V-LEDs Tail Light Star Design
Old Dec 10, 2009 | 12:38 PM
bmak's Avatar
Has anybody tried these LEDs? Will they fit in the factory light housing?
V-LEDs White V-Star M-SMT Parking Lights
Old Dec 10, 2009 | 12:43 PM
The Reverend's Avatar
That's a lie
Pico has them in his brake lights
https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/v-led-upgrade-brake-signal-lights-169490/
Old Dec 10, 2009 | 01:35 PM
bmak's Avatar
I notice that the stock bulbs are not tinted red. Is it safe and reasonable to use white LED taillights to provide a brighter glow while the red enclosure will still provide the red tint.
Old Dec 10, 2009 | 02:17 PM
JinDesu's Avatar
went back to srsly broke
It will still be a red tail-light, just a bit brighter and lighter where the LEDs reside.
Old Dec 10, 2009 | 02:32 PM
lepichichi's Avatar
I LuV mY Rotary....
my friend jose has them on his shinka and they look super hoTTTT, get them.!
Old Dec 10, 2009 | 03:39 PM
Pico's Avatar
It's Complicated
I've had them since last winter and they are 10times brighter then the OE lights.
IMO worth the price. If I were you i would stick with the red LED
Old Dec 10, 2009 | 03:43 PM
Pico: any night time pics?
any draw backs to swapping out to these LED's? Is it the brake lights that freak out the abs system for some people?
Rev: isn't that what happened to RedFox?
Old Dec 10, 2009 | 04:04 PM
Pico's Avatar
It's Complicated
Here are a couple pics (not the best) I haven't had any problems with other lighting components in the past yr since I did this upgrade
the amber turn signals are V-Led AMBER 1157 V-LEDS 7W HIGH POWER 20 LED TURN SIGNAL BULBS 2057
Old Dec 10, 2009 | 04:10 PM
That's a lie
He swapped some LEDs into his brake lights, when unbeknownst to him there was already a LED in the 3rd brake light which trips some of the dash lights. He replaced 3rd brake light with a regular bulb and it was fine.
Installing a resistor in the 3rd brake light solves the problem if you have all LEDs
Old Dec 10, 2009 | 04:28 PM
Pico's Avatar
It's Complicated
I also have the LED 3rd brake light that isn't shown in the pics above. I 'm not using a resistor on the 3rd brake light and there are no problems to report .
Only resistors being used are two 3ohms for the rear turn signals.
Here's a full view
Old Dec 10, 2009 | 04:42 PM
That's a lie
Interesting, although to my knowledge the problem occurs when the 3rd brake light is replaced with a 7440 LED. Your fancy schmancy LED board must be different
Old Dec 10, 2009 | 04:51 PM
Pico's Avatar
It's Complicated
Bingo
There's your problem
Old Dec 10, 2009 | 09:01 PM
bmak's Avatar
Pico, is that 3rd brake light one of the ones available on ebay? Been looking for a good 3rd brake light as well, what do you think of the one you have there?
Old Dec 10, 2009 | 09:05 PM
bmak's Avatar
Pico, I like the look of the turn signals as well, but I'm not sure about double the price for the "high power" ones, anybody have any experience with the standard amber turn signals and the standard white back up lights? I presently have the tail-light kit from rotaryfx and i'm disappointed with the results.
Old Dec 10, 2009 | 10:02 PM
Pico's Avatar
It's Complicated
I bought this 3rd light off of a member here. It looks exactly like the one's you'll see on ebay. I like it a lot, the brightness of the 3rd matches up very well with the v star brake lights. Very bright
I think its worth the price
the OE and FX lights are very under power. I have had the FX lights in the past and they definitely not worth the money.
Old Dec 10, 2009 | 10:13 PM
bmak's Avatar
What about the V-LEDs standard (I already know too well to avoid the rotaryfx ones). Here's a link: V-LEDs M-SMT 27 LED Amber.
And the same for white backup lights: V-LEDs M-SMT 27 LED White.
Old Dec 12, 2009 | 10:56 PM
Daisun's Avatar
I have them as brake lights as well:
https://www.rx8club.com/members/daisun-19985-albums-led-tail-lights-1431/
Old Dec 13, 2009 | 10:46 AM
Pico's Avatar
It's Complicated
I've seen these Leds in action and they look descent.
Definitely not as bright as the 7w bulbs but they still would be a good upgrade
Old Dec 14, 2009 | 12:47 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
I've seen the ones on sale on eBay and was wondering if they'd require a resistor.
Old Dec 15, 2009 | 03:18 AM
Daisun's Avatar
They dont need resistors. I have all my brake lights replaced with LEDS and they work fine. However, if you want to change the indicator lights to prevent hyper flashing I think you will need resistors.
Old Dec 16, 2009 | 03:25 PM
Pico's Avatar
It's Complicated
No resistor for 3rd brake light -- if you buy the actual light
3-6 ohm resistors for the signals are a must if you want to prevent hyper flashing.
vapor2
May 4, 2020 03:53 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
erikcamacho15
Sep 12, 2015 11:23 AM
