check engine light codes??
Old Nov 18, 2009 | 02:58 PM
Blackedout22's Avatar
I have gotten two codes from the car today when the check engine light popped on and i dont' know what to do. one is P0301 and one is P0442
Old Nov 18, 2009 | 03:02 PM
dozer's Avatar
on his 3rd rx8
p0301 is a misfire
time to change our your coils and plugs
Old Nov 18, 2009 | 03:04 PM
dozer's Avatar
on his 3rd rx8
heres the list
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
p0442 usually means your gas cap is loose, you most likely need a new one
next time please search
Old Nov 18, 2009 | 03:05 PM
I've already changed the plugs with 100,000 mile plugs and the coilpacks and the plug wires...
Old Nov 18, 2009 | 03:08 PM
dozer's Avatar
on his 3rd rx8
^what kinda plugs and coils are those? and how long ago was it done?
Old Nov 18, 2009 | 03:18 PM
umm had a shop do it and they said they had to order them from mazda and the packs are BWD performance
Old Nov 18, 2009 | 03:24 PM
dozer's Avatar
on his 3rd rx8
never heard of BWD performance coils for the rx8, they probably gave you OEM coils/plugs and wires...how long ago did they replace em?
Old Nov 18, 2009 | 03:27 PM
plugs and plug wires couple months ago coilpacks about 2 weeks ago
Old Nov 18, 2009 | 03:32 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Could be a loose or bad plug wire?
Check your leading plug wire at both ends. Then we will take it from there.
Yeah, the one is your gas cap. Click it 5 times when putting it back on. There are very few cases where it had to actually be replaced.
Then we are gonna ask the usual...............Mileage, year?
Old Nov 18, 2009 | 03:34 PM
dozer's Avatar
on his 3rd rx8
well youre having misfires, and thats from either your coils packs or spark plugs, check em all to see if they are on tight...
and the other code, you can solve that by going to autozone and buyin a new gas cap
im the one who put the coilpacks in they did plugs /wires
Old Nov 18, 2009 | 03:36 PM
think it might be the front rotor?? i hope not...
Old Nov 18, 2009 | 03:40 PM
dozer's Avatar
on his 3rd rx8
^the code you pulled is for the front rotor misfire...
Old Nov 18, 2009 | 03:41 PM
dozer's Avatar
on his 3rd rx8
where did you get your coils from?
Old Nov 18, 2009 | 03:44 PM
ya u think it might be rotor goin bad
Old Nov 18, 2009 | 03:47 PM
Mazurfer's Avatar
Coils can go bad even if fairly new.
I'd still check to make sure a plug wire didn't come off or is loose.
I would also still ask how many miles on the car? And when you did the others, did you change the wires?
Old Nov 18, 2009 | 04:06 PM
dozer's Avatar
on his 3rd rx8
we need more info to determine if you have a bad rotor
year? mileage?
where did you get your coils at? cus those BWD's dont sound right
go check your wire connections on both your coils and plugs
Old Nov 18, 2009 | 04:10 PM
90k miles changed plug and wires at same time
Old Nov 18, 2009 | 04:14 PM
dozer's Avatar
on his 3rd rx8
well point is youre having misfires, you need to check your wires that go on the plugs and coils, if they are on tight, you either have some bad coils or bad plugs and or both are bad...this doesnt mean you have a bad rotor/engine
Old Nov 18, 2009 | 04:38 PM
04RX8man's Avatar
Rotary Powered Countryboy
if everything is tight it wouldnt hurt to make sure u have the correct plugs in the correct spot
Old Nov 18, 2009 | 04:45 PM
well it wouldn't have ran right for over 5 months if that was the case correct?
Old Nov 18, 2009 | 04:49 PM
04RX8man's Avatar
read ur earlier post wrong...thought it said everything just got done a couple weeks ago.....if its been a long time ur fine w /that
Old Nov 18, 2009 | 04:51 PM
dozer's Avatar
on his 3rd rx8
5 months? you said you just replaced both your coils and plugs
Old Nov 18, 2009 | 04:54 PM
04RX8man's Avatar
^plugs and wires a few mnths ago...coils....recently
Old Nov 18, 2009 | 05:01 PM
you got the time right coils few weeks ago plugs and wires few months ago
