Tire facts
Old Mar 15, 2010 | 10:44 PM
dwolson2's Avatar
Tire facts
Don't know as much about the RX8 as the Legacy GT(way too much time on that forum) but anyone that is good with tires and the 8 could make a FAQ like the one at Legacygt.com. I haven't found one like this yet.
http://legacygt.com/forums/showthrea...-and-4426.html
Going to add it to the first post:
Gen 1 04-08
Blolt pattern is 5 X 114.3
Factory offset for the 18" rim is +50 with 225/45R18 tires.
Lug nuts are
16 in. rims :
17 in. rims :
18 in. rims :
225/45R18 F/R Stock size
235/45R18 F/R OK
245/40R18 F/R OK
19 in. rims :
Gen 2 09+
Use these at your own risk!
dwolson2's Avatar
this is how they have theirs:
I finally compiled the most completed info I can come up with for wheel and tire fitment questions that everyone has. I mapped this entire post out so that you can pick a rim size you want and the rest will follow, including tire size.. I worked out this post so that you guys can decide on a tire size and it will point to you of what rim specs you need to fit onto the car.. as for brands and types of wheels and tires, well, that's a totally different thread on its own.
-GT's bolt pattern is 5x100mm, NOT 5x114.3. Only the 2005+ Impreza WRX STi is currently running 5x114.3mm. Stock GT wheel is 17"x7" +55mm (still need full verification if it's different from model years), but it's been confirmed for 05' rims on post #1522
-OBXT bolt pattern is 5x100mm with +48mm offset (weighing around 20.5 lbs per rim). OBXT wheel is 17"x7".
-2.5i and 3.0R models will need confirmation on stock rim sizes.
-Center bore must have to be 56mm or larger (if the bore is larger than 56mm, use hub centric rings to fit properly to your wheel's center bore, but not always necessary if you have wheels with conical lugnut seating, the wheel will eventually center itself, but that's your call of how you want to go about that).
-SpecB, OBXT, and 3.0Rs can use shorter tire sizes from the GT. But be sure to check and compare the load capacity of the tires. Try to use the same tire load capacities if you can within +/- 100 lbs. You can certainly always go over, but not under (as this requires for you to run higher tire pressures and this could cause more of an issue for tire wear).
-Lug nuts threading are 12mmx1.25mm. Open or Closed End lugs will depend on the mounting thickness of your rim, usually, closed ends (like the stock ones) are fine.
-Here we go, here are your choices for rim widths (regardless of it being 17", 18", 19" or 20" rims):
{offset in BOLD are the closest possible offset to OEM's scrub radius, you'll notice that once you go past 8" wide rims, you will run out of room on the inboard side to put/stuff any more of the wheel/tire to maintain the OEM scrub radius.. 8" and up will increase positive scrub radius}
6.5" (+34mm to +60mm offset, +55) *for 2.5i only
7.0" (+37mm to +57mm offset, +55)
7.5" (+40mm to +54mm offset, +55)
8.0" (+43mm to +51mm offset, +53)
8.5" (+45mm to +48mm offset, +45) *will need to roll the fenders if tires are wider than 255
9.0" (+43mm to +45mm offset, +43) *will need to roll the fenders if tires are wider than 255
9.5" (+38mm to +40mm offset, +38) *will need to roll the fenders if tires are wider than 255
and it also depends on what kind and size of tire you want to run as well (and that can get messy). But to be on the safe side, here is the tire widths you can put on each rim:
195mm = 6.5", 7" and 7.5"
205mm = 6.5", 7" and 7.5"
215mm = 6.5", 7", 7.5" and 8"
225mm = 7", 7.5", and 8"
235mm = 8", 8.5", and 9"
245mm = 8", 8.5", and 9"
255mm = 8.5", 9", and 9.5"
265mm = 8.5", 9", and 9.5"
275mm = 9" and 9.5"
285mm = 9" and 9.5"
Once you decide on the rim size, the tire width you want to run, here are your final tire choices. Note that not all tires are built the same way, so sometimes you'll find two different tire models with the same size (225/45/17), but one can fit on a 7" rim, while the other one will need a 7.5". You'll have to look around the manufacturers' specs on sectional width of the tire.. normally you want your rim width be no more than 1.5" less than the tire's sectional width. For example, if you have a 8" wide rim, your tire's sectional width shouldn't be more than 9.5" or you'll have to deal with the flex on the tire sidewalls. Most performance driving set ups are 1" difference (ie. a 8" wide rim with 9" wide tire). Below I listed for you by rim diameter of which I recommend running with some notes on each tire with notes to go along with them as well:
16 in. rims (for 2.5i, 2005-on) only:
195/60/16 (great for snow rally or snow use)
205/55/16 (OEM sizing which is also good for some non-tarmac surfaces)
215/55/16 (oversized for the rim protection, but very sloppy sidewall handling)
215/50/16 (wider footprint used for more daily driving without harsh gas consumption)
225/50/16 (great for autocrossing, still usable for daily driving all year round)
17 in. rims (for GTs 2005-on):
205/40/17 (only for SUPER FAST acceleration and torque; for autocrossing only, do not use for daily driving)
205/45/17 (only for FAST acceleration and torque; for autocrossing only , do not use for daily driving)
205/50/17 (good for snow rally)
215/45/17 (stock)
225/45/17 (good autocross performance tire size for gearing, more mph per gear)
235/40/17 (good autocross performance tire size for torque, more acceleration)
235/45/17 (tallest tire you could use under the GT due to possible suspension clearance issues, best used with an 8" wide wheel)
245/40/17 (good autocross performance tire size for traction, will need to have a flatter alignment to make use of the grip)
255/40/17 (maximum grip, good for track days, will need a 9" rim to make use of the contact patch and a good alignment as well).
