Battery/Alt
Old Dec 14, 2009 | 11:44 PM
TwistedHumor's Avatar
Battery/Alt
Greetings All.
New to the forum. Got a 04 Velicoty Red 8 a couple months ago.
I have a truck and a Harley so I don't drive the 8 as much as I should. The truck will eventually go.
I know the computer and securty system drains some juice, but about how many days can an 8 set before the battery is drained enough where it will not crank?
I am wondering if I have a battery or alternator problem.
I had a similar problem with the truck a while ago. The alternator was putting out 12V but is was not putting out the amps to give a good charge to the battery. If I let it sit for two days, it would not crank. Replaced the Alt and problem fixed
If I let the 8 sit for a week, it will not crank. I know they are meant to be drivin. Will do once I get rid of the truck.
Think I might have an Alt problem?
Old Dec 15, 2009 | 12:10 AM
Old Rotor's Avatar
Originally Posted by TwistedHumor
Greetings All.
I have gone on vacation for four weeks and mine started right up. Get a new Battery....
Old Dec 15, 2009 | 06:17 AM
Alt should be putting out 14.2-14.7 V Under load, that means with headlights and stuff on.
if its not, you have a problem.
Also, u need new,good battery.
Mine has been sitting outside for 4 weeks in cold weather (20-40), and it still works.
Old Dec 15, 2009 | 06:35 AM
Huey52's Avatar
Registered Zoom Zoomer
A week or two (or four) is no big deal. As already cited your battery and/or alternator may be weak.
Also make sure your trunk lid isn't ajar. The trunk light will drain the battery overnight!
Old Dec 15, 2009 | 11:54 AM
Nubo's Avatar
Lubricious
If you plan on leaving the car sit for long periods (more than a few days), get a deep-cycle battery. An ordinary battery will permanently lose some capacity each time it is deeply drained. If you're planning on parking for more than about 3 weeks, I'd look into a disconnect switch, or a "battery tender" to keep it charged. The allowable "dark current" for the RX-8 is 50 milliAmps. That doesn't sound like much, but in the course of 3 weeks, that amounts to 25 Amp-Hours. That's about half of a decent battery's storage capacity right there.
Old Dec 15, 2009 | 12:14 PM
Thanks for the replies all.
What is Dark Current? Is that the equivalent of the parasitic draw of the security/computer system? Never heard of the term.
I think I can open the battery, so I will check to water level. I know this is a factor in storage capacity.
I will also take it to AZ and see if they can put their tester on the alt.
Old Dec 15, 2009 | 03:26 PM
^^thats pretty much what it means.
Old Dec 15, 2009 | 03:36 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Not the literal definition, but "Dark Current" to our car = current drawn while in "off" mode.
Old Dec 15, 2009 | 07:04 PM
Computer ---- Even when you turn the power "off", the Power Supply still has a "standby" power going to the motherboard. that consumes power
Car ---- when your car is off, the computer/radio has to keep some of the settings, so it will ALWAYS use some power from the battery.
Old Dec 15, 2009 | 09:38 PM
Yeah, most peoples computers are that way. I kill the terminal strip that kills power to 2 computers, a monitor, modem, router and speakers. Most people don't realize that most electronics (anything with a remote control)sip a little juice when they are "off". Many other things, like the cell phone wall wart that is plugged in but not hooked up the phone, is consuming energy.
I just never heard of the term he used.
Old Dec 16, 2009 | 06:52 AM
Huey52's Avatar
Yeah and dark energy is also pushing the galaxies apart. It's everywhere.
Old Dec 16, 2009 | 07:18 AM
join the dark side ...
Old Dec 16, 2009 | 10:25 AM
Mazurfer's Avatar
Oh hell yes...........better run for your lives!
Old Dec 16, 2009 | 12:56 PM
Nubo's Avatar
Lubricious
It's okay, dark matter is pulling them back together.
Old Dec 16, 2009 | 01:15 PM
Huey52's Avatar
^ perhaps, but then there's the other 10 parallel universes, so ....
btw: In one of those realities the 16X has already been incorporated into a 2-seater, and I'm a very happy camper.
sumdeus
Apr 12, 2010 04:55 PM
Raevik
12
Mar 5, 2004 03:20 PM
