Quick Question about The Mazsport Cooling fan mod
Old Jun 5, 2010 | 01:01 PM
Kevinbonds's Avatar
Just wanted to know if anyone knows what happens with the Maszport cooling fan mod if the supplied sensor that T's into the cooling hose goes bad?
Will this keep your fans from coming on? Or will it just not come on at the lower temp? The reason I ask is recently I have had to do a ton of city driving and idling, just want to make sure if something goes haywire with the sensor I wont overheat.
Old Jun 5, 2010 | 05:32 PM
Kevinbonds's Avatar
Nobody? 38 views and not one post? Someones got to have some info?
Thanks,
Old Jun 5, 2010 | 05:43 PM
laythor's Avatar
I zoom therefore I am.
since the company that makes it no longer exists (cough) and anyone who had anything to do with making that device only reads these boards but doesn't post... i think you're going to end up with only "it should, i belive, probably" replies.
Might get lucky and have someone stumble across this thread who had it happen to them.
Old Jun 5, 2010 | 05:51 PM
invasion08's Avatar
I have had my mazsport cooling fan mod for a few yrs now and no problems. I think if the sensor ever went bad the fans would kick at the normal oem temps. The relays are almost the same except the mazsport ones are connected and wired to the sensor. Someone correct me if I am wrong.
Old Jun 5, 2010 | 06:03 PM
Kevinbonds's Avatar
I was thinking the exact same thing. My thought was since they are identical relays they would just kick on at the normal temps.. Just wanted some type of confirmation...
Thanks for the posts so far!
Old Jun 5, 2010 | 06:25 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Not really sure what would happen. Thinking it would just go back to original temp.
Mines been fine for years as well.
Oh, and I kept the other relays just in case.
Mar 1, 2019 09:00 AM
rotorocks
47
May 11, 2016 03:23 PM
RA32425
10
Sep 8, 2015 08:53 AM
badinfluence
Aug 31, 2015 11:51 AM
PlayInMyWoods
Aug 8, 2015 07:03 AM
