My Typhoon installed myself w/ pics
Old Jan 27, 2004 | 10:15 PM
ATL RX-8's Avatar
Well, I just finished installing my K&N Typhoon. I'm not as mechanically-inclined as many of you, so it took me over an hour, but I'm satisfied. I have some beef with their installation instructions, but I made it through it. I was too tired to drive it around the block so I can't comment on sound or performance, but take a look at my pics and tell me what you think.
One odd thing I saw was the black plastic tip thingie on the vacuum switch. It has a Mitsubishi logo on it. :p
ATL RX-8's Avatar
Front pic
Old Jan 27, 2004 | 10:16 PM
ATL RX-8's Avatar
Side view
Old Jan 27, 2004 | 10:22 PM
bureau13's Avatar
Weren't they supposed to start offering a cover/heat shield for this? Is that available yet?
jds
Old Jan 27, 2004 | 10:34 PM
Jeff_pap31s's Avatar
Looks nice,but I think that filter looks a little big. How is the "butt-dyno"?
Old Jan 27, 2004 | 11:03 PM
rotarygod's Avatar
You can never have a filter that is too big.
Old Jan 27, 2004 | 11:44 PM
Japan8's Avatar
Int'l Man of Mystery
Rotarygod... isn't that beer or...
Old Jan 28, 2004 | 12:22 AM
rotarygod's Avatar
It applies to beer too!
Old Jan 28, 2004 | 02:11 AM
Speedy's Rx`8's Avatar
hey the pictures i cant see ...
Old Jan 28, 2004 | 02:38 AM
hey rotarygod..do you have any experience with HKS Foam hypermax foam filters??i heard they have much better air flow but get dirty much faster...do you think it owuld make much more of a difference?i know on piston engines they make a small difference compaired to your traditional k&n type filter..
Old Jan 28, 2004 | 08:07 AM
JimW's Avatar
Damn Right! theres never to much of a good thing. That K&N filter, if it would only hold beer! aaahhhh!
Old Jan 28, 2004 | 08:24 AM
ATL RX-8's Avatar
It's hard to hotrod to work in Atlanta traffic. The butt dyno didn't report much unfortunately, but when I hit 6000 RPM's, the engine is screaming. You can really hear the difference. I like the sound, which is mostly my reason for getting it.
bureau13, I recall seeing someone with a heat sheild installed, but I can't find it on the K&N site, so it may have been custom. I'll have to search the forums too.
Old Jan 28, 2004 | 03:08 PM
rotarygod's Avatar
You do not want one of those! There is an air filter test on the a Supra website somewhere that shows comparisons between different types of air filters based on how well they flow and how well they filter. The tests were run on a bench so these weren't guesses. The results are kind of scary. The HKS foam filter not only flows less than the best performing filter in the test but it also filters the worst out of the test group. The foam filters in general did really poorly whether they were oiled or not. The K&N filters did quite well and I believe came in 2nd. I forget what type of filter did the best but the winner not only flowed the best but also flowed the most which was very interesting. The K&N did very well against the competition and I have personally used their filters for a long time in other cars. You have to understand that higher horsepower cars show greater gains from a filter than lower power cars. 10% more flow on a 350 hp engine is more than a 10% gain on a 200 hp engine. This is why Hondas don't get any faster when a typical filter kit is installed. They get louder which translates as faster to the brain. There are ways to make them work though.
What does make a difference is the length of the tube that the filter is on and where the filter is located. I'm willing to bet that the long vs short RE intakes have different powerbands and not only because of "ram air". Ram air doesn't work the way everyone thinks it does. On my little Honda Civic that I use as a daily driver, I experimented with different lengths of intake tubes to arrive at a power boost where I needed it, on the low end. When I experimented with a short tube like most of the ricers use I found that power seemed to go down. I fabbed up a 3" pipe and ran it down to below the car and placed it directly in the airstream. The growl was much deeper and the power seemed to improve on the low end where I wanted it. This is verified since my original gas mileage in that car was about 28/32 before the mod. After it became around 32/35. Gain where I wanted it. The savings in gas alone paid for this. For a mod to be feelable it typically has to add about 10% more power there. If I could get a verifiable feelable gain on a little 127 hp Civic through a little experimentation, imagine what is possible on a 238 hp car, or a 350 hp car with a little effort. It is sure more than 6 or 7 hp. I'm not saying I added 12+ hp to my Civic but rather about 10% at the gain area. I suspect overall top end power (if you can call it that!) didn't change much if any. What I did accomplish is to get a better average across the board.
