Running AC in winter
Old Dec 3, 2009 | 05:18 PM
MyRXdrug's Avatar
I was just wondering, since it reached -20 degrees celcius up here this morning, if I could run the AC (without damaging it), with the heat on, and using Recycled air.
The RX-8 takes forever to warm up, so instead of using front window defroster (which uses fresh air, and considerably slows up engine warmup), I switch the direction to body and feet and use recycled air. Unfortunately this can fog up the windows even with no one in the car, so hence my question. Using the AC to take out the moisture from the air.
Old Dec 3, 2009 | 06:12 PM
EDZRIDE's Avatar
2005 White GT
I'm sure you could but it's better to use the defroster as the AC compressor runs in that mode.
Old Dec 3, 2009 | 06:49 PM
DubbsLuvs8s's Avatar
When it's in defrost mode you're just running the A/C with the temperature set at hot.
It's in the manual.
Old Dec 3, 2009 | 11:41 PM
MyRXdrug's Avatar
ok thanks!
I was thinking that the condenser would freeze up or something like that. It's too bad most newer cars do not allow you to choose recycle and defrost so it won't take the engine as long to warm up.
RevMeHarder
Jun 1, 2026 02:30 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Emmanyei
Sep 4, 2015 11:38 PM
