Autocross - Full or empty tank of gas?
Old May 22, 2010 | 06:53 PM
GotBass's Avatar
Still plays with cars
Going autocrossing tomorrow and want some imput on how much gas I should have in my tank.
I have heard 2 different theories, both from auto-x instructors. Both claim to be faster.
1) As little gas as you need to make it through the day. This saves about a hundred pounds.
2) Full tank of gas. Helps handling since the gas is not sloshing around throwing off balance.
Has anyone tried both and seen a difference?
Old May 22, 2010 | 06:56 PM
laythor's Avatar
I zoom therefore I am.
i would say bring as much as you need to get through a full day of auto-x. unless you're bringing jerry-cans. of all the things i've read about auto-x i would think "how much gas should be in my tank" would be somewhere next to "should i go with the pine, or vanilla air freshener"
edit; I say that because I would rather be slower because of a full tank of gas, then run out of gas half way through the day
Old May 22, 2010 | 06:57 PM
TopGear8's Avatar
mkuhnracing.com
If its your first event then keep it filled up..you won't notice a difference...But most of us will run with a 1/4 tank of gas...Each gallon weighs about 8lbs..
Old May 22, 2010 | 11:28 PM
kjchristopher's Avatar
I did the last 4 runs of a pro-solo with the light on.
Old May 23, 2010 | 02:07 AM
fuel pump does not like low gas.
hey, but what do i know.
Old May 23, 2010 | 02:24 AM
ScottyStyles's Avatar
Tailhappy
First event, definetely full tank. At events that I go to now, I generally show up with about half a tank.
Old May 23, 2010 | 09:22 AM
wankelbolt's Avatar
1% evil, 99% hot gas.
Six pounds per gallon. It varies a bit depending on grade and temperature, but roughly 6.3 lb per gallon.
Water is 8.33 pounds per gallon.
And I would definitely run 3/4 to full tank on your first autocross. You've got other things to worry about! Enjoy the ride!
And when it's over, send your result to MAZDASPEED Motorsports. One more set of results and you'll be able to buy stock parts at dealer cost. Coils for $28.85, wires for $48, etc.
Old May 23, 2010 | 11:29 AM
BRODA's Avatar
Not yet famous
I have done this several times also. Never had an issues.
^ This is really good advice.
1/2 tank is the worst of both world. This will give you lots of extra weight plus maximum "slosh". Either full or empty... Anything in between will only slow you down.
Old May 23, 2010 | 01:33 PM
Anijo's Avatar
Cone Abuser
Don't go below 1/4 is the guidance I've gotten to preserve the fuel pump and avoid starvation.
Old May 23, 2010 | 01:48 PM
track days and autocross are two different animals. I wouldn't suggest going out on a track with the light on....
Old May 24, 2010 | 03:39 AM
takahashi's Avatar
AutoX may not generate as much G force to create fuel starvation like in the circuit. I never have fuel starvation over 1/4 fuel. So close to half tank is AOK.
Old May 24, 2010 | 06:30 PM
fossumja's Avatar
Jim51
I try to just have the light come on on last or next to last runs, but as mentioned, having an extra 12 lbs (2 gal) of weight will not make a noticeable difference to your times. Running out of gas will.
Also, this may sound obvious, but if you are going to run it low, make sure there is a gas station nearby (and open on Sunday) so you can make it home!
Old May 24, 2010 | 07:47 PM
dmitrik4's Avatar
please wait for the beep
autoXing -- you're doin it wrong.
you don't have as many instances of sustained (i.e., 3+ seconds) high Gs, but the peak Gs are definitely higher during autoX than on a track. plus the transitions on a track are MUCH less sudden and frequent.
we starved at a recent event on a not-super-grippy lot just after the light came on. the course was ~1 mile (low 80-seconds), and the light came on just before one run. we had starvation on the next run. i generally show up with just over 1/4 tank (but i have a co-driver).
Old May 25, 2010 | 11:15 AM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
We always started the event with a 1/4 - and even then got fuel starve on two occasions. On another occasion I ran the car completely out of fuel without a hiccup. The course layout has a big impact on when it occurs. But a 1/4 tank is safe most of the time.
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Aug 29, 2018 10:14 AM
Azki23
Jun 27, 2018 03:48 PM
RXFEVER
Sep 11, 2016 02:51 PM
stickmantijuana
Sep 4, 2015 10:31 PM
