Viper Induction Kit, any info?
Old Feb 3, 2004 | 10:23 PM
M-ster's Avatar
Hi guys,
Came across this product, Pipercross - Viper Cold Air Induction Kit, looks like a farely interesting product, but couldn't find much info about it. Does anyone here has any experience with this Kit??
Here's a pix of the product.
And a little more read up here.
Old Feb 3, 2004 | 10:55 PM
Omicron's Avatar
Looks a bit like a vacuume cleaner hose with a "Typhoon" style element attached to it. :D
In other words, nope, never heard of it before today. Caveat Emptor!
Old Feb 4, 2004 | 01:16 AM
M-ster's Avatar
Here a close up of the call-outs
Old Feb 4, 2004 | 01:19 AM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
If its not made for the rx-8 i think its a rip
Old Feb 4, 2004 | 07:38 AM
XeRo's Avatar
Normality is Obscene
hmm...interesting...i'd like to see more info on it...
Old Feb 4, 2004 | 07:39 AM
ranger4277's Avatar
Cones need lovin' too!
With the way that intake is fashoned, it appears that it could be rigged to suck in the air through the hole in the front and through the existing 'outer' intake and second stage valve.
Not that this particular system is any less shady, but how much more beneficial would a setup like that be? You'd be guaranteed not to be sucking any engine bay air in while possibly utilizing the existing helmholtz tuning if done properly. (basically remove the restriction in the engine bay) Is the outer plumbing very restrictive?
I wish I had a shop where I could experiment with cars all day long... just for the sake of seeing what would happen.. maybe my next life.
Old Feb 4, 2004 | 08:04 AM
Spin9k's Avatar
Momentum Keeps Me Going
info from a seller site
Additional information (looks like an old product)
The technology used in the VIPER was first seen on the Lotus 340R. Now leading air induction specialists Pipercross are making it available for an ever increasing range of popular road cars.
The VIPER uses ‘velocity air force’ to direct cold air directly into the engine. The cold air feed takes air from behind the grill straight into the VIPER’s 100mm diameter inlet, swirling it through a unique Pipercross velocity filter contained within a carbon fibre heat shield, and then into a ram pipe to increase it’s pressure before feeding it into the induction system.
The carbon fibre heat shield protects the air charge from under bonnet heat, keeping it cool - and therefore more dense - thus introducing more oxygen into the combustion mixture, giving increased power.
The reverse flow technology filter and 150mm ram pipe make use of the physical phenomenon of air tending to move towards surface area's, creating more air flow on the edge rather than in the centre of the inlet. The unique design of the filter cone and the inlet 'tune' the moving air flow to increase its speed and therefore its pressure maximising the laminar air flow into the engine, again resulting in increased power.
The physics involved may sound a little complicated but the increase in power using a VIPER against a standard air box will be immediately evident. Just as obvious will be the VIPER's stunning looks - the carbon fibre heatshield connecting the polished alloy inlet to the 150mm rampipe will be the focal point of any engine bay!
The Pipercross VIPER Cold Air Induction Kit is now available for the Ford Probe 2.5L 24V (1994 onward).
Old Feb 4, 2004 | 10:40 AM
Speed Racer's Avatar
Certified track junky!!!
BMC Filter also makes a similar product called the Carbon Dynamic Airbox. I think it is a solid idea but the results can vary pretty dramatically from one car to another (i.e. S2000 - 3 Hp gain, BMW M3 - 18 Hp gain). So until someone tries one I'm not sure how much it would help our cars.
Old Feb 4, 2004 | 10:43 PM
So can u install in an rx-8,
anyone willing to test
Old Feb 4, 2004 | 10:54 PM
rotarygod's Avatar
I personally wouldn't waste my time with it.
Old Feb 4, 2004 | 11:08 PM
rotarygod,
So when are you going to design a helmholtz tuned intake that blows the competition out of the water? You'd make a small fortune if you could pull it off. :D
Old Feb 5, 2004 | 12:30 AM
rotarygod's Avatar
After I buy an RX-8. Money is tight right now.
Old Feb 5, 2004 | 12:59 AM
I'm sure that you could find a few volunteers around Houston that would be willing to let you experiment with some new intake designs. I know that would jump at that opportunity if I happened to live closer or at least in the state.
05rx8mazda
Nov 28, 2015 09:42 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Fickert
Sep 9, 2015 01:21 PM
