strange light and hose leak?
Old Nov 20, 2009 | 07:52 PM
ronx8's Avatar
zoom zoom!
got my car back from a 30k service.
i have an 07 AT
car seemed to be running smoothly but after arriving at school i heard a strange whistling/vacuum noise i never heard before during acceleration.
so i opened the hood to check it out and im not a mechanic so i dont know how to describe this but:
theres 2 hoses, 1 large one overlapping a smaller one. the larger one seems to be like an insulator to protect the smaller hose? they connect from the oil (yellow cap) to way down below towards the washer fluid and engine. when i clamp on the larger hose well, it compresses with the smaller hose and the vacuum noise stops, is it ok if i hose clamp this? is this even normal?
and also, i just finished me 30k but i got the radiator light that means low fluids or something like that. i highly doubt this is normal too.
sorry for the punctuation and poor knowledge of hose lines, but any info will help.
Old Nov 20, 2009 | 08:03 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Call whomever did the 30k service and tell them they screwed up, have them send a flatbed and tow it back as you are scared to drive it, then have them fix it, and provide you a loaner if you need it while they do so.
A picture with arrows would be nice if you could, as your desription is a little tough to make out.
I can almost do so with making assumptions, but don't want to steer you in the wrong direction.
If that hose really comes out of the oil filler neck, then it is just to route excessive oil or vapors back to your maintainance ports on the engine and it would be okay to lightly clamp it to stop the noise.....but I'm confused by your description of it. Let me ask you where you are squeezing it? Right at the oil filler neck? If yes, then you could clamp it......but again lightly.
Have you checked your coolant level? Do you know how?
Is there any on the ground beneath the car?
What about anything else leaking........oil spots on ground?
You should be able to see the coolant level looking at the left side of the bottle when standing in front of the car. Since you don't seem very car savvy, DO NOT mess with the radiator cap at all!!!!!!
BTW, look at the picture below. See my blue hose coming off my oil filler neck? Is this where the hose connects that you are talking about? Do not pay attention to where mine runs as we have completely different setups, I just want to know if that's the hose and where you are squeezing it? If so........you can see I have it clamped to the nipple that protrudes from the oil filler neck.
If not, then take this picture and point out the hose you are talking about.
Old Nov 20, 2009 | 08:11 PM
xun4gvn4everx's Avatar
True love is blue x2
^ +1
I have been searching trying to find out your symptoms, but your description is not helping. Give pix and DO NOT drive the car so that you do not compromise any leverage you have on the service repair personnel.
Old Nov 20, 2009 | 10:19 PM
ronx8's Avatar
zoom zoom!
thank you for your quick replies!
the blue hose is where it seems to be "leaking" or "whistling"
if i lightly clamp on the end away from the oil neck it stops.
as for the light, i called the dealer and they said it is common that the light can turn on when the fluids are taken out and replenished. apparently air pockets can form on the coolant and i guess throw the light. sounds funky, but i guess it is a possibility.
Old Nov 20, 2009 | 10:22 PM
ronx8's Avatar
zoom zoom!
no spots on the ground.
but i did notice moisture (possibly fluid) on the hose. very very small amount.
Old Nov 20, 2009 | 10:31 PM
Mazurfer's Avatar
Clamp it and see if it goes away, just don't clamp it completely closed.
This is possible. Make sure you check your coolant fluid level and have it up to the full line as I described above. Keep an eye on it and report back in a few days if that light doesn't go out but make sure you keep an eye on the level of the coolant during this time.
Good luck, once the bubbles get out, the light may go away.
Old Nov 20, 2009 | 10:32 PM
IF, it is just a clamping issue, then you are okay to clamp it as long as you are just clamping to a "connector". From your description I couldn't tell if you meant clamping in the middle of a hose or where it connects. As long as your "whistling" comes from where the hose meets the conneting piece, you are good to go for putting in a clamp. BUT, after connecting, make sure to reset your ECU and drive it for a few drive cycles (while watching the fluids and listening to the engine) to make sure all is well.
Old Nov 20, 2009 | 10:38 PM
Mazurfer's Avatar
^..............thanks, I didn't know how to tell him that. I assumed he was talking about squeezing it away from the filler neck but still on the "connector" or "nipple", but I wasn't real sure! Can't imagine he was at the other end of the hose way down by the ports.
I thought about the fact that he might be doing it in the middle somewhere, but that would indicate a hole in the hose?
Old Nov 20, 2009 | 10:44 PM
^ I am not quite sure where he is talking about in the line either. As you said before, pix would def help for us to help him out.
Old Nov 20, 2009 | 11:07 PM
Jon316G's Avatar
Grasshopper
The "hose overlapping another hose" is misleading...
The upgraded setup has a hose surrounded by a protective sleeve that runs down to the maintenance ports.
I assume the sleeve is what he is referring to as the larger hose.
Now that said, there is a T connection towards the end of the hose where it splits off to each port.
