Brace behind the backseats?
Old Jan 22, 2004 | 01:00 AM
manok_adobo's Avatar
Anybody know what will the effect be if the "bar or brace" behind the backseat is removed?
Old Jan 22, 2004 | 01:01 AM
brothervoodoo's Avatar
RainMan is Back
Structural integrity and protection in case of a rear end collision... very bad idea...
Old Jan 22, 2004 | 01:10 AM
Ah man! I guess my plan on puttin a pair of subs on that spot is out.
Thanks Brother!
Old Jan 22, 2004 | 01:12 AM
RainMan is Back
do a search on speaker boxes, some guy on here made a nice custom job in the back...
You know, after reading your post again, I don't think we are talking the same thing, what bar/brace are you taking about?
Old Jan 24, 2004 | 09:28 PM
that flat silver bar you see when you take off the rear seats.
Old Jan 25, 2004 | 06:57 AM
WHealy's Avatar
Mr. Blue Man
Like this? Taken from Flawless's web site.
Old Jan 25, 2004 | 05:08 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
I'm a little confused too- I have a black tubular bar that my spare tire mounts to, which I'm planning on removing when I build a sub box for the trunk... the bar I'm talking about is just for the spare tire and part of the optional spare tire kit, right? I'm assuming you're talking about something else for structural rigidity... I hope at least
-Sean
Old Jan 26, 2004 | 01:26 AM
Nubo's Avatar
Lubricious
you can find this in the press kit
Of course it's possible it may also have other structural purposes....
Old Jan 26, 2004 | 01:37 AM
RainMan is Back
G8rboy, that's the point i wanted to make clear. You can get rid of the spare tire tube bar. But I wouldn't remove the diagonal brace that Nubo is referring in his picture above.
The spare tire tube might actually have an unintentional benefit in stiffening the chassis. I saw some after market vendors selling something similar to help stiffen the car when taking extreme maneuvers.
Old Jan 26, 2004 | 08:25 AM
G8rboy's Avatar
Ahh... that must be behind the plastic paneling (from the inside of the trunk, you can't see the bracing). If the spare tire brace served double-duty as a shock-tower brace than I would consider designing my sub box around it... but since it doesn't, it's outtahere.
Thanks for clearing that up guys...
-Sean
Old Jan 26, 2004 | 09:45 AM
WHealy's Avatar
Mr. Blue Man
You can see the brace with the rear seats out. Very easy to remove. Here's a side shot with the rear sets removed where you can see the driver side cross beam.
Warrior777
Jun 24, 2019 04:47 PM
Rote8
Sep 22, 2015 03:43 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