18 in. rims (for GT 2005-on):
215/35/18 (only good for autocrossing use, do not use for daily driving)
225/35/18 (only good for autocrossing use, do not use for daily driving)
215/40/18 (uncommon tire size, close to OEM overall tire diameter, good for daily driving)
225/40/18 (typical sizing, most popular size, GREAT for daily driving)
235/40/18 (very large, but great for pot-hole city driving, may need fender rolling)
235/35/18 (rare size, but closest to OE tire sizing to keep the spedometer reading correctly)
245/35/18 (common autocross, performance size, very good for daily driving)
255/35/18 (very good daily driving size, even better on the track)
265/35/18 (very good daily driving use, but the car wont be able to use all 265mm of tread for the track)
275/30/18 (tallest tire you can mount without fender clearing issues on a 2" lowered car if you get the right offset)
285/30/18 (aka, the "STREETS OF DREAM" setup... the widest you can go.. this is the next tire size I am going for and a rim to match it)
18 in. rims (for Spec B.2006-on, 3.0Rs 2008-on):
225/40/18 (common tire to use and gives a better acceleration since it's 0.5" shorter)
235/40/18 (rare size to find, but near stock height for proper gearing)
245/40/18 (popular tire size for the larger cars)
19 in. rims (for GT 2005-on):
225/35/19 (common typical sizing for 19" for our cars)
235/35/19 (tallest tire you can mount without fender clearing issues on a 2" lowered car if you get the right offset)
245/30/19 (rare size, but also tallest tire you can mount without fender clearing issues on a 2" lowered car)
Use these at your own risk, but to my knowledge on a lowered car with a small-spring perch type coilover, it should work and ride fine. The most you'll probably have to do to the fenders is to just roll the lip of it in to give yourself another 5mm of clearance. I hope this helps.
Old Mar 15, 2010 | 10:56 PM
Chavy's Avatar
I did it for the lulz
you should research and make one
Old Mar 15, 2010 | 11:15 PM
make it and ill stick it- as long as its accurate and doesn't mention "hub-centric rings"
Old Mar 16, 2010 | 08:03 AM
dwolson2's Avatar
Lug nuts are
16 in. rims :
17 in. rims :
18 in. rims :
235/45R18 F/R OK
245/40R18 R OK
19 in. rims :
Old Mar 16, 2010 | 08:07 AM
dwolson2's Avatar
if anyone knows the factory offset(and Lugs) and offsets that will work, as well as tires sizes that work(and whether or not they need fender rolling) I will update the above post. ...Its a start, I don't have the time to do this on my own, 2 college classes and about 10 hours a day plus a wife and daughter keeps me pretty busy.
Old Mar 16, 2010 | 08:17 AM
Huey52's Avatar
Registered Zoom Zoomer
Factory offset for the 18" rim is +50 with 225x45 tires.
Factory Lugs are 5x114.3
The "aggressive offset" thread cites a number of differing types but concur it's not as nicely organized as you portray.
Old Mar 16, 2010 | 09:18 AM
2tone's Avatar
The RX-8 is missed
^oem is +48 or +50? i forget.
need to split into two sections, gen I and gen II. Gen I only had two wheel options, the 18x8 that Huey referenced, and horrible looking 16"s. not clue on the other specs fo the 16"s though. Gen II has 18"s and 19"s (on the R3). I don't think they offer 16's anymore, maybe 17's for the base model or is it all 18's now? a lot of people run 17"s, but they are all aftermarket, mazda doesn't offer a 17" for the rx-8 that I am aware of.
Old Mar 16, 2010 | 08:22 PM
bhop's Avatar
NO A/C :(
^, I think 50?
Old Mar 16, 2010 | 09:09 PM
dwolson2's Avatar
decided to put it to the first post
Old Apr 11, 2010 | 08:56 PM
RotaryP7's Avatar
Seriously.. FML..
Uh? You can't use 245/40/18 front tires?
Old Apr 11, 2010 | 09:01 PM
alnielsen's Avatar
245/40 18's are fine all round. I've known people that have used 255's and have heard of 265's being used. I think your gas mileage would take a dive if you did go that wide however.
Hunterkelley24
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
