Car smoking
Old Nov 16, 2009 | 03:58 PM
SHINKA RX8's Avatar
Car smoking
my car has the greddy turbo kit so i dont know if the turbo is bad or not. when i drive it its fine but after driving it for 15 min i come to a stop and 5 sec later it will smoke almost like the car is on fire. has anyone had this problem. please help.
Old Nov 16, 2009 | 04:23 PM
CyberPitz's Avatar
Huge hole is huge
It sounds like an oil seal, in my uneducated opinion. Which one? good question. First place I'd check is the turbo.
Wait, what kind of smoke? Sweet smelling white smoke? Blue?
Old Nov 16, 2009 | 04:59 PM
04RX8man's Avatar
Rotary Powered Countryboy
yes like cyber said the turbo would def be the first place I would check.... and make sure your feed and return lines are tight and not leaking onto the turbine/manifold
Old Nov 16, 2009 | 05:06 PM
Easy_E1's Avatar
As Cyberpitz asked, what color is the smoke. Is it coming out of the exhaust or from under the hood?
Old Nov 16, 2009 | 05:08 PM
04RX8man's Avatar
^yes kits are alot cheaper than a new turbo...like easy siad they're easy..I rebuild a Nissan sr20 turbo last yr and didn't take long at all....
Old Nov 16, 2009 | 05:10 PM
tubingchamp's Avatar
What mawd bug?
Maybe it's not tuned either? (if pipes)
Old Nov 16, 2009 | 05:13 PM
Easy_E1's Avatar
Rebuilding a turbo is not that hard. Let's first determine where the smoke is coming from before we start ripping things apart. Diagnosis of the issue is key to any repair job performed correctly.
Old Nov 16, 2009 | 05:15 PM
04RX8man's Avatar
^YES don't replace parts unless u see what is wrong first...unless u want to just waste money then it's up to u haha
Old Nov 16, 2009 | 05:54 PM
SHINKA RX8's Avatar
Its not blue smoke and it is coming from the exhaust. if i turn the car off then let it sit for a bit like ten min its ok again. i think that if it was coming from the engine like a bad oil seal from the motor then it would smoke all the time. i dont know if thats correct or not. i dont have any cats on the car so before it starts to smoke i get a real bad smell then the smoke starts. if i start to drive at any speed slow or fast it goes away but when i stop it starts agian untill i turn it off. the color off the smoke is black.
Old Nov 16, 2009 | 06:03 PM
SHINKA RX8's Avatar
before all the smoking started i did a oil change on the car and i over filled it by a quarter quart of oil to much and drove it that way home, but when i started the car the first time to check the oil i let it warm up, and 30 sec later it started smoking really bad. the next day i drove it to work and drained the oil and got it to the correct level, but i have driven the car two days know and it is still smoking.
Old Nov 16, 2009 | 08:23 PM
04RX8man's Avatar
did this smoking just start to occur right after the turbo was installed?...black smoke usually equals fuel.....
a quarter quart overfilled shouldn't hurt anything but with a turbo if you don't have a catch can you could easily be pushing oil out the tube and into the intake....then burning it....
Old Nov 16, 2009 | 09:32 PM
Easy_E1's Avatar
A 1/4 Qt. extra of oil will do nothing to the car.
Black smoke is an indication of unburnt fuel. It's running too rich. Check your spark plugs and see which one is black. Could be a fouled plug. Caused by what I don't know. Could be a clogged injector. Dirty and or a bad spray pattern, or stuck open. Check the ignition system and the fuel system. Check your air filter.
Do you have any type of Engine Management on the car?
Old Nov 16, 2009 | 09:44 PM
What mawd bug?
He probably doesn't have it tuned well..
Old Nov 16, 2009 | 10:30 PM
bhop's Avatar
NO A/C :(
^ I agree
Old Nov 17, 2009 | 10:55 AM
SHINKA RX8's Avatar
it does run rich so i will check the spark plugs first. i work at a shop so its very easy for me to check them.
Old Nov 17, 2009 | 11:03 AM
CyberPitz's Avatar
Huge hole is huge
What are you using for a tune with the turbo? Just curious.
Old Nov 17, 2009 | 03:06 PM
SHINKA RX8's Avatar
so i changed out the spark plugs. they were darker full of carbon. im talking darker than the darkest night. it smoked just a little im thinking the old stuff was burning out but i drove it around the block at wot and got no smoke i drove it back to my shop and let it idle for 5 min and no smoke. i do think that i have to get it re tuned since i just got the spark plugs about 8,000 miles ago. to much fuel. im currently running the interceptor x (microtech) engine management system. thanks everyone that had some input on my issue.
Old Nov 17, 2009 | 04:10 PM
hakuna matata!
was it competently tuned?
Old Nov 17, 2009 | 04:14 PM
CyberPitz's Avatar
Huge hole is huge
Ya, it seems like it is tuned, but not right. I'd get someone to make sure it's tuned properly, otherwise this is just going to happen again.
Old Nov 17, 2009 | 06:39 PM
SHINKA RX8's Avatar
I had my car dyno tuned @ the dyno shop in santee,ca and i would not recommend them to anyone 1100 dollars later yes the car runs but not that great. i have spoken to a shop in long beach that does 3 rotors and rx8 and rx7 i hope to take my car their soon to have it re tuned.
Old Nov 17, 2009 | 06:46 PM
shazy's Avatar
You should've went to them in the first place. But damn! 1100$!
It should be one helluva tune!
Old Nov 18, 2009 | 12:37 PM
SHINKA RX8's Avatar
I think that im having a change of heart now. ive had the turbo kit on their for about a year, and im thinking about getting rid of the turbo kit. i just never use it like its ment to be.
Old Nov 18, 2009 | 12:41 PM
What mawd bug?
After spending all that cash?
Probably bad call man.
Get it tuned and enjoy it.
Old Nov 18, 2009 | 03:01 PM
tamz273's Avatar
Hey, not to encourage you to take the turbo out, but if you DO decide to rip the whole kit out, please send me details of what you have installed and you might have yourself a buyer!
Old Nov 18, 2009 | 04:42 PM
04RX8man's Avatar
id put the time in to get it to run how u like it...but if u do take it off u will easily sell it here
