headlight hazing already!!!??
Old Jun 17, 2010 | 01:57 AM
Juan09's Avatar
Question headlight hazing already!!!??
ive had my 8 a little less than a year now and my headlights are already hazing. i took it in to the dealership this morning and asked if the warranty covered it and one of the guys said he doesnt think so because the hazing isnt inside the headlight and that its possibly some chemical that ive been putting on them.......if so, does anyone know of a solution to this??
Old Jun 17, 2010 | 02:47 AM
Dirt_Nasty's Avatar
Filth in a world of Clean
It's on the outside of the headlight, so using a cleaning kit, like ones made by rain-x, will remove the deposits.
Old Jun 17, 2010 | 06:05 PM
invasion08's Avatar
Go to yout local walmart, they sell a few headlight kits. If you catch this early they should work just fine.
Old Jun 17, 2010 | 07:32 PM
silverkillrx8's Avatar
or if you r cheap go in ur bathroom and get your nice little bottle of toothpaste and a lil bit of elbow grease and should come out fine... did this with mine and looks awesome
Old Jun 18, 2010 | 12:41 AM
jasonrxeight's Avatar
plasticX works wonder.
Old Jul 3, 2010 | 09:26 AM
Never L8's Avatar
^Is that the Meguire's product? I don't have it with me, but Meguire's makes a really great plastic polish. It cleaned my lights up perfectly. This is an easy fix with the ideas mentioned here.
Old Jul 3, 2010 | 09:45 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
"yes, it is".
Old Jul 3, 2010 | 01:44 PM
mZimm's Avatar
I picked up the Turtle Wax headlight restoration kit for like $8 at Target, it was on sale last week. Worked phenomenally.
Old Jul 3, 2010 | 01:49 PM
mscamp02's Avatar
Blue Bullet?
if all else fails you could always wet sand and buff
Old Jul 3, 2010 | 01:52 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
I used the Rain-x product last week and it worked great! I had to resort to the good 'ol sand and buff for my santa-fe though, the cleaners were not enough.
Old Dec 3, 2010 | 07:06 PM
Boltaction's Avatar
Yes there is a simple and quick solution.
What ever you do don't listen to the advice telling you to sand your headlights.
All you need to do is deoxidize them with a acrylic lens deoxidizer.
It's liquid non abrasive system that won't damage your lens.
http://www.ibc34.com/Onestep.html
Old Jun 30, 2011 | 09:21 PM
don_peppino24's Avatar
The Don
what i did with my headlights is polish them with a foam pad and menzerna super intense polish, then menzerna super finish.
for a long lasting finish, i carefully applied a few coats of clear and then some world's best wax.
Old Aug 24, 2011 | 12:08 AM
Necksnapper's Avatar
3M makes a pretty sweet little kit that works wonders. Plenty of options out there for this! Mazda tried to pawn off a $195 treatment on me! I need to open up a car dealership so I can start extorting money out of people!
Old Aug 24, 2011 | 02:06 AM
SayNoToPistons's Avatar
Wheels, not rims!!
Any polish will work... Dont waste your money on expensive headlight polishing kits. Abrasives are abrasives -_-... Make sure you seal them with a sealant/wax after.
Old Oct 24, 2011 | 01:44 PM
extremsprt86's Avatar
i rock compound on a small foam disc attached to a 90 degree die grinder, follow up with plasticX, and then seal it with blue magic lens sealer.
do that 2x a year they look good as new.
Old Oct 24, 2011 | 01:51 PM
Deathwatch's Avatar
Deathwatch
I use Flitz, Works really well......You can find this product at any Uniform Shop. "Poilice Uniforms" Walmart might have it too.
http://www.walmart.com/ip/Flitz-BP03...-Tube/16493905
Old Oct 26, 2011 | 07:48 PM
Tamas's Avatar
Registered Lunatic
It was said by some folks that these headlight restoration compounds and methods work fine but the haze returns after a while.
After getting rid of the haze, I'd suggest applying some headlight protection film so that the lens is sealed and the haze doesn't show up again.
I had such a protector film on my headlights from very early on and after 8 years of ownership, there is no sign of any hazing.
Old Nov 9, 2011 | 09:22 AM
firebirdude's Avatar
User and Abuser
Use any abrasive product or one of the headlight restoration kit. Then hit them with a heat gun set to high. The plastic is thick, so you'll have to move the heat gun very slowly for it to melt in the tiny scratches/hazing. If you don't think it's working, hold the heat gun in one spot for 4-5 seconds. You'll see the hazing disappear. Works like a champ.
Old Nov 13, 2011 | 06:10 PM
Boltaction's Avatar
It has been my experience that the less you do to the headlight the better.
Every time you rub an abrasive on your lens the more surface material you displace.
Over time that will cause the lens to cloud up with scratches.
Unlike oxidation scratches caused by abrasive cleaning will not come out with a non abrasive liquid, you will be forced into using more abrasives to remove them.
In addition the lens can suffer from UV layer break down and turn yellow. Eventually, You won't have a choice and you will have to replace the lens.
I find that abrasives have their place in extreme cases but for oxidation removal it's counter productive and causes unnecessary damage.
Old Nov 14, 2011 | 03:09 PM
dynamho's Avatar
Clean it with a headlamp lens restorer then protect it with Lamin-X.
http://www.lamin-x.com/Automotive-Products-s/47.htm
Old Nov 14, 2011 | 03:15 PM
Tamas's Avatar
Registered Lunatic
Exactly.
Old Jan 27, 2012 | 10:30 AM
Pikashoe's Avatar
lets dance
I bought a restoration kit from autozone. i will take pics of the before and after
Old Nov 3, 2012 | 04:43 PM
Boltaction's Avatar
Well it's been about a year now, What happened?
Did you use the product? did you take before and after pictures and if so. How does it look today 10 months later?
Were you happy with the product relults?
Old Nov 9, 2012 | 03:55 PM
Pugheaven's Avatar
Pug 205 & RX8 Lover
UK
Me too, it works perfect then buff in some car wax, hey presto in 10 minutes perfect headlights again!
Old Nov 9, 2012 | 09:10 PM
Sugarfree135's Avatar
I've experienced the whole return of the haze problem before so with the 8 this time around I personally used the rain x kit and after sealing them I put 3m clear bra over the headlights so it won't be a problem ever again lol
