Rx8 only just running
Old Feb 1, 2010 | 09:56 AM
paulmorrall's Avatar
My 2004 RX8 with 50,000 miles on the clock is running like a dog and the sensor on the front part of the exhaust is glowing red hot, any ideas?
Old Feb 1, 2010 | 09:57 AM
JinDesu's Avatar
went back to srsly broke
glowing red hot..? clogged cat maybe?
Old Feb 1, 2010 | 10:00 AM
RIWWP's Avatar
Yup, your cat is blown. Get it to a dealer. It isn't healthy or wise to keep driving it that way. You are still under warranty on the cat, so it should be free.
Old Feb 1, 2010 | 10:15 AM
Renesis 8's Avatar
I had the same problem. Brought it into the dealership and ended up getting a new engine out of the deal as well as a new cat. All under warranty.
Old Feb 6, 2010 | 05:55 AM
Well ive taken the cat off the car and it is running just the same as before...like it is missing, not sure what to do now...any ideas
Old Feb 7, 2010 | 09:31 AM
RIWWP's Avatar
So you took the cat off, and ran it without a cat/midpipe/etc? And it still runs the same as before?
Doesn't really mesh with the glowing cat description you gave above. The cat only glows like that from excessive heat buildup that can't go anywhere but through the sidewall of the cat, and you don't get that level of heat if the exhaust is free flowing.
Old Feb 7, 2010 | 11:13 AM
JPotta's Avatar
Just take it in, unless you have mods done to it theres no reason to try to figure it out on your own.
Old Feb 8, 2010 | 12:52 AM
really,
how do you know that or see that?
what is the exhaust temp?
Old Feb 8, 2010 | 01:18 AM
Let's not forget that the first typical step is that the ignition coils become weak. Then the cat cooks itself. The OP may still be in the first stage but he should still get it to the dealer, ASAP.
that is so how it works in the tsbs.
F51
Aug 2, 2021 04:07 AM
akagc
Aug 11, 2015 07:07 PM
Bamaham
Jul 23, 2015 08:08 AM
RX7.9
Jul 20, 2015 12:01 PM
