Led Lighting
Old Jan 29, 2004 | 12:44 PM
Need For Speed's Avatar
SPEED-8
Led Lighting
LED LITS FOR MY 8
Old Jan 29, 2004 | 12:45 PM
SPEED-8
INSTAL PHOTO
Old Jan 29, 2004 | 12:46 PM
SPEED-8
Old Jan 29, 2004 | 12:47 PM
SPEED-8
CRISTALE SAUMADOS
Old Jan 29, 2004 | 12:51 PM
SPEED-8
DETRAS
Old Jan 29, 2004 | 12:52 PM
SPEED-8
DELANTE (FRONT)
Old Jan 29, 2004 | 07:43 PM
mikeb's Avatar
100% Italian
looks way better with all the lights matching in the front
Old Jan 31, 2004 | 08:13 AM
Tirxer's Avatar
was it hard to install?
Old Jan 31, 2004 | 10:46 AM
TiRX8's Avatar
ROTOR?
I couldn't agree more. Looks great!
Old Jan 31, 2004 | 01:00 PM
SPEED-8
IT' S WASS HARD TO INSTAL THER IS NO SPACE TO INSTAL THEM
I OSO PUT MI SHOP EMBLEM
Old Jan 31, 2004 | 01:03 PM
SPEED-8
Old Feb 3, 2004 | 03:48 AM
SPEED-8
parcking system
Old Feb 3, 2004 | 08:13 PM
Isamu's Avatar
Nice! So to double check before I go running out and buying myself a pair of Raybrig RC23's, "W5W" mentioned in other threads is the same as "168 wedge light 12v0.2w" (RC23)?
168's will fit into that tiny parking light beside the emblem?
(How to get it in there would be another question)
Old Feb 5, 2004 | 04:49 PM
ATX25RS's Avatar
194, 168, and 158 ar all the same bulb....they are small wedges. as for more pics of LED bulbs ....here are some from the subaru guys....
Old Feb 5, 2004 | 07:12 PM
mikeb's Avatar
100% Italian
what is flash
what does with flash mean
camera flash?
Old Feb 5, 2004 | 07:28 PM
mental pimp's Avatar
Se ve muy bueno, por un momemto yo creia que ponistes las luses abajo de tu carro
Old Feb 5, 2004 | 07:32 PM
Genom's Avatar
Not so Super right now
Yeah, they mean the camera flash when taking pics.
Old Feb 6, 2004 | 09:36 AM
BRx8's Avatar
Ero-sennin
i used to have LEDs but they turned out too bluish in color...i since took them out and replaced with Polarg xenons...it matches MUCH better with the HIDs...you can't even tell...only lights i haven't changed is the HIDs...can you even change those bulbs to get them whiter?
Old Feb 6, 2004 | 10:32 AM
ATX25RS's Avatar
Polargs are teh best you can get in there.
as for the HID's the higher the K rating for the bulb the more purple the color is. ie stock halogens run about 3000K most HID's/ hyper whites range in the 4300K-5000K range....then the purpleish lights like audis are more in the 7000K range...and so on....
try these websites for info and some bulbs. i think, i am not sure, that changing the bulb will change the color. i dont know that you need to change the ballasts too.
http://www.misterjung.com/ or www.danielsternlighting.com
Old Feb 6, 2004 | 12:04 PM
ATX25RS's Avatar
Mcculloch or Brightstar are also good kits.
Old Feb 9, 2004 | 03:33 AM
Xyntax's Avatar
THREAD KILLER
I have a couple spare blue 194 LEDs here. How can I install these to those driving lights? I have been scoping it out but can't seem to find the place where I could install them. Pls help.
Old Feb 9, 2004 | 11:27 AM
ATX25RS's Avatar
into the parking lamps? it is a real PITA. you either have to have small hands or be really flexible. on the driver side if you remover the fuse box cover it is a bit easier. reach in there and twist off the connector. pull it out and replace the bulb. to get it into place it is easier if you have the lamps on to see what you are doing. put it back and twist it back on. the passenger side is easier if you remove the engine covers. there is a box there with three 10mm bolts, remove those then unclip the two small retainer clips on the outside edge of the box, then its the same twist off. good luck and try not to get frustrated, it takes patience :D i've done this several times...and i own a subaru not an RX
Old Feb 23, 2004 | 03:31 PM
RonD-NM's Avatar
What color are they? Blue+Blue, Blue+White, White+White.
Found here for $33.oo http://www.intakeone.com/Light_bulbs..._23_Bulbs.html
Old Feb 23, 2004 | 03:33 PM
RonD-NM's Avatar
Sorry,
I guess they are the White+White (RC23)
-Ron
cliffkemp
Dec 24, 2024 10:48 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
xAgyex
Sep 28, 2015 08:54 AM
Evan Gray
Sep 26, 2015 12:30 PM
