Rotor Housing Cut-Away with Different Spark Plugs
Old Feb 15, 2010 | 02:19 PM
Turblown's Avatar
Boostin'
Each photo has its description at the bottom. All these plugs seal, and do not protrude too far in. The Rx-7 plugs get the closest, and would be the best for power as long as you don't need anything colder than a 9 NGK heat range. The bur9egv are available much colder, 10/11 etc.
Attached Thumbnails Rotor Housing Cut-Away with Different Spark Plugs-different-plugs.jpg   Rotor Housing Cut-Away with Different Spark Plugs-stockrx-8plugt.jpg   Rotor Housing Cut-Away with Different Spark Plugs-rx-7-l.jpg   Rotor Housing Cut-Away with Different Spark Plugs-rx-7-t-b9egv-l.jpg   Rotor Housing Cut-Away with Different Spark Plugs-b9egv-t.jpg
Old Feb 15, 2010 | 02:26 PM
Mawnee's Avatar
I divide by zero
This should be good
MazdaManiac's Avatar
Hey! I recognize those housings! I'm glad they got to "live on" beyond their useful life.
Notice the problem/difference between pic 2 and pic 4?
Old Feb 15, 2010 | 03:32 PM
Turblown's Avatar
Boostin'
Yeah thanks for the housing
There is a big difference in spark plug reach, but the Rx-7 one still works. Its a tight fit, but there is room. This is the best pic I can get..
I am not real familiar with the board discussion on this, Dave just mentioned something about it yesterday and I got curious...
Attached Thumbnails Rotor Housing Cut-Away with Different Spark Plugs-rx-7plug-t.jpg
Old Feb 15, 2010 | 03:54 PM
Yeah. You cut the trailing plug port seat out.
Can you cut directly down into the seat without destroying it on the other housing?
Old Feb 15, 2010 | 06:51 PM
arghx7's Avatar
leading on bottom and trailing on top?
Old Feb 17, 2010 | 11:25 AM
09Factor's Avatar
Original Turbo 'd Auto !!
Hey, I recconize those plugs! The rusted crappy one is what was x-threaded at the dealer 2 years ago..
Good to see the cut-a-ways E
You are correct.
Old Nov 13, 2015 | 02:27 PM
logalinipoo's Avatar
Driving my unreliable rx8
bump for some neat pics
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
PotatoCannon
Sep 6, 2015 11:48 AM
Psychofox
Aug 20, 2015 04:48 AM
Obivious
Jul 29, 2015 05:57 PM
