Car wont crank over
Old Mar 15, 2010 | 12:04 AM
ntf1015's Avatar
TX Car wont crank over
So I bought my 04 RX8 middle of last year and when i bought it, it had a lot of aftermarket parts on it. Now as embarrassing as this is, I really dont know much about cars so I dont know what all hes done to it other than the obvious.
Car has a turbo, intake, exhaust, pulleys, intercooler, possibly headers, etc.
I started the car one night with no problems. Next morning I got up to go to work and it wouldnt start. It acts like its trying to start it just doesnt crank. It just makes the loud buzzing noise without the cranking. Someone please help!
Also, I have a problem where once the car is warmed up, if it's above 2k rpms and i push in the clutch it will stall out. I have no idea what could cause that. I've recently put new ngk spark plugs in, spark plug wires and bought a new battery.
Old Mar 15, 2010 | 01:07 PM
EDZRIDE's Avatar
2005 White GT
Sounds like the battery is dead. First off, clean all the connections and have the battery load tested and charged if needed. After you get it started , check the charging system, should be putting out 14.25 volts.
Old Mar 15, 2010 | 01:13 PM
xun4gvn4everx's Avatar
True love is blue x2
After the new battery it still won't crank? Did you replace the coils when you replaced everything else?
robd1337
Jul 31, 2015 09:35 PM
Obivious
Jul 29, 2015 05:57 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
netrovers
Jul 20, 2015 03:32 AM
