RX8 Starter Recall??
Rating: Thread Rating: 6 votes, 5.00 average.
Old Apr 26, 2010 | 12:19 PM
REAL_SPEED723's Avatar
so my car has been having trouble starting and i took it into the dealership and they said that they needed to change spark plugs and do a fluid flush and stuff idk. all i know is that they tryd to charge me about $350 to change my spark plugs which was extremely over priced when spark plugs are right behind your front driver side wheel. and they also tryd to charge like $170 for the fluidflush crap.
so heard from a few rx8 owners that they got the starter replaced for free on there rx8 by the dealership, there was a recall for them being to small and weak so they where giving hard starts and was an open issue. told the dealership this and they said there was no recall for the starter and pretty much told me i was wrong. so im just woundering if anybody has any input on this?? maybe you got yours replaced, how you went about it, what documentaion i should take as proof... i dont want to have to pay for a new starter if there was something put out by mazda saying this is an issue that needs to be fixed if it ever happened to any rx8.
thanks everybody for any input!
Old Apr 26, 2010 | 12:36 PM
RIWWP's Avatar
The weak starter was not a recall (which doesn't expire), but a TSB, which only covers the weak starter under bumper to bumper warranty.
The weak starter was only for 2004 and a few 2005 early builds, which the bumper to bumper has expired for all of those on time alone, if not mileage.
If your starter is indeed failing, it's all on you unfortunately. My new starter from Mazmart is arriving tomorrow.
And the plugs are $80 from vendors here on the forums and a 10 minute change job that is cake to do. Do it yourself and don't let them rape you again
Old Apr 26, 2010 | 12:48 PM
expo1's Avatar
He's as bad as Can
The attached old TSB will explain how to tell if your 8 has the older starter. This TSB (ENGINE CRANKS NO START) has been revised many times, the only valid info is in regards to the starter.
File Type: pdf
Old Apr 26, 2010 | 12:55 PM
thanks for the input riwwp, i changed my spark plugs but i guess that didnt fix the problem so im hoping its the starter. il go check out the mazmart to look at pricing for the starter.
thank again man!
Old Apr 26, 2010 | 01:05 PM
RIWWP's Avatar
If you get the number from the dealer at all, in case they checked, a starter should be able to crank 250rpm+, 300 or 350 is much better, 350 being that "instant start". My hard start started showing up when my cranking speed had dropped to 200rpm, and it's probably down to 180 or so now, takes forever to start, constantly worried about flooding it.
Fortunately only 4 more starts before I am home with the new starter in hand, I keep crossing my fingers.
Old Apr 26, 2010 | 01:23 PM
Huey52's Avatar
Registered Zoom Zoomer
Just as amazing as how many '04 and early '05 original owners were unaware of this free [at the time] starter/battery upgrade, is how many people re-post the same old thing without even trying to search.
Old Nov 11, 2010 | 01:23 PM
andreasy's Avatar
Does anyone know any EU shop to order the updated starter? For some reason, US shops are extremely expensive on international sales. I get up to $200 for delivery. Is the starter that big and heavy?
Old Nov 11, 2010 | 02:03 PM
Rudolph's Avatar
EU
About 1/2-3/4 year ago on e-bay USA there suddenly was a limited stock (turned out to be 30 units) of OEM updated starters (2 kW) available at USD 175,- soon USD 185,-..........for MT RX-8's.........
see:
https://www.rx8club.com/showthread.p...ht=starter+175
I ordered immediately one; shipping cost to the Netherlands were only USD 58,50 (USPS); it is a small box.........
The starter costed me a total (incl Customs and BTW=VAT) of Euro 217,-......
Weight of updated starter was total gross 10 Lbs&14 Ozs / approx. 3,5 kgs
After a couple of weeks all were sold of course.
Pity for you...
After that new OEM updated starters are rather rare available (especially in Europe incl. UK)........
At this moment I only know the next posibilities:
http://www.finishlineperformance.com...cat=338&page=3
from Germany for Euro 399,- (1x Anlasser (modifiziert- erhöhte Drehzahl) N3Z1-18-400A;.......... 399,- Euro incl. MwSt.)
http://www.schmidbauer.mazda-service...equest_uid=yes
and from UK; for a total of GBP 400,- incl. shipping and VAT:
http://www.mazdarotaryparts.com/brx-...r-b-1484-p.asp
Best regards, Ruud
Old Nov 11, 2010 | 05:11 PM
andreasy's Avatar
Smile
see:
Pity for you...
Best regards, Ruud
Thanks.
Old Nov 11, 2010 | 05:27 PM
andreasy's Avatar
I found one at: http://www.trademotion.com/partlocat...layCatalogid=0
for $336.14 and around $50 delivery. However, the model seems to be N3H1 plain and they say it is the updated one and that Mazda returned to the standard code but all starters are updated.
Does anyone else know this?
Old Nov 11, 2010 | 06:18 PM
wcs's Avatar
wcs
no agenda
What's worse is the amount of people complaining about hard starts on models newer than 04-05
BTW I have an 05 with the original starter and only occasionally have hot (hard) start issues, however I've got a ******* boat load of other mods that could be causing this.....
