lots of vibration
Old Jan 5, 2010 | 04:03 PM
Bigbacon's Avatar
2006 WB AT
lots of vibration
I noticed today that if the car is warmed up, I am in drive and I'm stopped I get a lot of vibration in the car, RPMs are steady just above the 750 mark.
If the car is warmed up, I am in park and the engine is on, I do not get this vibration and idle RPMs are at the same place.
Engine mounts or something else? it is a constant vibration until I start moving again.
Old Jan 5, 2010 | 05:20 PM
Jon316G's Avatar
Grasshopper
Possibly the engine mounts.
Have you received any misfire codes lately (especially if you drive above 7k RPM)?
This could point to an ignition problem (spark plugs, wires, and/or coils).
Old Jan 5, 2010 | 05:23 PM
Bigbacon's Avatar
2006 WB AT
no codes or funky lights on.
it all seems fine other wise, it accelerates no problem and I can push it the red line without it hesitating anywhere.
Old Jan 5, 2010 | 05:31 PM
invasion08's Avatar
I am going to say its your motor mounts. How many miles on you coils and spark plugs?
Old Jan 5, 2010 | 05:32 PM
Bigbacon's Avatar
2006 WB AT
coils/plus - no idea. car at 26000 miles on it. I got the car when it had 19000
Old Jan 5, 2010 | 05:35 PM
Jon316G's Avatar
Grasshopper
Its not unusual that the spark plugs and/or coils will cause this.
Might be best to change out the plugs... especially since you don't know when they were changed out (if ever).
Old Jan 5, 2010 | 05:43 PM
Bigbacon's Avatar
2006 WB AT
unfortunetly I cannot spend 300 dollars to get new plugs, coils, wires. just finished paying off christmas, vacation and all our bills. I also just spent like 800 dollars over the last 30 days on car stuff.
curious though, what is the average service cost to get engine mounts replaced? Is it easy to tell if they are broken? I am going to have the car on jacks this weekend.
Old Jan 5, 2010 | 07:29 PM
Jon316G's Avatar
Grasshopper
With the front wheels off you can see the mounts, inspect them for cracks.
The passenger side is more prone to failure since its by the exhaust manifold.
I would start with just new spark plugs. You can get all 4 for about $80 from various sources.
Old Jan 5, 2010 | 07:35 PM
Bigbacon's Avatar
2006 WB AT
thanks, I'll check out the mounts this weekend and see. I hope they are not broken because I suspect it's pricey to fix and not covered under any of the warranties.
Old Jan 5, 2010 | 07:41 PM
Jon316G's Avatar
Grasshopper
Here is a TSB for the motor mount issue:
http://www.finishlineperformance.com...01-09-2062.pdf
Old Jan 5, 2010 | 07:49 PM
Bigbacon's Avatar
2006 WB AT
can one partially clean the plugs with some kind of house hold tools/cleaners?
Old Jan 5, 2010 | 08:09 PM
Jon316G's Avatar
Grasshopper
Straight from NGK's website:
http://www.ngksparkplugs.com/tech_su...s.asp?mode=nml
Hunterkelley24
Jun 14, 2022 08:32 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
GranTouTou
Sep 30, 2015 06:11 AM
Jb4ker96
Sep 27, 2015 10:06 PM
