Anyone have the PCM code list?
Old Jan 27, 2004 | 08:45 PM
khoney's Avatar
FX8TED on my RX-8
I could've sworn I saw a PCM code list posted somewhere on the forum, but I've been searching for an hour to no avail. Was I hallucinating? Can someone direct me to the thread (if there is one)? And if there is one, it NEEDS TO BE A STICKY!!!!
Old Jan 27, 2004 | 11:06 PM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
Hmm iunno why u need the codes anyways
Old Jan 28, 2004 | 12:46 AM
Superfan's Avatar
Member
No list.. You can't pull code from the PCM via the diagnostic loop & CEL like the 2&3rd gen RX-7.
Old Jan 28, 2004 | 11:18 AM
SnyderMazz's Avatar
That would be a long list for all of those codes - there are a couple of hundred codes specific just to the RX8, plus the couple of hundred just in general. I know there are some websites out there that will tell you the basic codes like the P0300's, 400's, and so on. I would be impressed if someone took the time to write down all of the codes and posted them though. Your look at I would say at least 500+ codes
Old Jan 28, 2004 | 11:34 AM
six_shooter's Avatar
The RX-8 is ODB II compliant, so just look up the ODB II codes.
Old Jan 28, 2004 | 11:07 PM
legokcen's Avatar
The Turkish Delight
Here is a link to the codes I just found. I saw several on my web search.
http://au.geocities.com/ozbrick850/obd2codes.html#obd-2
Old Jan 28, 2004 | 11:38 PM
RX-GR8's Avatar
good job
Old Jan 30, 2004 | 06:24 PM
khoney's Avatar
FX8TED on my RX-8
Thanks - I didn't know there were standard codes. Now if I only knew what causes them :D
Old Jan 30, 2004 | 07:31 PM
he's right though. someone here mentioned in a post in fall or early winter that you could put the car in "diagnostic mode" and get codes by watching a dash light blink or something. wait a moment and i'll search.........
Old Jan 30, 2004 | 07:39 PM
here ya go. it turns out my memory isn't that bad after all, but it's probably not what you thought.
thread from august
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
ErwinN
Sep 23, 2015 09:29 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
carid
Vendor Classifieds
Sep 10, 2015 09:26 AM
