View Poll Results: Which oil filter?
stock OEM Mazda filter
16
51.61%
larger OEM Mazda filter, actually designed for the V6 engine
0%
M1-108
6.45%
M1-110
6.45%
FRAM
6.45%
Purolator Pure One
16.13%
other (list below)
12.90%
Voters: 31. You may not vote on this poll
For DIY people, what oil filter do you use?
Old Jan 12, 2004 | 07:19 PM
fan's Avatar
fan
or maybe I should ask which one is the BEST?
also, do places such as pepboys and autozone sell the crush washer?
Old Jan 12, 2004 | 09:24 PM
khoney's Avatar
FX8TED on my RX-8
I go stock, on the advice of the best rotary mechanic in town. If not stock, I would go with an AMSOIL or Mobil-1 filter. Both are highly rated.
Old Jan 12, 2004 | 09:46 PM
rxeightr's Avatar
M0D Squad -charter member
Stock as well
Old Jan 15, 2004 | 10:47 PM
w2aew's Avatar
www.dorkage.com
Stock for me too (even though it is a little smaller than the one from the factory). Of course, I've only done one change so far, at 1500 miles. Planning on doing it again at 5K, and every 5K after that. On my other vehicles, I stick with Purolator or Motorcraft.
One more question for the DIYers... I noticed that when I changed the oil that there was a bit of air bubbling/gurgling as I removed the filter (as the rubber gasket released from the sealing surface). I also noticed that I spilled about a tablespoon or so of oil from the filter. So, the question is: If I remove the filter very slowly to let the air enter the filter, will this help to drain the filter more effectively and give less spillage? If so, will poking a small hole in the top of the filter with an awl prior to removal result in the same draining effect?
Just trying to minimize the amount of spilled oil to clean up.
Old Jan 15, 2004 | 11:53 PM
B-Nez's Avatar
I've been using the Bosch 3300. My local Autozone only carries Fram (sucks), Motorcraft, Mobil1, Bosch, and a few AC Delco.
Old Jan 15, 2004 | 11:58 PM
B-Nez's Avatar
There had been some debate over hole-punching a while back. Here is one thread that touched on it, but I know there was some more discussion in other threads. Here are the results I got when I searched for the keywords 'oil' and 'nail'.
mr. GrandGame
Sep 9, 2025 10:41 PM
05TR1CH
Apr 18, 2023 04:56 AM
Warrior777
Jun 24, 2019 04:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
Junirol
Sep 22, 2015 06:02 AM
