VIS carbon fiber hood,
Old May 25, 2010 | 09:59 PM
Z0oMzo0m's Avatar
De-oxidizing the hood begins!
On my last car i had a VIS invader hood. I kept the car in sun daily but had the hood for a year and half with no defects on the clear, i kept it waxed. I sold the car and gave the hood to a buddy of mine. He had the hood for past 2 and half years and now its oxidized. The clear isnt peeling, it is still rather really smooth! but i picked the hood back up from him for free and going to put it onto my girlfriends car.
Any ideas on how to clean the hood up?
WET SAND extremely fine grit?
LOTS OF BUFFING?
Needs to be cleared again?
again the hood is still really smooth, no clear peeling, like i have seen others do.
Last edited by Z0oMzo0m; May 26, 2010 at 08:42 PM. Reason: title change, for new thread
Old May 25, 2010 | 10:06 PM
Z0oMzo0m's Avatar
http://www.randomguysblog.com/2009/d...on-fiber-hood/
Look at that found my own answer! gotta love google!
Old May 25, 2010 | 11:10 PM
rodjonathan's Avatar
silent assasin
great find
Old May 26, 2010 | 08:40 PM
Z0oMzo0m's Avatar
Here are the pics of how the hood looked before any work was done.
Old May 26, 2010 | 08:44 PM
mscamp02's Avatar
Blue Bullet?
are there hood pins on it?
Old May 26, 2010 | 08:57 PM
Z0oMzo0m's Avatar
yes there are hood pins.
I started using light sand paper, and some acrylic clear rattle can spray paint. and rubbing compound. This was taking way to long..
Old May 26, 2010 | 08:59 PM
Z0oMzo0m's Avatar
Since this way taking to long, and wasnt even with a rattle can, i started all over and stripped it down and got some automotive paint since my dad has a spray gun and compressor.
Old May 26, 2010 | 09:00 PM
laythor's Avatar
I zoom therefore I am.
unless you want to do it again... get the hood cleared at some point. or even a 3M clear bra. After almost 2 years my seibon CF hood started to oxidize... I painted it the body color.
Old May 26, 2010 | 09:06 PM
Z0oMzo0m's Avatar
Yeah the 3m would possibly be best thing overall after its final.
But i have to give VIS, 2 thumbs up for there quality!
Old May 26, 2010 | 09:18 PM
8upbad's Avatar
Jared
Subscribed!! There are lots of options here. I need to research and get back to you, but this project is perfect..... Weight savings, cooling options, attention from the ladies.... Good times.
Old Jun 13, 2010 | 02:14 PM
Z0oMzo0m's Avatar
Well guys, been a little bit but here's the status with the hood. Since its first time ever doing this, it was a learning experience and time consuming, and have to be patient..
I spent some time sanding spraying, sanding spraying and sanding spraying...
Basically wet sanded hood down till it was haze free, when you wet sand the oxidation its usually a yellow milky color.
I used 600 grit wet/dry paper.
Once the hood was free of oxidation, you should see white milky streaks from sanding.
Here is what it looked like after i cleared it.
Old Jun 13, 2010 | 02:17 PM
Z0oMzo0m's Avatar
i went to do a last and final coat and it oranged peel all over the place.. It got to hot outside and i should have stopped when i was ahead.
So i had to get out the sand paper again and get back to work..
Here is the clear coat i am using, easy mixing, and fairly cheap. cost 35.00 total
Old Jun 13, 2010 | 02:22 PM
Z0oMzo0m's Avatar
Once it was sanded back down to..
I was able to start clearing again. This time i changed the guns, and used a finishing gun. Really took some time and still in process. Il post pictures of the after math. hopefully it will be done
Old Jun 13, 2010 | 03:43 PM
laythor's Avatar
you've been doing all the sanding by hand?
Old Jun 13, 2010 | 05:28 PM
Z0oMzo0m's Avatar
yes, only way to feel it get really smooth like ice while wet sanding
Stevent1986
Jun 3, 2023 08:56 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
GK1707
Sep 27, 2015 07:33 PM
