DIY: Test Neutral and Reverse Switch
Old Jul 5, 2010 | 12:39 AM
Jon316G's Avatar
Grasshopper
This DIY will show you how to easily test the neutral and reverse switch on a manual transmission.
1) Jack-up driver's side and support vehicle with jack stands.
2) On top of the transmission, about mid-line, you'll see four connectors... two white and two black.
a) White connector = neutral switch
b) Black connector = reverse switch
3) Remove both connectors for switch to be tested.
4) Use a multimeter, set to 'ohm', and attach a probe to each connector.
5) Have the shifter in neutral and observe multimeter's display:
a) For the neutral switch, the readout should display numbers.
Doesn't matter how much resistance you read, the inductive sensor just needs to "see" something.
DIY: Test Neutral and Reverse Switch-neurtal-switch-neutral.jpg
b) For the reverse switch, the readout should be "open" or no numbers displayed.
DIY: Test Neutral and Reverse Switch-reverse-switch-neutral.jpg
6) Now put the shifter into gear:
a) For the neutral switch, you can shift into any gear
b) For the reverse switch, you need to put it into reverse
7) Observe the multimeter's display:
a) For the neutral switch, the readout should be "open" or no numbers displayed.
DIY: Test Neutral and Reverse Switch-neurtal-switch-gear.jpg
b) For the reverse switch, the readout should display numbers.
DIY: Test Neutral and Reverse Switch-reverse-switch-reverse.jpg
8) Reattach connectors. It doesn't matter if you swap the connectors, just as long as the colors match (white to white, black to black).
Old Jul 6, 2010 | 08:37 PM
Sephitrask's Avatar
Zoom Frickin Zoom
Ok, seems to be a good place for this question. Is there any kind of reverse lockout that is supposed to be active while driving? I have occasionally ground reverse instead of going into 6th (I know, driver mod..). IF there is supposed to be a lockout, is it mechanical or electrical?
Old Jul 6, 2010 | 08:58 PM
Jon316G's Avatar
Grasshopper
Yes, there is a physical hard stop... here is where its located:
DIY: Test Neutral and Reverse Switch-shifter-hard-stop.jpg
The shifter itself has a tab that sticks out and hits that hard stop, preventing you from going into reverse.
This is why you have to press down on the shifter to get it into reverse... you're moving that tab under the hard stop.
Might be best to pull-up your center console and look at it... see what it looks like.
Old Jul 6, 2010 | 09:41 PM
ASH8's Avatar
Super Moderator
Yep Jonathon is right ..again.....as always...
I would buy you a beer or put a prawn (shrimp) on the BBQ if you ever came Down Under.....YOU are a Great help to all here, you give great advice..
The Series 2 RX-8 is similar, except Reverse is PUSH DOWN and Left UP.
Sephitrask, Don't know how you are getting Reverse Gear unless you are pushing down when shifting or your Tab (Mazda # Y601-17-571A WOW $53 ) is also worn or busted as Jon shows??
Old Jul 6, 2010 | 09:54 PM
Jon316G's Avatar
Grasshopper
Originally Posted by ASH8
Yep Jonathan is right.....
Fixed
I know... being picky...
If I ever fly out that way I'll take you up on that.
Though seeing as I've never been further west than Ohio (where I live), that shows you how I am with traveling
I honestly didn't know that... learned something new...
Old Aug 25, 2010 | 12:58 AM
Tony Watlington's Avatar
AZ testing
Attachment 158704
Attachment 158706
Attachment 158705
Attachment 158707
Very thorough explanation. since im trying this with the tranny still installed are you testing the male or female ends. It looks like the female ends in the pic but I wanna be sure. Thanks again for the post.
Old Aug 25, 2010 | 05:24 PM
Jon316G's Avatar
Grasshopper
It would be the male ends. The connector has a flat blade style contact.
You can easily follow the wire from the neutral switch since its a couple inches away.
Old Sep 21, 2011 | 01:15 PM
ASH8's Avatar
Super Moderator
Lets Clear this one up First....
The Reverse and Neutral Switches on Series 1 RX-8 6 Speed Manuals ARE NOT the same.
Mazda NAO have corrected their erroneous superseding which cause so much confusion for many years..
Y611-17-640A Neutral and Park Switch
Y612-17-640B Reverse- Back-up switch
Auto's do not use these switches they have a single larger unit incorporating gear selection switch...called an Inhibitor Switch
Old Sep 21, 2011 | 09:31 PM
Jon316G's Avatar
Grasshopper
Originally Posted by tkepper
I know everyone flames to search, but the features even in advance search did not help me find my answers. New to the community here, but it seems to be very quick to flame new people toward searches, that in my experience do not yield good results.
