oil dipstick question
Old Jan 11, 2004 | 10:42 PM
i3man's Avatar
How much oil does it take between the low line and high line on the oil dipsick? Is it one quart? More?
Old Jan 11, 2004 | 10:53 PM
WHealy's Avatar
Mr. Blue Man
1.8 quarts from high to low I beleive.
Old Jan 12, 2004 | 12:51 AM
brothervoodoo's Avatar
RainMan is Back
Between the low and high hash mark it only takes me 1 quart.
1.8 quarts seems high to me.
Old Jan 12, 2004 | 01:00 AM
sferrett's Avatar
Whaaaa?
If the manual is to be believed, it's stated on page 8-10:
"The distance between L and F on the dipstick represents the following: 1.7L (1.8 us qt, 1.5 imp qt)"
Old Jan 12, 2004 | 01:25 AM
i3man's Avatar
I was about 1/3 below the high mark, I added 1/2 quart, and now I'm about 1/4 inch above the high mark.
Old Jan 12, 2004 | 01:27 AM
RainMan is Back
hmm.. really, maybe I have one of those recalled dipsticks I heard about long ago.. I dunno? Maybe the book is incorrect and that is why some people were getting overfill on oil when at the dealer... mine seems to hit the full mark with only 1 quart, i've done it a few times.
Old Jan 12, 2004 | 01:28 AM
RainMan is Back
Well, it seems your 8 fills with 1 quart like mine... I would fix that overfill though.
Old Jan 12, 2004 | 01:30 AM
i3man's Avatar
Today I had planned to change my oil but when I got started, I realized it wasn't going to be as easy as I thought. I had all the right tools and since I'm a pretty thin, I thought I'd slide right under there...NOT :p
I was going to use one of those disposable oil boxes to drain the oil in and that thing barely fits under the car too. So I ended up just checking oil and topping it off.
I think I'm going to go buy me some front wheel ramps to get the front up another 6-8 inches or so. I guess I'll try again next week.
Old Jan 12, 2004 | 01:32 AM
i3man's Avatar
How do you fix an overfill w/out draining? Go do some burn outs and redline it for about 1/2 and hour :p
Seriously, will the 1/4 inch overfill cause any problems? If anything happens I'll just blame the dealer and say the car came with too much oil
Old Jan 12, 2004 | 01:41 AM
takahashi's Avatar
I think someone said overfilling is no good. Last time I check it was 1/4 down from H mark... the dealer told me to leave it until it drops below the half way point
Old Jan 12, 2004 | 01:45 AM
i3man's Avatar
If overfilling is bad, they should say in the manual to wait until it gets to the low line before adding oil...instead of making you paranoid that the 8 drinks oil faster than vampires drink blood.
I would think from a safeguard standpoint that not just Mazda, but any automaker, would not allow engine in an amount that would be harmful to the engine to be filled. By that I mean the oil fill spout would start overflowing.
The automaker cannot control how low a car owner runs the oil level but they surely can control how much oil can safely go into the engine by creating an overflow.
Old Jan 12, 2004 | 11:39 AM
Rick's Avatar
If I remember correctly,the oil plug is located on the right side center of the oil pan. I do not think that much oil will drain out with the front end up.
Old Jan 15, 2004 | 10:57 PM
w2aew's Avatar
www.dorkage.com
I found that simply raising the car by 1-1/2" was enough to fit my drain pan underneath, and kept the car reasonably level to get good drainage. Simple to do, just drive up on a pair of 2x4's.
Old Jan 15, 2004 | 11:42 PM
B-Nez's Avatar
I don't have to raise mine, and I'm not as thin as I used to be (I'm about 145 nowadays, sigh...) Anyway, as for drain pans and fitting, take a look here . Scroll down to the photo depicting all of the tools and Saran-Wrap.
mr. GrandGame
Sep 9, 2025 10:41 PM
eazzyg
Oct 28, 2022 10:33 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
eazzyg
Aug 12, 2015 09:09 PM
RotaryRider
Jul 20, 2015 07:05 AM
