Using 93 octane in the mazda 3
Rating: Thread Rating: 4 votes, 5.00 average.
Old Dec 12, 2009 | 11:51 PM
PNTitBLK_07's Avatar
For some reason my GF go the idea that she needs to be using 93 octane gas in her mazda 3. she justifies this because...quote "its a nicer car and its a 6 cylinder so it needs better gas" now where did she get this wisdom..who knows probably some *** clown at her work, but however it happened she is convinced. i understand higher octane helps prevent detonation in my rx-8 but dosent do much in cars like hers. how do i explain it to her nicely? i should alsp probably tell her that her car is not a V-6
Old Dec 12, 2009 | 11:58 PM
05rex8's Avatar
sold the 8... :(
just dump her ***
Old Dec 13, 2009 | 12:18 AM
kersh4w's Avatar
Hit & Run Magnet
wow.
you need to pop her engine bay and explain she has 4 cylinder. once she sees you're right on that, she'll probably believe you that 87 is fine.
and mazda3s arent THAT nice. i mean, i'd drive one. but... its not a bmw.
Old Dec 13, 2009 | 12:28 AM
Lord ET's Avatar
Is that a bike rack?
Does she have the owner's manual...it probably says something along the lines of ...you don't need 93.
Old Dec 13, 2009 | 12:46 AM
my mazdaspeed3 2010 has not seen 93 oct yet..
explain she is pissing away money....
Old Dec 13, 2009 | 03:57 AM
kvndoom's Avatar
The Slow and the Serious
Really? Are you just running 87 in it? Any side effects?
OP, if she's more apt to listen to and believe friends/coworkers/strangers than you, you need to get out of that relationship. But in the meantime, prove to her that she's just wasting money and that the car isn't a V6 in the first place. But don't be surprised when she gets mad at you for showing her the truth instead of mad at the person who pulled the wool over her eyes.
Old Dec 13, 2009 | 04:08 AM
nvrfalter's Avatar
tonybob failpants
eh slightly better performance, slightly better gas mileage. let her do what she wants who cares?
Old Dec 13, 2009 | 08:48 AM
rotarykillz's Avatar
Rotary Freak
that's money she could be spending on him!!!
Old Dec 14, 2009 | 01:37 AM
rxwarrior's Avatar
You mean you didn't immediatly tell her she doesn't have a V6? What, are you afraid of her?
Old Dec 14, 2009 | 01:48 AM
Symbioticgenius's Avatar
You Dumbass!!!
[EMBED]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/2wwahLXf1n0&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/2wwahLXf1n0&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/EMBED]
This!
Old Dec 14, 2009 | 08:01 AM
DubbsLuvs8s's Avatar
Just don't confuse her with words like "High-Compression Engine" or "Car"
Then show her the user manual and run away.
Old Dec 14, 2009 | 08:07 AM
RIWWP's Avatar
When some women are confident that they are "right", nothing will sway them.
Figure this one out:
My mother in-law believes that "radar guns read the RPMs from an electronic transmitter on the engine, and that is why you downshift when you see a speed trap."
(where to begin......)
Old Dec 14, 2009 | 08:40 AM
tubingchamp's Avatar
What mawd bug?
Thank god my girlfriend isn't a dumb ***.
Old Dec 14, 2009 | 08:44 AM
maxxdamigz's Avatar
Baro Rex
... lots of people don't understand the meaning of octane rating.
Old Dec 14, 2009 | 09:25 AM
*sigh*
u know how long it took me to convince my father that his pos 95 Nissan Quest (sold last yr) doesnt need fuxking 93/Premium/SuperUnleaded kind of bs?
Funny thing is, my uncle "Believes" that, "the premium gas makes engine last longer" so he uses it. but his engine blew about 70K miles cuz he changes oil every 10K miles. LMAO.
Old Dec 14, 2009 | 09:50 AM
tza0001's Avatar
Dum Spiro Spero
That is a tough one! Go get her a gas certificate for Christmas)))
Old Dec 14, 2009 | 09:51 AM
alfy28's Avatar
Old Dec 14, 2009 | 12:14 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Oy...show her the manual and specs on the car. If she still insists on higher than 87, get her down to 89 at least.