Please do not use my thread as a source to complain about your feelings toward the general population of this forum.
Comments like this could prevent people from helping you and welcomes argumentative members to crap all over this thread.
Old Jan 29, 2012 | 12:14 PM
camilo's Avatar
Could my reverse switch be stuck if my reverse lights dont turn off even when ye car is off?
Old Jan 29, 2012 | 12:30 PM
Jon316G's Avatar
Grasshopper
Two questions
1) Have you recently done work with the reverse lights such as changing the bulbs?
2) Do you have an MT or AT?
Old Oct 26, 2012 | 10:30 AM
Chino_rx3's Avatar
Gulf Coast Rotaries
Man I just got the code p0850 and im goin to try this. Love searchng and finding how to do it right thanks again, Grasshopper lol (jon ) you always have a good answer to a fix or how to look and see if you need to change or test something,.
Old Jul 11, 2013 | 11:46 AM
RX-G's Avatar
thanks jonathan. this was very helpful.
Old Mar 4, 2014 | 07:28 PM
toddkrein's Avatar
Thanks very much for the pics! Just had to do this last weekend.
Now, how hard is it to replace the reverse switch?
Edit: Turns out it was pretty easy...
Old Sep 2, 2015 | 05:31 PM
xAgyex's Avatar
Does anyone know how to remove the neutral switch when the transmission is still on the car? I was trying to look for a socket like the O2 sensor socket that is 26mm, but no luck...any advice is welcomed.
Old Sep 3, 2015 | 03:34 AM
Jon316G's Avatar
Grasshopper
Think a crowfoot wrench would be your best bet.
Old Sep 8, 2015 | 02:26 PM
xAgyex's Avatar
***View this on my thread it looks better****
So I was able to fix the neutral switch on my own with the transmission in the car. Tigth fit but with Husky's Universal Pass-Through sockets it was a breeze.
Order from Mazmart.com RX-8 Neutral & Park Switch (2004-2008) - Manufacturer part number: Y612-17-640B - $95 part+2 day shipping
Also pickedup Husky Universal Pass-Through socket set, used then returned it back to home depot...all within 2 hours. You need a 27mm Pass-Through socket. - $130 (But I returned it so $0)
1. Jack up the driver front side of the car.
2. Support with Jack stand for safty.
3. Locate the neutral switch shown below
4. Disconnect 2 white clips
5. Thread clips through pass-through socket - 27mm
6. Carefully remove neutral switch
7. Install new switch
8. Remove jack stand and jack
9. Clear the CEL P0850 code
10. Have a bear and then go for a ride
New on left vs Old on right
***If your car is idling weirdly and using a lot of gas and you got CEL P0850, do your self a favor and replace the neutral switch asap.***
Old Sep 8, 2015 | 02:29 PM
xAgyex's Avatar
Jon316G, thanks. I ended up picking up a set of pass-through sockets, and it worked like a charm.
Old Sep 15, 2015 | 02:26 AM
mrpablozone's Avatar
Hi,
I have question about reverse switch. Is there any chance to search reverse switch, or any cable connected to it, from interior? I want install parking camera to RX-8. The camera is connected to reverse lights. The LCD for this camera is connected with camera wirelessly. The LCD is connected to +12V cable to lighter. But the receiver (for camera signal) heated and I want connect the receiver for +12V cable, which has heads to/from reverse switch or any cable, which in voltage only, if i have shift into reverse. Is any chance to do it without decompose transmission from car? Could you anybody send me photo of position of it or write me a instructions? Thank you for help.
PS: Sorry, i forgot send info about rx-8. So it´s Mazda RX-8 2004, Automatic 4-level transmission (141 kW)
Old Dec 30, 2021 | 04:11 PM
Killawatts's Avatar
spent so much money
Very old thread, but just an FYI to add on here: On the S2 transmission, the black connector is the neutral, and the grey is the reverse, so kind of the opposite of the S1 trans.
Old Apr 12, 2022 | 03:43 PM
andrewhelmus's Avatar
DSC Off
Just wanted to share my appreciation for your input in this thread! Saved me a headache while doing a S2 transmission swap into my S1. Thanks!
Old Apr 24, 2022 | 02:31 AM
Killawatts's Avatar
spent so much money
I'm glad to be of help.
Old Apr 24, 2022 | 06:12 AM
Red line envy's Avatar
I bought a 26mm socket and cut a slit up the side of it. Worked great.
Old May 3, 2022 | 06:20 AM
yep
Old May 10, 2022 | 10:39 AM
james1202's Avatar
hi, I need your help....I recently changed the S2 Transmission, but Neutral Switch is no work,
I want to know Neutral Switch of S2 is the same as S1?
