engine doesn't want to rev past 6500rpm
Old Jan 26, 2010 | 04:33 PM
dieselsdad's Avatar
Got the BHR ignition kit in and installed it today. Definately fixed the dead coils issue. Car runs great on the street, pulls well, but on the dyno the motor doesn't want to pull over 6000-6500rpm. Fuel trims look good, spark looks good. We're thinking maybe the apv valves aren't wanting to open correctly?
The car is a 2005 with AEM intake, BHR ignition, brand new plugs, HKS single side exhaust.
Any ideas? We're here at the dyno looking for answers (time is not an issue so don't fret).
Old Jan 26, 2010 | 04:35 PM
bad cat?
The dead coil you mentioned could have prematurely killed your catalytic
Old Jan 26, 2010 | 04:39 PM
dieselsdad's Avatar
Thought about that. Am perplexed by it running well on the street. The rollers on the dyno are VERY heavy so it's possible. I figured the dead cat would be consistent with running on the street though.
Old Jan 26, 2010 | 05:14 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
The fact that it happens at 6500 may be a clue!
APV valve opens providing more air to the system at 6500rpms. It is possible that it isn't opening as it should and some ZoomZoom cleaner might fix it.
I know this is stupid but.................you know that the PCM won't let you go above 6500 until you are at proper temp right?
And............also kinda stupid in this case, but I read somewhere that "When the car is not in motion there is no extra air to come into the engine so the SSV doesn't open." I take this as meaning in neutral in your particular case, it won't do it either......but I'm sure you aren't in neutral at this time. Of course......it could be the CAT as Jorge points out!
Old Jan 26, 2010 | 05:34 PM
dieselsdad's Avatar
Jedi was right.........as always.
Dead cat. Spit pieces out when I pulled it off.
Racing Beat test pipe fixed that.
We'll see what dyno tuning does later throughout the week.
Old Jan 26, 2010 | 05:39 PM
glad I could help!
although, I don't imagine removing a RED HOT cat off a car that was just on a dyno was a whole lot of fun.
let us know how the dyno numbers come out. Are you tuning with the AP? is the car N/A or FI?
Old Jan 26, 2010 | 06:24 PM
Poor CAT...
Rest in peace.
Old Jan 26, 2010 | 06:25 PM
Mazurfer's Avatar
Another cat uses up it's nine lives!
Old Jan 26, 2010 | 06:27 PM
RIWWP's Avatar
There has been alot of dead cats recently.
Who let the dogs out?
Old Jan 26, 2010 | 06:29 PM
Jon316G's Avatar
Grasshopper
Originally Posted by Mazurfer
SSV valve opens providing more air to the system at 6500rpms.
I know its irrelevant to this topic since the OP already figured-out the problem, but wanted to correct this.
Mazurfer- You're thinking of the APV which opens above 6250RPM. The SSV opens above 3250RPM.
OK... I'm done
Old Jan 26, 2010 | 06:37 PM
Mazurfer's Avatar
OK... I'm done
Oooooops! I fixed it.........sometimes I just type too fast or get distracted in the middle of something.
Old Jan 26, 2010 | 09:01 PM
dieselsdad's Avatar
Sorry, had a 2 hour drive home.
Like I said, the cat was the issue. It blew chunks all over the floor. Didn't get to make another dyno run tonight but did take the car around the block before getting it ready for tomm. Seat of the pants is WAY better.....and louder (I knew to expect this, I have several rotary racecars). It's harder to say how much EXTRA power I'm making catless as it was so sick before hand, dead coils and plugged cat. We'll see more numbers this week. I figure it will finish up tomm but maybe Thursday.
The car is NA and is being tuned on some superflow rollers (which weigh 4800 pounds by the way).
I'll keep you posted as we see more results.
Old Jan 26, 2010 | 09:13 PM
diesel: what engine management are you using to tune the car?
AccessPORT? E-manage? Hymee ProTuner?
Old Jan 26, 2010 | 09:45 PM
dieselsdad's Avatar
SuperFlow all-wheel dyno and some proprietery tuning software. Doesn't belong to me so sorry I don't have more info.
I do have an AP and AccessTuner but haven't used it yet as I wanted to fix the coil issue first. Then this oppottunity came along to be tuned so........
Old Jan 28, 2010 | 09:06 AM
dieselsdad's Avatar
The first pull after replacing the dead cat with a mid pipe made OVER 100 hp more. I ROCK. Too bad the pulls before the dead cat were so miserable.
We'll see how we fare over the next few days.
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
dbarber
Jul 25, 2015 01:34 PM
Bomba
Jul 22, 2015 06:46 AM
Belalnabi
Jul 17, 2015 07:48 PM