The whole point of this is to show that the intake design has a bigger affect than the filter. If a filter can flow well enough to supply the engine with its needs, then changing to a different filter will not do any better. Someone needs to redesign the factory type of box to use a bigger filter that still has a couple of different tuned passages for intake air. The total area just needs to be worked on a little since the factory intake area is smaller than the throttlebody. This is why aftermarket intakes are only giving a few more hp to the RX-8. It is because of flow. They have lost the tuning benefit though. Figure out both (which isn't difficult) and you'll have the best intake around.
Old Jan 28, 2004 | 04:01 PM
fredinlou's Avatar
i am also interested in getting the typhoon but only if i can buy a heat shield that is compatible with it anyone know where????
Old Jan 28, 2004 | 04:39 PM
Speed Racer's Avatar
Certified track junky!!!
There is a heat shield in the works but it won't be released until mid-February.
Old Jan 28, 2004 | 06:40 PM
JimW's Avatar
Anyone try a cold air intake or and extension for the typhoon that can go to the grill area of the car? is there enough room to work around the radiator? At the least getting cooler air would help.
Old Jan 28, 2004 | 11:08 PM
ATL RX-8's Avatar
JimW,
Someone has done this and posted a picture here somewhere. You could see the tip of the filter poking out behind the grill. A search may find it, but it was a while ago when I saw it.
Old Jan 30, 2004 | 08:48 AM
XeRo's Avatar
Normality is Obscene
NO...there is not a heat shield in development at K&N they have no plans for one...if you want proof i'll go diggin; through my .pst and find the email from them...
**NVRMIND***
with all the BS and skepticism on this board i went ahead and dug it out..
__________________________________________________ _
Charles,
The Typhoon systems do not come with heat shields and there are no plans to change them. The Typhoon system is designed to improve the under hood appearance of your car while still producing a performance intake for your car.
Thanks for writing
Fred
Old Jan 30, 2004 | 09:59 AM
310Guy's Avatar
4AT poor mileage king
LOL !!!
Old Jan 30, 2004 | 10:02 AM
zerobanger's Avatar
adkdai8e dkadloi98
so you cant put the stock lid back on with the typhoon inside the box?
Old Jan 30, 2004 | 10:11 AM
RaceBannon's Avatar
there is a heat shield out. It's nice looking and not hard to put in. Do a search on google for : RX8. Search through for a whil and you'll see a titanium rx8 with a silver box where your current filter/intake box is. Click on it and the site will come up- i forget the name of it, but it looks well thought out.
Old Jan 30, 2004 | 10:14 AM
RaceBannon's Avatar
I have a question-- I just ordered a K & N filter (33-2284) and i was wondering, am i going to have to reset my computer and dsc when i install it?
Old Jan 30, 2004 | 10:24 AM
jerzeydevil's Avatar
With the factory airbox, isn't their a second opening in the box that only opens up after like 6500 RPM? If so, this mod removes that....what are the remifications of this?
I guess to put it another way, the secondary port in the air-box opens up to allow more air at higher RPMs.....is their something in the intake design that doesn't want more air at lower RPMs? And if so...what does removing it do to lower RPM performance/reliability?
Old Jan 30, 2004 | 11:03 AM
There are two intakes hidden behind the front bumper and the stay in place even with the K&N installed. The longer of the two intakes is tuned for better low end response and the shorter one called the "fresh air duct" opens at 5.5k RPMs to help out with the higher revs.
Old Jan 30, 2004 | 11:07 AM
RaceBannon's Avatar
Here is that site that has the air box mod:
http://www.rotaryextreme.com/rx8intakeinstall.html
