Shock Sensor Install Help!
Old Feb 3, 2004 | 10:46 PM
tripwire's Avatar
W!ck3d $!ck
Exclamation Shock Sensor Install Help!
Ok, I received the "new" shock sensor today and I've installed everything up to Step 4. I cannot find the "brown" wire that I'm suppose to tap into. There is a 14-PIN connector that has some wires I tapped into per step 2, there are no Brown wires coming out of that.
Step 4 says "In the same harness, locate the BROWN wire coming from the 24-way connector." Where is the 24-"WAY" connector?
If it is the very large connector below the 14-pin "connector, I see one brown wire, but it seems as though it would be very hard to tap into, and the instructions don't show me tapping into that point.
If anyone has done this and can tell me what I'm suppose to do, that would be great. Thanks!
drebbrnator
Dec 27, 2018 07:02 PM
Paul_Y
Sep 21, 2015 02:23 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