I would inspect the connections around there.
Maybe even remove the whole hose assembly so you can visually check it outside the car for any cracks.
Old Nov 20, 2009 | 11:34 PM
^ Jon is the man with the plan!
Old Nov 21, 2009 | 09:31 AM
ronx8's Avatar
zoom zoom!
taking it to dealer this morning.
if its not fixed ill get some pix going.
thanks for all the replies.
and no i wouldn't clamp a hose in the middle.
Old Nov 21, 2009 | 09:37 AM
Mazurfer's Avatar
^..........Well.....I didn't think you would, but you never know!
Yeah..........I was hoping it was just a sleeve he was taking about as Jon describes.
Still........Why would that whistle at the interface between the sleeve and the inside hose?
Given what he has said.......I don't think he is talking about anywhere near the maintenance ports, but I could be wrong?????
Seems that if he is squeezing at the sleeve interface, and it close to the filler neck(something I'm still not sure about), then you'd think he might just be effecting it at the filler neck connection, or..........he's got a crack in the hose?
Anyway...........anybody think there is really enough vacuum action or air flow in this entire setup to generate a whistle?
Old Nov 21, 2009 | 09:46 AM
Jon316G's Avatar
Grasshopper
I don't believe it would be the sleeve causing the issue, but maybe pinching it helped to cover a possible crack on the inner hose.
This is why I recommended he remove the hose and inspect it.
It would even be worth it to remove the hose, disconnect it from the T-fitting, plug one end of the hose with your finger while blowing on the other end (obviously wipe the end of the hose before applying your lips to it).
Then listen for any air escaping.
Or apply a vacuum pump to it and see if any vacuum escapes.
Oh well... we'll see what the dealer finds.
I could be wrong in my assumptions.
Old Nov 21, 2009 | 09:52 AM
Mazurfer's Avatar
It the only thing I can really think of.............a break/crack in that hose. Wish I knew just how far back from the end of the inner hose that the sleeve starts? Obviously my 05 doesn't have this and I'm too lazy to go find a pic!
Old Nov 21, 2009 | 09:56 AM
Jon316G's Avatar
Grasshopper
Here is a pic from the TSB:
Old Nov 21, 2009 | 10:00 AM
Mazurfer's Avatar
Funny that they call it a PCV hose!
If he was squeezing up by the filler neck, I could see it might tighten the interface at the connector, but I'm gonna quess that the sleeve is several inches back....if that is close to scale.
Old Nov 21, 2009 | 10:09 AM
Jon316G's Avatar
Grasshopper
Not the best quality pic, but I found a pic that shows the hose.
Appears that the sleeve is about an inch from the oil filler neck.
But its difficult to judge from this pic.
Old Nov 21, 2009 | 10:28 AM
Mazurfer's Avatar
I wonder if it's possible he's only hearing the air pump after initial start-up and by the time he walks around to the engine bay and gets ready to squeeze the hose that the air pump whine stops....or as he manipulates the hose the air pump then stops?
It's just a theory..................but I wanted it on the record, just in case!
Old Nov 21, 2009 | 10:30 AM
Jon316G's Avatar
Grasshopper
LOL... that would be funny and easy to eliminate.
Simply disconnect the wire harness to the air pump.
Old Nov 21, 2009 | 10:44 AM
Mazurfer's Avatar
Well, he said he's going to the dealer so hopefully we will find out.
Can't help but wonder if he was having any issues and what he said when he went in for the 30k service, because I can't imagine why they(dealer) would be in this particular area(that hose) at the 30k service point? Guess it's possible if there is a crack in the hose, it was always there???? Oh well...............he'll get it found out.
I'm actually more worried about his coolant light issue and whether that is really caused by air in the system after change out and whether or not it goes away........and if he keeps an eye on all that was suggested.
Old Nov 21, 2009 | 12:32 PM
ronx8's Avatar
zoom zoom!
just as i suspected - i had a bad coolant light sensor. i read up on it a while ago and i said to myself "this isnt ever going to happen to me"
anyway, no light on the way home. knock on wood.
and the hose kinda didnt make the noise this morning. but i guess i was just paranoid or something.
Old Nov 21, 2009 | 12:34 PM
Good luck bro
Old Nov 21, 2009 | 05:02 PM
Mazurfer's Avatar
^.......suck, I didn't think it could happen that soon or kinda as you described. Oh well. Mine on my 05 went out not too long ago, but I'd only get the light come on in 3rd gear and almost at redline, then it would go away. Did they replace your bottle under warranty?
Old Nov 21, 2009 | 09:21 PM
ronx8's Avatar
zoom zoom!
yep. fully under warranty.
RXFEVER
Aug 29, 2018 10:14 AM
Azki23
Jun 27, 2018 03:48 PM
RXFEVER
Sep 11, 2016 02:51 PM
DVerdeyen
Sep 13, 2015 11:19 AM
