Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
where do you change your oil here in dfw
Old Jan 19, 2004 | 11:38 AM
Vrimmick's Avatar
I was just wondering where do you guys change your oil and bring your mazda for service here in dallas/ fort worth. Any particular places that specialize in rotaries?
Old Jan 19, 2004 | 12:05 PM
DrKillJoY's Avatar
Rotary Performance in Garland - www.rx7.com
Old Jan 19, 2004 | 08:11 PM
allstate's Avatar
Contents Extremely Hot
I am using the dealership since it's free. Even after the free maintencance is up I will still probably use the dealership.
Old Jan 19, 2004 | 08:25 PM
Vrimmick's Avatar
Well I asked since it looks that technicians at the dealerships do not know much about rotary engines. They exchanged oil in mine with a semi-synthetic. After I asked why they said: well synth is better isn't it? They did not have any idea about the whole debate around the topic and that mazda first did not recommend using synt oils and than said it is ok to do so... I would still prefer to use dyno and deal with technicians that know what they're doing. By the way what dealership you use? It seems you're from the area.
Old Jan 19, 2004 | 10:02 PM
Sin's Avatar
Sin
KauffmanTire in Hurst...A friend has worked there for 5 yrs.
Old Jan 20, 2004 | 05:48 PM
Knerk's Avatar
Limecat De'Original!
Seach the tech threads on "do it yourself oil change"- Its very easy & you know the job is done right. no 10W-30 oil in your 8
Skyl3r
Dec 2, 2019 04:51 PM
Pelleilee
Sep 29, 2019 10:07 AM
uZu
Dec 30, 2015 12:35 PM
motohegg
Aug 23, 2015 08:14 AM
Modern2Strokez
Aug 16, 2015 01:07 AM
