Do you rev before turning off?
Old Nov 20, 2009 | 09:01 AM
tamz273's Avatar
So I've been reading different opinions about revving the engine to 4-5k before turning the car off.. Would this prevent flooding, or increase the odds of flooding??
Ive been doing it for over a year without a problem.. What do you guys think?
Old Nov 20, 2009 | 09:05 AM
expo1's Avatar
He's as bad as Can
I only do that when moving a cold RX-8 a short distance.
Old Nov 20, 2009 | 09:09 AM
tamz273's Avatar
When I do that I make sure to rev REALLY high.. Others...?
Old Nov 20, 2009 | 09:14 AM
tubingchamp's Avatar
What mawd bug?
How high?
4K should be the max you should rev a cold renesis.. Doesn't get proper lubrication until the engine is warm.
I never rev my engine before shutting it off, only exception is when I've got to shut it down and start it up more than once in a short period of time.
4K should be enough in any case.
Old Nov 20, 2009 | 09:17 AM
Huey52's Avatar
Registered Zoom Zoomer
Yes, religiously. Rev to 3k rpm and hold for 10 seconds, quickly turning off the key just as I take my foot off the accelerator so it continues to purge fuel as it spools down.
But as expo1, only when it's not fully warmed up, which is rare.
Old Nov 20, 2009 | 09:24 AM
DarkLord7854's Avatar
Software Engineer
I'll blip the throttle to 3k before every shut off
Old Nov 20, 2009 | 09:40 AM
Huey52's Avatar
Again, you have to hold it at 3k for 10 seconds or so, not just "blip it", wtf that means. The point is to allow time for the excess fuel to purge. Our engines run ultra rich when cold and thus the need.
Old Nov 20, 2009 | 09:46 AM
ARE-EX-8's Avatar
Rotary > Piston
question ... if you rev 3k for 10 seconds... and the needle is not in the middle... do you still shut if off ... shouldnt the needle be at least half way ?
Old Nov 20, 2009 | 09:51 AM
Pico's Avatar
It's Complicated
Only when cold
Normal driving-- I park let the rpm settle then I shut off
Old Nov 20, 2009 | 10:07 AM
ARE-EX-8's Avatar
Rotary > Piston
No i what i meant was.... say u do the rev prodecure and the needle is STILL not in the middle ... do you still shut off anyway ?
Old Nov 20, 2009 | 10:11 AM
Huey52's Avatar
The middle of what??? You rev to ~3k rpm and hold it there for ~10 seconds. Take you foot off the gas and quickly shut off the ignition as the engine is winding down (unless you have Superman speed it will be somewhat less than 10k as you shut it down).
Old Nov 20, 2009 | 10:15 AM
The Reverend's Avatar
That's a lie
The reason you rev is so that even though the engine is still cold to purge fuel from the system.
So yes the needle is not in the middle, rev, then shut off.
I've been told that flooring it as you switch the ignition off helps also.
Old Nov 20, 2009 | 10:17 AM
Huey52's Avatar
I wouldn't floor a cold engine!
Old Nov 20, 2009 | 10:20 AM
That's a lie
Well after the ignition is off so you aren't revving the engine
Old Nov 20, 2009 | 10:47 AM
josuar88's Avatar
The Crawlster
Only when I want to my car to sound cool lol
Old Nov 20, 2009 | 11:20 AM
Huey52's Avatar
I can't imagine what the point of flooring it is after you turn off the ignition. Granted it cuts off the fuel, but that's like closing the gate after the horse has fled.
Old Nov 20, 2009 | 11:25 AM
RyansRx8's Avatar
Brettward is/has a G
I think he means the display on how hot or cold your engine is but yeah i only rev it to about 3k ONLY if I turn it on then quickly turn it off...my family has alot of cars so we have too move our cars out the way so the other person can back out so I have to do this almost every day lol
Old Nov 20, 2009 | 11:27 AM
That's a lie
^ ugh that is the worst when you have to move your car so someone else can move.
Old Nov 20, 2009 | 11:30 AM
shazy's Avatar
hahahha same for me
Old Nov 20, 2009 | 11:31 AM
Huey52's Avatar
I actually by-hand roll my car out of the garage to wash it, then fully warm it up while drying before backing it in again.
Old Nov 20, 2009 | 11:49 AM
b'Eight''s Avatar
I actually do the opposite. I blip the throttle in neutral after started thereby splash lubricating the tranny.
Old Nov 20, 2009 | 12:01 PM
deadphoenix52's Avatar
meh.
yep.
Old Nov 20, 2009 | 12:03 PM
ARE-EX-8's Avatar
Rotary > Piston
Yup i meant the temp needle. So rev 3k for 10 seconds > shut off as you remove foot from gas > and shut off even though the needle is not in the middle.
Old Nov 20, 2009 | 12:06 PM
ARE-EX-8's Avatar
Rotary > Piston
I know the needle is not in the middle at first. But what im asking is ... atfer your rev 3k for 10 sec it wont make the needle go to the middle... do you still shut it off though ? Sorry i know im being a pain in the ***.
Old Nov 20, 2009 | 12:08 PM
Software Engineer
I do that too
