Another car won't start thread
Old Nov 10, 2009 | 03:54 PM
kanjas's Avatar
I've read the threads I can find but they don't help. Can someone point me in the next direction to troubleshoot my problem?
My car started 2 days ago when i moved it out of the driveway and back, but when i went ot restart it the battery was dead. I tried to jump it but the starter would spin but it didn't sound like the engine was turning. Maybe a little at first but nothign now.
I bought a new battery and it's still doing the same thing. Starter spins but seems like the engine isn't doing anything.
I tried holding the gas down for 10 seconds thinking it was flooded like the manual said but no luck.
I just found out my warranty expired 2 weeks ago. I found some small water droplets on the dipstick when i checked the oil. it wasn't a lot. Could i have a more serious problem?
Anything I can try before i call a tow truck?
Old Nov 10, 2009 | 04:39 PM
EDZRIDE's Avatar
2005 White GT
First verify that the engine is not turning while the starter is spinning. If that truly is the case, remove the starter and check the teeth on the ring gear (flywheel); if those are ok, have the solinoid & starter drive checked.
Old Nov 10, 2009 | 04:50 PM
Jon316G's Avatar
Grasshopper
If the starter is spinning and the rotors (engine) aren't, verify the flywheel's teeth as EDZRIDE mentioned.
I've seen the flywheel's "pressed-on" teeth ring separate from the rest of the flywheel before.
But this was caused by a serious clutch failure, so hopefully this isn't your case.
Also verify the connections to the battery are tight.
Since you mentioned reading threads on deflooding, have you tried the other methods such as pulling the spark plugs, tow starting, or even squirting washer fluid into the maintenance ports?
Old Nov 10, 2009 | 05:38 PM
kanjas's Avatar
Thank you for the responses.
How do I verify that the engine is not turning while the starter is spinning?
And no I have not tried those other flooding measures yet. Mainly since I am unsure how. (What/where is a maintenance port?)
Old Nov 10, 2009 | 05:45 PM
EDZRIDE's Avatar
2005 White GT
The easiest way would be to raise the hood, remove the engine cover, and watch the alternator pully while a second person is in the car trying to start it. If the pully isn't moving but you can hear the starter motor turning, it's time to check the flywheel teeth then the starter if necessary.
Old Nov 10, 2009 | 05:52 PM
Jon316G's Avatar
Grasshopper
First method to try is simply removing the spark plugs, pulling the fuel pump relay, and have someone crank-start the car.
Have a rag nearby to catch the fluid as it ejects from the engine.
Insert the plugs and relay and try starting again.
Old Nov 10, 2009 | 05:58 PM
Jon316G's Avatar
Grasshopper
My personal favorite that has worked for me every time is using washer fluid which I talk about in this post:
https://www.rx8club.com/showpost.php...8&postcount=89
Old Nov 18, 2009 | 03:53 PM
DomesticRx8's Avatar
where are the ports in your pictuers?
Old Nov 18, 2009 | 04:04 PM
Jon316G's Avatar
Grasshopper
To the right of the washer fluid reservoir:
Old Nov 18, 2009 | 05:15 PM
04RX8man's Avatar
Rotary Powered Countryboy
^how is it i've been here 4 almost 3 yrs and i never saw that method? haha...just shows there's alot of info on here
Wantingtoknow
Dec 15, 2016 02:25 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Kangarhew
Jul 18, 2015 08:27 PM
