lost vacuum from power assisted brake
Old Oct 26, 2009 | 03:42 PM
terrypk1's Avatar
BC lost vacuum from power assisted brake
Hi
So
I accidentally broke the master cylinder bleeder screw (only seen on 04 models)by over tightening it. yeah i am an idiot.
To get the screw out, i need to drill a hole first and then use easy out.
to drill a hole, i need clearance to get tools in. So i decided to remove the master cylinder from the brake booster and i didn't know that the booster is supposed to have VACUUM in it..sigh..dumb move
so now the vacuum is disrupted and gone...what effects are there if i just replace the bleeder screw and bleed my car and try to drive? will I be able to brake? or will the braking becoming significantly worse?
thanks guys
Old Oct 26, 2009 | 03:52 PM
Jon316G's Avatar
Grasshopper
LOL... no worries, I've removed vacuum from the booster without any issues.
There is a vacuum line running to the upper intake manifold with a one-way valve.
When you start the car and vacuum builds-up in the intake, it'll restore your booster.
Old Oct 26, 2009 | 03:56 PM
terrypk1's Avatar
I LOVE YOU.
that's what i read too..but wasn't sure.
LOVE YOU for saving my ***..
now i just have to get the screw out..and bleed the car.
LOVE YOU
Warrior777
Jun 24, 2019 04:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
Olib1988
Aug 20, 2015 10:34 AM