Darkbrew has an 04 and has zero hard start issues.
Hopefully the hard start issue is the exception not the norm in those manufactured years.... just say'n
Old Nov 12, 2010 | 03:06 AM
Rudolph's Avatar
EU
A) see:
1)
N3H1-18-400R-0A = this is the updated starter that Mazda now replaces, it was originally installed on the 2009-10 rx8's. And this same starter was approved for all models 2004-10
2)
N3H1 = Original (04' & '05 models)
N3H1 A = Upgraded
N3Z1 = Updated (standard with '06 and newer models)
B) From the search in this suppliers-site it is clear that it will be the upgraded/-dated N3H118400R0A:
Search by OEM Part Number: (Select Make) Honda Mazda Nissan Multi-Part Search Mechanical Catalog Item Number MSRP Core Price Price N3H118400R0A $334.87 $75.00 $261.14 Starter
Starter, rx-8 - manual trans 2004 - 2008
Add to Cart
Contact Us Collision Catalog Item Number MSRP Core Price Price N3H118400R0A $334.87 $75.00 $261.14 Electrical - Starter - Starter - Manual trans
Manual trans 2004 - 2008
Add to Cart
Contact Us OEM Catalog Item Number MSRP Core Price Price N3H118400R0A $334.87 $75.00 $261.14
STARTER, REMAN
Add to Cart
Contact Us
By the way...........in which country do you live?
Regards, Ruud
Old Nov 12, 2010 | 05:49 AM
andreasy's Avatar
A) see:
1)
2)
N3H1 A = Upgraded
Add to Cart
Add to Cart
STARTER, REMAN
Add to Cart
Contact Us
Regards, Ruud
Thanks.
I have already read this thread but I wanted to confirm.
About price now, the core is added on my price so instead of getting $261.14, I get:
$334.87 $261.14 $75.00 = $336.14
I live in Cyprus. Maybe that's the reason for adding me that value instead of getting the discounted one?
Old Nov 12, 2010 | 06:38 AM
Rudolph's Avatar
"I live in Cyprus. Maybe that's the reason for adding me that value instead of getting the discounted one?"
I live in the Netherlands and this higher price also counts for me, however on brake discs etc the discount is applied.
Old Nov 12, 2010 | 07:58 AM
Mazmart's Avatar
A) see:
1)
2)
N3H1 A = Upgraded
Add to Cart
Add to Cart
STARTER, REMAN
Add to Cart
Contact Us
Regards, Ruud
The 09 version is N3R3-18-400 and costs even more. The N3Z1 is the latest version factory new one whereas the N3H1-18-400R0A is a remanufactured unit.
I hope that helps.
Paul.
Old Nov 12, 2010 | 08:45 AM
Rx8mommie's Avatar
My car is a 2010 and it has a hard time starting time to time.Yesterday at the dealer I mentioned it and they said you have to tac it up to 5-6g rpms then immed.turn the key off,I posted about this yesterday..
Old Nov 12, 2010 | 08:51 AM
RIWWP's Avatar
Mildly curious how reving to 5-6k RPM, or any RPM for that matter, affects your next start (other than removing excess fuel if you are shutting off while cold)
Whomever told you that at the dealer is clearly not thinking it through, or talking from bad information.
Old Nov 12, 2010 | 08:54 AM
Rudolph's Avatar
Thanks Paul,
on behalf of andreasy............
Regards, Ruud
Old Nov 12, 2010 | 09:17 AM
andreasy's Avatar
And thanks from me to all of you. You have been very helpful.
BTW:
I finally clarified what the Core Price of $75 from trademotion is. You pay the full price and they return you $75 if you return to them your old starter.
Old Nov 12, 2010 | 09:32 AM
andreasy's Avatar
Is it a good idea to buy the remanufactured starter? Is it safe or are we playing with our luck if you think that it is a used part that might fail in a few months?
Old Nov 12, 2010 | 10:13 AM
Rudolph's Avatar
I have seen that Mazmart can supply the right / new one for USD 395,- (I assume they can ship to Europe).........
No returns, no 2nd shipping costs............
Make it youself easy; take a decision............
You only live once.........
Good luck,
Ruud
Old Nov 12, 2010 | 11:09 AM
Mazmart's Avatar
In 09 and later it is MUCH harder to fuel flood. I recommend all RX8 owners making sure that they have a FULLY charged high CCA battery.
Can you describe what you mean by "A hard time starting"?
Paul.
Old Nov 12, 2010 | 12:34 PM
andreasy's Avatar
Good luck,
Ruud
Yeah they do, but they want $80 on shipping for such a small package. I bought a guitar and I paid less.
Old Nov 12, 2010 | 12:59 PM
oltmann's Avatar
Have you checked with this dude?
http://blackhaloracing.com/products-...starter-motor/
Old Nov 12, 2010 | 03:39 PM
andreasy's Avatar
Originally Posted by oltmann
Great. I thought he didn't have this. I didn't search enough there and I am expecting an order from him already. I will try to see if I can make it before he ships my other order.
Thanks for the info.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