Old Dec 15, 2009 | 03:37 AM
b'Eight''s Avatar
Tell her:
Higher octane 93 fuel actually burns SLOWER than 87 octane fuels. Since gasoline is a mixture of several different hydrocarbons that burn at different rates, the cheaper lower octane mixture will start burning faster but with a less concentrated BOOM.
With a higher octane fuel, the slower burning, albeit more concentrated combustion, allows for a more controlled explosion. This in itself doesn't necessarily yield more power or better economy by itself but it can be exploited to do so assuming you have a purpose built engine.
For a purpose built piston engine this means higher compression ratios starting at 10:1. Higher compressions means higher squish and hence more torque IF you can protect against early detonation which becomes a problem since higher cylinder pressures also mean more heat. This heat contributes to early detonation on cheap fuels due to a lower ignition temp. Therefore, the use of a higher octane fuel is required with it's slower burning but more concentrated combustion.
There are many other factors affecting an engines octane needs: Advanced spark timing, short stroke vs long strong relative to bore sizing, cam timing: lift, duration, overlap; small bore vs large bore, cylinder filling, swirl etc etc with compression ratio and ignition timing being the main factors.
Today, all cars come with a knock sensor that senses pre ignition signaling the computer to retard timing should you use a lower grade of fuel than your car requires. However, compression ratios are fixed but the actual volumetric efficiency (or amount of air the engine actually ingests) often improves at higher RPM's (depending upon tuning) or with the addition of a turbo. Just because your cylinder holds 100 cc's of air doesn't mean it ingests 100 cc's at every intake stroke. This volumetric efficiency changes over the RPM band.
So really it is really comes down to this: If you have the purpose built engine that requires a higher octane fuel, then your car may drive better than if you used a lower grade, cheaper fuel. But if your car doesn't need a higher octane fuel, aside from extra cleaning detergents, you might actually find worse gas mileage off.
For the RX-8, I find mid grade fuel to be the best for me here in PA.
Old Dec 15, 2009 | 06:34 AM
Originally Posted by b'Eight'
Tell her:
You forgot step 2:
Watch her face melt.
Old Dec 15, 2009 | 07:59 AM
Feras's Avatar
the Doctor
Tell her:
girls love it when you explain things like an engineer or a scientist.
Old Dec 15, 2009 | 08:35 AM
911SC's Avatar
Did you ask her where she got this "information"? Then go beat that person with a 93 octane soaked rag at the end of a stick. Lit of course.
Old Dec 16, 2009 | 03:19 AM
right now i am almost finished with the second tank of 89. well i will say so far.. the 87 and 89 the car has a lose of power, but no knock or bad stuff happening..
and i have to say this is a butt dyno you can trust.. but this is the speed3..
Old Dec 16, 2009 | 04:32 AM
thanks for the input everyone, sorry i havent checked on htis in awhile. another question though...this morining i started her car for her while she was getting ready, when i did this i turned on her rear window defroster and her cab lights dimmed a little...i am pretty sure it was normal. I mentioned it to her later and she now thinks there is a major problem with her car and it needs to be taken into the shop....it it really that big of a deal?
Old Dec 16, 2009 | 04:40 AM
Originally Posted by PNTitBLK_07
thanks for the input everyone, sorry i havent checked on htis in awhile. since posting I have, at different times, considered ALL options presented in your responses but have yet to folow through with any of them...maybe i will just do a combination of each. another question though...this morining i started her car for her while she was getting ready, when i did this i turned on her rear window defroster and her cab lights dimmed a little...i am pretty sure it was normal. I mentioned it to her later and she now thinks there is a major problem with her car and it needs to be taken into the shop....it it really that big of a deal?
let her take it to the dealer. then let her search for a mazda 3 forum.
stop being her bitch..
good god are you a moon around her??
good luck..
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
