Spec for the stock wheel
Old Jan 30, 2004 | 09:22 AM
RotaryZZ's Avatar
Does anyone know the exact specification for our 18" wheels. Is it 18x8 or 18x8.5? What's the offset and how much it weights.
TIA,
Pete
Old Jan 30, 2004 | 09:55 AM
RotaryZZ's Avatar
Also, what's the size of the wheel nuts? Is it 16mm??
Old Jan 30, 2004 | 02:07 PM
mdw33333's Avatar
18" x 8" 5 x4.5" bolt circle, as for the offset, I'm not sure, I've been told it's +45 or +50. The lugs are 12mm x 1.5.
Old Jan 30, 2004 | 03:01 PM
RotaryZZ's Avatar
Thanks. Do you know how much it weights too?
Old Jan 30, 2004 | 06:04 PM
Koala Joe's Avatar
Pink Slip?
The Stock Rims are 18x8 all around, with offset of +50. Bold pattern is 5x114.3. Weighs about 26lbs each.
Old Feb 1, 2004 | 02:10 PM
RotaryZZ's Avatar
Btw the lug nuts for the 18" wheels is not 12mm. I've asked the parts dept of one nearby dealer and they don't even know about it. Pathetic!! My guesstimate is 20mm. Do anyone know for sure?
TIA,
Pete
Old Feb 1, 2004 | 02:38 PM
DUGS_REX's Avatar
TIA,
Pete
I believe the 12mm was referring to the Threaded Stud Diameter, not the Size wrench you need to remove the nuts.
Billy Marcial
Mar 1, 2018 06:50 AM
Paul_Y
Sep 21, 2015 02:23 PM
dafiltafish
Aug 21, 2015 06:56 PM
