How to clean dirty headlights?
Old Mar 19, 2010 | 05:16 PM
david_kim5's Avatar
my headlights are dirty, it has that build up of calcium or some sort inside.
it makes the plastic look kind of yellowish/green but the Hid lights are still bright white.
any solutions on how to clean it?
Old Mar 19, 2010 | 05:32 PM
Red_Fox's Avatar
Sauteed
build up is usually outside i use this and clears it up after a few uses theres also something about sand paper but i dont know much about that
Old Mar 19, 2010 | 05:34 PM
invasion08's Avatar
You can buy the 3M Headlight Lens Restoration System this kit is about 14 dollars, http://www.amazon.com/3M-Headlight-L...9037772&sr=8-1. Or for even better results call around to your local auto detailers and ask them if the use the 3M Headlight Lens Restoration System, this kit is around 500 dollars. I had Monster Coatings Inc restore my headlights and they look brand new.
Old Mar 19, 2010 | 05:37 PM
invasion08's Avatar
I have tried the Meguiars Headlight Restoration kit and it works but does not last long. Came across this thread as well https://www.rx8club.com/series-i-tech-garage-22/headlight-restoration-%2410-192974/
Old Mar 19, 2010 | 08:07 PM
JessiahC's Avatar
Nitrous Threadjacker
^ +1
Worked out great for me, looks so clean you could eat off it.
Old Mar 19, 2010 | 09:13 PM
david_kim5's Avatar
you guys are the best u guys know exactly what i need.
much appreciated
Old Mar 19, 2010 | 11:19 PM
JessiahC's Avatar
I can speak for most of the guys here in saying, "We're glad to help!" Now you can change your signiture!
Just don't hesistate to search first!
Old Apr 11, 2010 | 05:24 PM
MEGAREDS's Avatar
Goh Mifune
It's on the outside, duh!
Glass cleaner and elbow grease cleaned up the mess that I thought was on the inside of the headlights; thanks for setting me straight!
Old Jul 24, 2010 | 03:18 PM
Rotary-RX8's Avatar
Girls who drive stick FTW
I just ujsed the Meguiars Headlight Restoration kit. Yes it looked clean. But when i turned on my HIDs to really see how well it cleaned the lens, there was still little spots on the lens. Is that normal? Isnt it possible to make the lens 100% clear ? When i turned on my HIDS the speckles of w.e it is, were still there Help
Old Jul 24, 2010 | 03:59 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I had mine cleared (with clear coat) after having them cleaned. I used the 3M stuff on my Subie and it worked great for about 6 months. Now the haze is back. The clear protects the plastic from re-oxidizing.
Old Jul 24, 2010 | 04:45 PM
Rotary-RX8's Avatar
Did you use the Mequiars Headlight Restoration kit ? I just used it and when I turn on my HIDs, the little dots of haze are still there. Wtf am i doing wrong. I used the drill and used 3 coats of PlasticX on each headlight. Help
Old Jul 24, 2010 | 04:58 PM
Never L8's Avatar
Meguires also has a Clear PlastiX product. You use it just like wax on your car. It clears them up really nicely. Just like some other people have experienced, you will have to periodically re-apply the cleaner, but hey...it's quick, easy, and cheap. I have used it repeatedly without any complaints. It will last for over 6 months...at least mine did.
Old Jul 24, 2010 | 05:17 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yep, ya need to get them clean however you decide to do so and then use PlastiX every once in awhile. They key is obviously never let them get real bad in the first place.....as with everything.
Old Jul 24, 2010 | 08:19 PM
DocBeech's Avatar
I drive at Red Line.
if you mean by spots are you sure its not pitting? look at your windshield and tell me if you see the same tiny spots. If you do its pitting from sand and debris. Those you wont be able to get out without some serious sanding and or polishing which I dont recommend. After you clean them, step about 8 feet away from the car and take a look. If they look good from that distance than your fine, try not to over sweat it and just polish them until they look good from a couple feet away. They will never be pefect if your 6 inches away and they are years old, and again look at your windshield to see if you see the same pitting. If you do its really not something you can fix.
Old Jul 24, 2010 | 10:58 PM
invasion08's Avatar
For dirty headlights try orbitz
Old Jul 24, 2010 | 11:12 PM
Rotary-RX8's Avatar
Actually i do have sorta the same thing on my windshield too. But i can only see it when the sun hits it directly. Theyre little tiny clear spots. IS this a common thing ?
Old Jul 25, 2010 | 12:56 AM
DocBeech's Avatar
its called windshield pitting. and your headlights have the same damage. Its not exactly easy to repair so don't fret yourself over it and dont let it worry u.
step back over 5 feet and look at them, see if they look ok, if you polished em good enough youll be fine.
Old Jul 25, 2010 | 08:16 AM
Rotary-RX8's Avatar
Yea they look brand new from at least 3 feet back lol. Thanks for the info
Old Jul 30, 2010 | 05:42 PM
SEANMAC777's Avatar
Is it ALWAYS on the outside? I took mine to the only detail guy in town and he told me it was on the inside and no use worrying about it. (but he also seemed kind of like a d-bag.)
But it looks like ****. And my headlights are sealed good/no water in them so I wouldnt think it would build up inside.
Old Jul 31, 2010 | 01:43 AM
shadycrew31's Avatar
WENTGERMAN
+1 on the 3m kit.
While rebuilding my engine I got some parts cleaner on the headlight. Normal parts cleaner wouldn't be an issue but this was the stuff you need to wear gloves to handle. Anyways it ate into the plastic after I got some on the headlight. I also had some yellowing, scratches, pits, etc.
After about 2 hours and allot of patience I got my headlights done and they look brand new out of the box no scratches or anything. the kit comes with 4 500 grit pads 4 800 grit pads a gray pad (Its magical) and rubbing compound with a foam pad, it has a drill bit applicator thing.
Im tired point is it works. if yrou get sick of rubbing your headlights for hours to no avail buy the kit.
Old Jul 31, 2010 | 03:22 AM
DocBeech's Avatar
did you clear coat after all that work? just curious to see how long the 3m kit has lasted you.
Old Jul 31, 2010 | 03:25 AM
WENTGERMAN
I used 3m rubbing compound that came with it. that pretty much acts as a protective barrier. Its plastic so... yea I'm not gonna go to the trouble of clear coating. they say to hit it up with plastic polish here and there to keep it clean.
Old Aug 17, 2010 | 03:03 AM
bonestockrotary's Avatar
USAF certified tough guy
i took my 8 up to a car detailer. they did it for like thirty bucks. looks brand new
Old Aug 21, 2010 | 01:17 AM
boizart1's Avatar
1500 wet sand...just keep sanding until the water coming off looks like white foam (will be greenish while still dirty). To finish you gotta have wax and a waxing machine though. I did my own sanding and my pops waxed it for me...took about 10 minutes total and you will spend a couple of bucks on sandpaper...if you already have waxing materials.
Old Aug 21, 2010 | 01:21 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Meguiars PlastX
