My Baby Died in the Cold
Old Jan 26, 2004 | 04:12 PM
arcnphat's Avatar
Yes boyz and girls my four month old winning blue 8 died as a result of that crappy battery and the cold we had here in new york. I had to have the car towed and when they looked at it they found no spark and the spark plug coated in fuel. The car did start for about six seconds and would not fire again. Any suggestions would be greatly accepted to avoid this from happening.
Old Jan 26, 2004 | 07:21 PM
Gord96BRG's Avatar
Were you still able to turn over the engine? Did the battery run dead trying to start it repeatedly with extended cranking?
It doesn't sound like it died from the cold, it sounds like it wouldn't start because it was flooded.
Regards,
Gordon
Old Jan 26, 2004 | 08:05 PM
mdmaclean's Avatar
How cold was it? I have had mine start in -29C, which is about -20F.
Did it crank over?
Old Jan 26, 2004 | 08:16 PM
racerdave's Avatar
F125er/Future RX-8er
Have the dealer install the alternate (hot) plugs while he's at it.
But if the Canadians haven't had much trouble... I don't see why New York should be much different.
Sounds like a flood.
Old Jan 26, 2004 | 10:27 PM
arcnphat's Avatar
I guess it did die from being flooded but I am so good with the car and the wierd thing is that it did start for a few seconds and then stalled. They did change the plugs but now it start kinda sluggishly starter sound and battery wise. thanks guys for all your insight.
Old Jan 27, 2004 | 10:27 AM
RotaryZZ's Avatar
I've talked with the service manager at one of the dealership over the weekend. He think Mazda may replace the 8 with a stronger battery (more amp) for owners living in the cold belt. He admit the battery is kind of weak too.
Old Jan 27, 2004 | 08:48 PM
CERAMICSEAL's Avatar
One more time, repeat after me: BATTERY
The main cause of the flooding. Some people's batteries are more fully charged than others, hence some people don't have the problem, but it's most common in cold weather (when they are most affected).
As mentioned by RotaryZZ the cold cranking amps of the 8 is pathetic.
Old Jan 27, 2004 | 11:05 PM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
So what would happen if you put that battery "optima" (i think the cool looking battery) or is it the same thing
Old Jan 28, 2004 | 05:55 AM
rx8cited's Avatar
Do the Canadian cars come with a different battery model than the US cars?
Old Jan 28, 2004 | 10:52 PM
Icanrel-8's Avatar
Sorry about your car, but um, could you rename this thread? It creeped me out at first.
Old Jan 29, 2004 | 08:13 AM
rx8cited's Avatar
Yep, page 45 of the Owners's Manual has specs listed:
Manual transmission - models:12V-40AH/5HR
12V-52AH/5HR*1
Automatic transmission - models: 12V-48AH/5HR
12V-52AH/5HR*1
*1Cold areas
Not sure why they don't list CA and CCA or battery group size info.
Sato Tatsuya
Oct 5, 2015 03:09 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Danield97
Sep 30, 2015 05:59 PM
Jb4ker96
Sep 27, 2015 10:06 PM
