RX-7.com exhaust
Old Jan 26, 2004 | 05:20 PM
s13lover's Avatar
RX-7.com exhaust
I know this has been out for a while but I don't remember seeing any threads about it. It sounds good and is dyno'd at 21hp.
http://www.rx7.com/RPGReddyRX8exhaust/index.html
Old Jan 26, 2004 | 05:24 PM
donald121's Avatar
I think the 21 gain is with the midpipe. I have ordered my GReddy from my friend. I should get it at the end of the January. :D
Old Jan 26, 2004 | 09:32 PM
RX8on19s's Avatar
FYI,
Don't buy their O2 Simulator.....It does not work and the quality is very poor. Buy the 02 Sim from Casper Electronics. You will need this if you get the testpipe.
Old Jan 26, 2004 | 11:29 PM
Jeff_pap31s's Avatar
How do you know that it does not work? Did you try it?
Old Jan 27, 2004 | 01:10 AM
but why do you need it for the testpipe?? does it just turn the check light on?
Old Jan 27, 2004 | 08:32 PM
RX8on19s's Avatar
Jeff,
Absolutely, I tried it and it did not work. I had to buy the Casper Electronics 02 Simulator and it worked like a champ. The one they sell works on some other cars, but not on RX-8’s due to its advance computerized system. After buying the product from them for 29.00, I found out that you can buy it from the manufacture direct for 20.00. The quality of the product is extremely poor. The Casper Electronics includes a solid protective housing which the one from RX-7.com does not. This is necessary to protect the delicate circuit inside. If want I can post a picture so you can see.
XDEEDUBBX,
I testpipe is great for those individuals how love to drive the RX-8 at very high RPM’s because it improves the exhaust flow. There is not point in putting on an exhaust if system if you do not increase the flow through the catalytic converter. Instead of buying a high flow catalytic (which still has a bit of restriction) you go with a testpipe.
Old Jan 28, 2004 | 01:17 PM
graceflow's Avatar
Question
OK so I am new, but aren't testpipes against the law to have?
Old Jan 28, 2004 | 06:36 PM
N20SA22C's Avatar
so is ripping the tag off your mattress but they havn't hunted me down yet! I have done it in CA of all states for years, but yes its not legal. I had a friend who beat his cat out and welded a straight pipe through it so it retained the stock look. just an idea
Old Jan 28, 2004 | 07:03 PM
RX8on19s's Avatar
N20SA22C,
Great analogy.....
Old Jan 29, 2004 | 12:23 AM
Rx8Freehk's Avatar
Special Agent Member
Originally posted by RX8on19s
FYI,
Ya there ya go, you guys go ahead and listen to someone that had one bad experence.... Ive had Rotary Performance's O2 Simulator for about 5 months now and have had Zero Problems, Yes when they first started selling them there were 30 of em that were bad, this was told to them by the manufacturer. Tell them that your went bad and guess what..... They give you a new one.. WOW. Ive been dealing with RP online for about 6 years, a 79, 91 and 04 rotary , and have not one complaint.
Old Jan 29, 2004 | 02:09 AM
[QUOTE]Originally posted by RX8on19s
[B]Jeff,
That would be cool to post a picture so I can see. Do you have the midpipe from RX7.com? Is it too loud? Can you feel a performance gain? Can you tell me where to get the Casper 02 Sim? Much appreciated man!
:D
Jeff
Old Jan 31, 2004 | 02:18 AM
Rx8Freehk's Avatar
.............. I stand corrected.... mine failed today casper it is
Old Jan 31, 2004 | 02:19 AM
Rx8Freehk's Avatar
sooooo ahhhh rx8on19s....... where did ya get the casper? part # please
Old Jan 31, 2004 | 02:29 AM
What happens when it fails?
Old Jan 31, 2004 | 10:23 AM
Rx8Freehk's Avatar
engine light comes on.... replace cat and old sensor... light went off
Old Jan 31, 2004 | 11:13 AM
RX8on19s's Avatar
Here is the info you guys requested.
http://www.casperselectronics.com
Checkout out the pictures of the two units. You be the judge....
Old Jan 31, 2004 | 11:16 AM
RX8on19s's Avatar
Casper Unit.....This one worked for me
Old Jan 31, 2004 | 11:17 AM
RX8on19s's Avatar
Here's the RX-7.com unit.....This one DID not work!!!!
Old Jan 31, 2004 | 11:30 AM
RX8on19s's Avatar
Rx8Freehk,
If your comment below is true, then that means they lied to me. When I installed the unit & it failed, I emailed them to report the issue. They responed back by saying they were not aware of any isssues & all of them have worked. Thats not cool.......
(((" Ive had Rotary Performance's O2 Simulator for about 5 months now and have had Zero Problems, Yes when they first started selling them there were 30 of em that were bad, this was told to them by the manufacturer.")))
Old Jan 31, 2004 | 01:29 PM
Rx8Freehk's Avatar
Ohhhhhh time to get Rocky on this here forum to answer some questions........ stay tuned
Old Jan 31, 2004 | 02:09 PM
RX8on19s's Avatar
Rx8Freehk,
I see you have the Greddy SP. Do you have a sound clip? I’m thinking of getting it but I’m worried it may be too loud. I like the way the Greddy sounds with a cat, but I have not heard it without one.
Please let me know.....Thanks
Old Jan 31, 2004 | 02:28 PM
Rx8Freehk's Avatar
well actually.. the clip at Rx7.com is with the midpipe, and sounds MEAN not too loud, thanks to the pre-silencer
Here it is
Old Jan 31, 2004 | 02:30 PM
Rx8Freehk's Avatar
Oh ya could you by anychance hook up a part # for the o2 simulator? I cant seen to find ours on there website
-Thanks man
Old Jan 31, 2004 | 03:40 PM
Thanks for the pics man. I'll def have to keep this in mind when I order it eventually. I'll have to have a chat with Rocky.
Old Jan 31, 2004 | 07:55 PM
zerohour's Avatar
Sorry to be a knucklehead here guys but can I ask if the RX7.com Midpipe has a silencer how is this being achieved? It it simply a another restriction on the flow of the midpipe. Kind of like how they put a tiny hole at the end of a 4 inch tip lol. Im confused, how does this work? What is the difference between this and a resonator? Will the silencer effectively give me more low to midrange torque at the expense of high end power?
Im sorry ive never gotten a mid pipe before i usualy keep my cats on but if im gonna get canzoomers stage 2 Ill have to do it right.
Any help would be appreciated!
