Cup holder or hot box
Old Feb 3, 2004 | 06:47 PM
rx8gator's Avatar
Get up and go!
Question Cup holder or hot box
Tonight, I put my cell phone in the drink holder and closed the cover. When I opened it and took it out, it was noticibly warm. Has anyone else noticed this? I guess it could be that the engine is located so close, but it seems strange.
Old Feb 3, 2004 | 06:59 PM
Sea Ray's Avatar
It will help keep your coffee warm but I did find out it is not good to store your M & M's in there.
Old Feb 3, 2004 | 07:15 PM
93rdcurrent's Avatar
The Stickinator
I guess that would go for Hershey Kisses and Peanut Butter Cups as well?
Old Feb 3, 2004 | 07:21 PM
rx8gator's Avatar
Get up and go!
I'll try to heat my sandwich for lunch tomorrow!
Old Feb 3, 2004 | 07:36 PM
Kaliken's Avatar
New AutoX & Track Addict
mmm molten m&m's hehe..
yeah my cold soda didn't last too long in there. oh well.. not as if I drink a lot of liquids in my car.
Old Feb 3, 2004 | 11:15 PM
Nubo's Avatar
Lubricious
We can make s'mores! :D
There's gotta be a way to sandwich some thin-sulation under there....
Old Feb 3, 2004 | 11:52 PM
Artifex's Avatar
Both my rx-7s had the same problem in the ash/coin tray. I carelessly put a 256mb flash drive in the cup holder when I first got the 8. Needless to say I learned my lesson.
Old Feb 4, 2004 | 03:19 AM
BillK's Avatar
FWIW, the cupholder in the center console of the Honda S2000 is also lovingly referred to as the "beverage warmer."
Old Feb 4, 2004 | 10:36 PM
markpmm's Avatar
FRONT CUP HOLDER / CENTER CONSOLE BECOMES HOT
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 40113124
Some customers may complain of the front cupholder area of the center console becoming hot after extended driving, causing cold drinks to warm. Due to the heat from the exhaust system (catalyst), the center console (cup holder area) becomes hot. This is due to insufficient insulation between the floor panel N cup holder. A insulation pad is available to reduce the heat transfer to the center console. 1. Remove the upper panel, hole cover (cigar lighter) and storage box from the vehicle. (See WSM 9-17-8) 2. Remove the six screws from the upper panel and remove the rear console. (See WSM 9-17-8,9) 3. Attach the heat insulater pad to the bottom of the front cup holder in the rear console removed at the above step #2. NOTE: Be sure to attach the heat insulator pad so that the bottom of the cup holder is wrapped. 4. Re-install the parts reverse order of removal. Parts information: F151-55-161 Heat insulator pad
Old Feb 6, 2004 | 04:49 PM
zojas's Avatar
wonder if the 05s will ship with that installed?
Old Feb 6, 2004 | 09:37 PM
ToRX-8orToZ's Avatar
Ummm... you sure? I keep my garage opener in my cup holder (MY03), and it never gets warm... even whem I'm shifting at 9.
Old Feb 6, 2004 | 09:43 PM
RX8_GT's Avatar
Thanks for the posting - I've noted this with my RX8. Will get it fixed at the first servicing. John
Old Jun 17, 2004 | 07:23 AM
kgoh2262's Avatar
I am not sure about the cup holder being warm ....but I did find out that the ashtray which I turn into a coin box, was hot......kinda supprise initially. Luckily did not have the time to turn that into candy corner....
Old Jun 17, 2004 | 08:01 AM
BasenjiGuy's Avatar
Beware of the cupholder fix- a few folks have posted that it may not reduce console temps very much...I may not have it done. I'm not sure the service guys could put everything back together without tearing something up or creating new squeaks/rattles.
Old Jun 17, 2004 | 09:24 AM
blue flash's Avatar
mine was mfg in dec04 an i dont have this problem
Old Jun 17, 2004 | 11:39 AM
NomisR's Avatar
It's not exactly difficult to take apart the center console. I've done so myself and not found a lot of insulation for that area where the cupholder should be. My cup holder usually ends up as a coffee warmer. Works great to warm up my lunch too!
Old Jun 18, 2004 | 01:00 AM
djantlive's Avatar
rotary engine produces high temp exhaust and your center console is near the pre-catalytic converter where heat is retained. that's why it heats up a lot.
vapor2
Jul 9, 2016 07:35 AM
Danield97
Sep 30, 2015 05:59 PM
XianUnix
Sep 29, 2015 03:48 PM
Rote8
Sep 22, 2015 03:43 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
