car wont start
Old Nov 8, 2009 | 11:48 PM
katafuji's Avatar
car wont start
here's what happened. started my car it was warm already but i still let it run for awile before driving. before i even get it into gear it shuts off. i didnt step on the gas or anything. got out and saw some smoke coming out the exhaust not a lot. tried to start it again and it wont start. had my cousin turn the key while i looked under the hood and the crank wasnt turning at all. just a clicking sound. its an 04 6MT with 95k.
Old Nov 9, 2009 | 10:18 AM
EDZRIDE's Avatar
2005 White GT
Sounds like the battery is low. Charge and load test after you check and clean the connections. Check the charging system too.
Old Nov 9, 2009 | 10:19 AM
xun4gvn4everx's Avatar
True love is blue x2
I want to start off by saying congrats on 95k! Now, when is the last time you changed your coils, plugs, wires, and battery?
Old Nov 9, 2009 | 12:38 PM
katafuji's Avatar
Question
I changed the coils, plugs and wires at the same time last month. The battery, almost two years. like i said the car started then shut off while i let it idle. all the electricals are working like lights, windows, radio. tried to jump it but still nothing.
Old Nov 9, 2009 | 12:40 PM
katafuji's Avatar
do you guys think it could be the starter????
Old Nov 9, 2009 | 01:20 PM
Did you check to make sure the connections on the battery terminals have not come loose? Also check for corrosion on the terminals which could limit the transfer of electricity from your battery.
Old Nov 9, 2009 | 03:32 PM
katafuji's Avatar
yes, i checked battery before jumping it. the problem is not the alternator either. the crank does not move at all.
Old Nov 9, 2009 | 03:36 PM
I know you have said you tried to jump it, but if it is not turning over, then there has to be something causing power loss. Try putting a volt meter on your battery under load to test and see if it is any good. A bad battery will also give you issues when trying to jump since it can't hold the charge well enough.
Old Nov 9, 2009 | 06:09 PM
iLikeEatPoo's Avatar
The Great Dick
Try pop starting. That almost always works.
Old Nov 10, 2009 | 12:17 PM
katafuji's Avatar
here's an update: i tested the battery and it's good. we already tried pop starting, it didn't work. my friend's dad is a toyota master tech and he said it might be the starter.
Old Nov 10, 2009 | 02:05 PM
Huey52's Avatar
Registered Zoom Zoomer
You didn't say how you tested your battery. If you just put a voltmeter across its terminals and observed 12v that does not speak to its capacity. It has be load tested to be determined good.
But let's assume you did load test it. Unfortunately without the vehicle running you can't really determine if the Alternator is putting out the proper ~14v.
You don't need a good starter motor to pop [clutch] start it (being at speed and popping the clutch provides the motive force to turn over the engine), so I don't see where the bad starter assumption necessarily comes from.
A few more variables to resolve: 'plugs, coils, 'plug cables, fuel pump, starter interlock switch (on the clutch bracket), and of course flooded condition.
Old Nov 11, 2009 | 01:12 PM
katafuji's Avatar
i tested the battery using at VAT. its not the plugs, coils, or cables cause they're still pretty much new and i've checked them already. it's not the fuel pump either cause i can hear it when i turn the key to the on position. deflooding wont work cause the crank is not turning at all. when i turn the key to the start position there is only a clicking sound. the crank DOES NOT ROTATE.
Old Nov 11, 2009 | 05:04 PM
Huey52's Avatar
Then try to push start it (M/T presumed; pop the clutch in 2nd while rolling down a hill or being pushed). You don't need a starter to push start and if it does run it will tell you the starter's bad - although from your latest description it does appear the starter's gonzo.
You possibly have the old, lower powered, starter anyway. See the other similar post today for TSB insight (albeit not now offered free due to B-to-B warranty expiration).
https://www.rx8club.com/series-i-trouble-shooting-95/not-starting-186057/
Old Nov 14, 2009 | 05:09 PM
katafuji's Avatar
the car started, then it shut down after 2min. now it looks like the engines locked.
Old Nov 14, 2009 | 05:42 PM
Old Rotor's Avatar
If it only ran for two minutes and stopped then it might be flooded now.
Old Nov 15, 2009 | 08:41 AM
katafuji's Avatar
would flooding keep it from cranking? forgot to mention this but when it shut down the first time i tried to start it .it was cranking then it stopped and started clicking.
Old Nov 15, 2009 | 01:50 PM
Old Rotor's Avatar
No if flooded it would just turn over and over and not start. If it won't even turn over then you have a bad battery or starter or connection to them. This would be the first place to look. Look at the bottom of the page there are usually some good ideas there ......Then get back to us....
Old Nov 15, 2009 | 04:01 PM
04RX8man's Avatar
Rotary Powered Countryboy
if it was cranking then stopped cranking and started to click sounds like a battery...you need to get it running and see what voltage is coming out of the alternator to make sure it's charging...95k miles and prob the original alternator it's a possibility
Old Nov 15, 2009 | 06:24 PM
Old Rotor's Avatar
04RX8man is right check the alternator after it's running make sure it's charging! That would be the next important thing if that was the cause. It could be a tired battery that never got any service or a tired old style starter that you soon will be glad you updated.
Old Nov 19, 2009 | 09:40 PM
katafuji's Avatar
tested the alternator, good. tested battery, good. checked connections, good. i'm a uti graduate so i know what to check and how to check it and have uti's equipment at my disposal. last test gave me the answer. tried to turn the crank by hand, fail. engine is definitly locked. getting a new one now.
Old Nov 19, 2009 | 10:28 PM
Old Rotor's Avatar
Get it how? please give us the details. I see you have 95K miles and Mazda's warranty last to 100K......
Old Nov 20, 2009 | 06:16 AM
Huey52's Avatar
Engine locked??? The dissimilarity in the expansion rates of the aluminum-iron contact metals makes it impossible to seize the engine. So it must be mechanical. E-shaft?
Well, at least you'll get a new [reman] engine and essentially have a new car.
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
Kangarhew
Jul 18, 2015 08:27 PM
