rotary fx led interior question?
Old Mar 23, 2010 | 11:39 PM
calej729's Avatar
NJ rotary fx led interior question?
does the footwell kit sold on this site bring 4 tubes for both the front and under driver/passenger seat? if not can you buy the same kit to be used for the driver/passenger seat?
Old Mar 23, 2010 | 11:40 PM
WTBRotary!'s Avatar
Drummond Built
no they are a 9 LED bulb for each footwell
Old Mar 23, 2010 | 11:56 PM
calej729's Avatar
so to do the four sides the fronts and seats would require 4 kits?
Old Mar 23, 2010 | 11:59 PM
WTBRotary!'s Avatar
Drummond Built
What? No the kit Rotary FX sells give you the footwell lights for both sides... on their website they will tell you what is included in the kit...
Old Mar 24, 2010 | 12:03 AM
RX8sd's Avatar
no it's one kit....one LED bulb for each side and honestly it isn't worth the money in my opinon. I bought one like a month ago. Not happy with it what so ever. I ended up just using the bulbs for the doors instead ha ha. The instructions were kinda shitty too. You might have better luck with it though....just my two cents.
calej729's Avatar
ohh aight and are they bright? and does it include the turn on and off switch sorry for all the questions and thank you for the help
Old Mar 24, 2010 | 12:09 AM
WTBRotary!'s Avatar
Drummond Built
Brightness depends on color, I had blue and they were bright but my friend had red and they werent as bright... the wires you wire it into are for the... **** i just blanked ... um the switch that turns on the lights when you open, close or unlock your door, I forgot what its called again...
Old Mar 24, 2010 | 12:11 AM
calej729's Avatar
ok yea i want red ones but i want it so that when i drive i can have led/neon lights where can i find that?
Old Mar 24, 2010 | 12:14 AM
WTBRotary!'s Avatar
Drummond Built
you can wire it to a different harness where they turn on when your headlights are on... or you can wire it to a switch to turn it on and off...
Old Mar 24, 2010 | 12:15 AM
calej729's Avatar
if this kit isnt good any idea where i can get the underglow kinda kit and the middle dome lights to red led?
Old Mar 24, 2010 | 12:17 AM
calej729's Avatar
yea i want it so i can turn it on and off whenever is there any kind of harness or switch that i have to buy?
Old Mar 24, 2010 | 12:21 AM
WTBRotary!'s Avatar
Drummond Built
Search... I cant give you all the anwsers...
Old Mar 24, 2010 | 12:29 AM
calej729's Avatar
k tnx for the help
Mar 1, 2019 09:00 AM
BigMikeATL
May 26, 2016 12:31 AM
talonhart2
Aug 26, 2015 04:14 PM
Stubbs
Jul 28, 2015 09:23 PM
