AT Fuel Injectors
Old Dec 10, 2009 | 03:30 PM
volcomx31's Avatar
Silver Power
Question AT Fuel Injectors
I need to swap out my fuel injectors but I don't know which color/size I need for my Automatic 8. If anyone knows the correct size/color please let me know. Thank you!
Old Dec 11, 2009 | 12:39 AM
volcomx31's Avatar
Silver Power
nobody knows what injectors the AT has?
Old Dec 12, 2009 | 01:10 AM
i wonder if you even try sometimes.
but here you go..
https://www.rx8club.com/showthread.p...ight=injectors
Old Dec 12, 2009 | 01:14 AM
volcomx31's Avatar
Silver Power
lol. i searched and never found that particular thread. thanks.
Old Dec 12, 2009 | 01:18 AM
lilring's Avatar
Finally a MT
this might be a stuiped question. but why are you swaping out your injectors?
Old Dec 12, 2009 | 01:23 AM
volcomx31's Avatar
Silver Power
they are most likely clogged/dirty and my car is running like ****. bad gas mileage, rough idle, etc..Charles Hill actually came by and diagnosed my car and he thinks that could be it.
Old Dec 12, 2009 | 01:35 AM
lilring's Avatar
Finally a MT
really? do you have the orginal engine? and how many miles are on it? im wondering if mine is the same thing
Old Dec 12, 2009 | 01:38 AM
Easy_E1's Avatar
No wonder I couldn't get him on the phone. He's out helping people.
Have you tried some fuel conditioner/injector cleaner?
Old Dec 12, 2009 | 01:44 AM
lilring's Avatar
Finally a MT
what fuel injector cleaner should I use? there so many out there
Old Dec 12, 2009 | 01:51 AM
b&g 44k and seafoam are good choices.. you can now find seafoam at walmart..
i would do one can with half a tank..
but if the injectors are really clogged it will not do it.. removal and cleaning is the only way..
Old Dec 12, 2009 | 01:20 PM
volcomx31's Avatar
Silver Power
i am on my 2nd engine and it has 35k on it..i have tried BG44K and that didn't do anything..i need to get them removed and cleaned.
Old Dec 12, 2009 | 02:02 PM
lilring's Avatar
Finally a MT
do you think Zmax would do the trick?
Old Dec 12, 2009 | 02:48 PM
I dont' get how you clogged your injectors in 35,000 miles.
Old Dec 12, 2009 | 04:54 PM
volcomx31's Avatar
Silver Power
i don't know..it sucks though.
Old Dec 12, 2009 | 05:16 PM
invasion08's Avatar
Here is how to get to your fuel injectors to get them cleaned
BEFORE REPAIR PROCEDURE
WARNING:
•Fuel is extremely flammable. Always keep sparks and flame away from fuel. Ignition may cause death or serious injury, or damage to equipment.
•Fuel line spills and leakage from the pressurized fuel system are dangerous. Fuel can ignite and cause serious injury or death and damage. Fuel can also irritate skin and eyes. To prevent this, always complete the "Fuel Line Safety Procedure".
CAUTION : If there is foreign material on the connecting area of the quick release connector, it might damage the connector or fuel pipe. To prevent this, when the quick release connector has been disconnected, clean the connecting area before reconnecting it.
1.Remove the fuel-filler can to release the pressure inside the fuel tank
2.Remove the fuel pump relay.
3.Start the engine.
4.After the engine stalls, crank the engine several times.
5.Turn the ignition switch to the LOCK position.
6.Install the fuel pump relay.
FUEL INJECTOR REMOVAL/INSTALLATION
1.Follow the before repair procedure and perform fuel line safety procedure.
2.Disconnect the negative battery cable.
3.Remove the extension manifold (upper). (See INTAKE-AIR SYSTEM REMOVAL/INSTALLATION.)
4.Remove the extension manifold (lower). (See INTAKE-AIR SYSTEM REMOVAL/INSTALLATION.)
5.Remove the VDI actuator bracket installation bolt and the position the VDI actuator out of the way.
6.Disconnect the fuel injector connector.
7.Remove in the order indicated in the table.
8.Install in the reverse order of removal.
9.Inspect the variable dynamic effect intake (VDI) actuator.
10.Inspect all parts by performing the "AFTER REPAIR PROCEDURE".
Old Dec 12, 2009 | 05:24 PM
invasion08's Avatar
Volcomx31 This is your best bet without removing the fuel injectors. http://www.bgfindashop.com/locator/index.php. And find a place that can do the Fuel/Air Induction Service on your car. BG also has a product just for fuel injectors
BG Fuel Injection System Cleaner
BG Fuel Injection System Cleaner is a specially formulated blend of solvents, high molecular-weight dispersants and deposit control additives which will quickly, effectively and safely clean fuel injectors and help remove upper engine deposits. This product is designed to be used with the BG 9210 Inject-A-Flush® Apparatus and BG 44K® Part No. 208. BG Fuel Injection System Cleaner contains deposit control additives which “pre-soak” rock-hard valve deposits. This allows the powerful cleaning ingredients in BG 44K® to provide even more effective cleanup. Not harmful to any fuel system components including gaskets, hoses, metals, fuel tank bladders, fuel pumps, O-rings, etc. Catalytic converter and oxygen sensor safe.
Old Dec 12, 2009 | 10:18 PM
volcomx31's Avatar
Silver Power
good looking! i will look into this. thanks man.
Old Dec 12, 2009 | 10:40 PM
volcomx31's Avatar
Silver Power
would you guys choose Econo Lube N' Tune or AAMCO for service?
Old Dec 13, 2009 | 01:05 AM
yep,,
likely will not do the job..
neither
Old Dec 13, 2009 | 02:01 AM
volcomx31's Avatar
Silver Power
from experience or what?
Old Dec 13, 2009 | 02:39 AM
mike[piston eater]'s Avatar
O' Let's do it.
neptune speed :D
Old Dec 13, 2009 | 02:59 AM
Atilla's Avatar
I am THAT guy
^+1 w/mike
would be the only place i would trust.
scribed for reference.
Old Dec 13, 2009 | 07:27 AM
invasion08's Avatar
Originally Posted by swoope
yep,,
And could i please get your opinions or facts on why this will not do the job?
Old Dec 16, 2009 | 03:29 AM
have done both seafoam, and have been a big fan of 44k.. but if you get a good clog in an injector only removal and replacement will work..
it happened to me..
