Odd electrical problems
Old Nov 23, 2009 | 03:20 PM
MFslacker22's Avatar
Hi,
Every once in a while my headlights will not turn on. I flip the switch inside and nothing happens. The high beams work, so I end up having to keep my high beams on to get home and blind everyone driving by me. A weird thing that happened the other day is the headlights would not turn off! The switch was off and the lights were still on. I switched relays and it seems to work now, but is there any other reason this would happen?
Also, sometimes when I press the volume on the steering wheel the radio will restart a song or go from cd to radio or vis versa rather than turn up the volume. Why would this happen?
thanks
Old Nov 23, 2009 | 03:34 PM
Jon316G's Avatar
Grasshopper
When you have electrical problems where a device gets power intermittently when a switch is used, a stuck relay is a likely suspect.
Only problem is the headlight relay is for both your low and high beams, so a bad relay would affect both.
The light switch itself could be defective.
Now with that said... you mentioned electrical issues with the steering wheel controls too.
You might have some funny wiring/electrical issues going on in your steering wheel that is affecting both the light switch and the controls.
This is one of those, "if you're still under warranty, let someone else deal with it!"
Old Nov 27, 2009 | 09:03 PM
ASH8's Avatar
Super Moderator
You might want to swap a few Relays for your Headlamp one to see what may be the cause...
Many of the relays are ALL the same...up to 12 in fact (depending on Country)
The same relays are used for the following...Part Number B115-67-730
Headlamp (HID Discharge Type)
Tail Lamp
Cooling Fan
Heater
ACC
Defogger
Air Conditioner
Horn
Seat Warmer
Front Fog Light
Rear Fog Light
The same relays are used for the following up to 3...Part Number L110-67-730
Ignition
Starter Cut
Headlamp
B115-67-720 (One)
Cooling Fan
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
zoom44
General Automotive
10
Sep 29, 2015 09:56 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Tsurugi
Sep 7, 2015 08:27 PM
mattymack
Sep 6, 2015 10:33 PM
