Stealth Bulbs
Old Feb 2, 2004 | 06:24 PM
Tirxer's Avatar
Stealth Bulbs
worth it?
edit- what are the sizes for the turn signal bulbs?
how do u install them?
Old Feb 2, 2004 | 07:56 PM
mikeb's Avatar
100% Italian
turn signal bulbs are 7443 in size
Old Feb 2, 2004 | 08:00 PM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
How the heck do I reach into that area Mikeb? I can't seem to get into it... turned the tires to the far right, took off those pegs, and I still can't reach into it... is there an Easier way?
I got 7440 bulbs which the parts dept at Mazda said should be good.
Old Feb 3, 2004 | 08:55 AM
Tirxer's Avatar
OEM Stealth Bulb 7506 fit?
thats as close to 7443 i can find
Old Feb 3, 2004 | 05:29 PM
mikeb's Avatar
100% Italian
no, those wont fit
I got mine from ebay they are stealth bulbs but not by that company. That company doesn't have 7440 yet
Old Feb 3, 2004 | 05:37 PM
brothervoodoo's Avatar
RainMan is Back
Todd has something that fits, probably one of those other bulb numbers. On the stealthauto.com website it show his RX-8 with his stealth bulbs but I don't know what part number he is using.
Old Feb 3, 2004 | 05:59 PM
Tirxer's Avatar
so wait, then 7443s are basically side marker bulbs?
am i right?
Old Feb 3, 2004 | 06:11 PM
mikeb's Avatar
100% Italian
next to the headlight is 7440
next to the mazda emblem is 194
the corners by the fenders are also 194
Old Feb 3, 2004 | 07:44 PM
garyna's Avatar
I just picked some "silvervision" bulbs from auto-illumination. I bought 7440's for both front & rear turn signals. They look great on the RX-8. The only drawback is they don't flash real bright orange like the stock bulbs do. I suppose the silver coating has to reduce the amber light to a degree. But for $3.49 each, no complaints here.
http://www.autolumination.com/
BTW: to install the front bulbs, you have to remove 6 plastic tabs that holds the fender liner. I was able to peel back the liner just enough to reach in behind the headlight assembly and get to the bulb. Pretty easy, the fronts took 10 minutes. If you search for clear side marker install, you'll find a step by step w/ photos on how to remove the fender liner.
-gary
Old Feb 6, 2004 | 12:09 PM
ATX25RS's Avatar
there are a few companies that make these bulbs.
philliips silvervisions as mentioned is one.
Sylvania also has silverstars in other sizes that match the headlights. they have a crome slight blueish tint to them, they flash a color REAL close to the silverstar headlights.
APC and 3A racing make "titanium" bulbs that look crome, but flash red, yellow, hyperwhite, and blue.
Old Feb 6, 2004 | 01:06 PM
D MENAC 7's Avatar
Moderator with a mycocardium
I've done the rear turn signals and back up lamps with the silvervision lamps from http://www.autolumination.com/
Both the amber turn signals and the reverse lights are quite dim in comparison with the stock lamps. I got a couple of red 7443 LEDs that I am going to try with the tail lights/ brake lights and see how they look with this combination.
I have replacement amber 7440s for the front too but haven't had the time to mess with installing them yet. My 15 year old has small hands and that was a big help with the rear lamps. I'll probably employ him for the front lamps, too.
Another post on the forum identified the third brake light as being a 194 but it is a 7740.
I'm thinking about doing a mod to the third brake light with either a custom LED arrangement or some other LED third brake light stock part modified somehow. Not sure what yet about that. Autoilumination sells bare sockets so any modification would be an easy plug in. One other idea about th third brake light is to black out some of it so that when the brake is applied the RX-8 logo is displayed. I haven't read a thread on here about doing that, has anyone else?
Does anyhone know what the small light on the sides of the tail lights that are red when the lights are turned on are? Are they LEDs or tiny grain incadescent? My bet goes to LEDs because incadescent would eventually burn out and they would be a b**ch to change!
Old Feb 6, 2004 | 03:58 PM
mikeb's Avatar
100% Italian
those back lights are led
Old Jul 10, 2004 | 03:42 PM
Equis's Avatar
Speeding Ticket Magnet
Pleeeeease don't buy the APC ones those burn out so fast, and it's not even orange is like a dark orange red.
Old Jul 10, 2004 | 07:27 PM
Krayzie8's Avatar
are there bulbs on this site http://www.autolumination.com/ that will exchange the interior lights??
Old Jul 10, 2004 | 07:50 PM
mikeb's Avatar
100% Italian
that company sold me poor quality lights^^
Old Jul 11, 2004 | 10:34 AM
Lacroft3's Avatar
www.stealthauto.com makes 7440 bulbs for the turn signals.I have them installed on my car and they fit perfect.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
arexatemate
Oct 9, 2015 06:23 PM
CARBONRX-8
Aug 23, 2015 09:52 PM
