Koni rebuild question
Old Oct 13, 2009 | 10:30 AM
StrokerAce's Avatar
I'm unclear on what the options are for rebuilding the Koni's to be double adjustable. Where are/can the adjustments be made? Particularly the rear. Can the rebound and compression adjustments be made from below without any dis-assembly?
Old Oct 13, 2009 | 10:41 AM
chiketkd's Avatar
Row faster, I hear banjos
Team would be a good person to answer these questions.
Lee Grimes at Koni-NA would be able to answer them as well. If you want his e-mail or phone number, I have it and could pm it to you.
Old Oct 13, 2009 | 11:16 AM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
Rebound is on the top, compression on the side at the bottom. You will still have to pull the shock down to adjust rebound, you just wont have to pull the spring or remove it completely from the car.
Old Oct 13, 2009 | 07:22 PM
iaus10's Avatar
0110100001101001
Phil at Koni Truechoice Racing Services is another good resource. Lee Grimes is a good guy, and I've had Koni NA do a couple DA conversion/revalves... but they've never supplied me with dyno plots when I've asked.
This year, Truechoice Koni gave me everything I asked for, with less than 1/2 the turnaround time.
Make yourself some remote adjusters which fit through the factory openings in the trunk. Saves a bunch of time when you want to change rebound.
-Ivan
Old Oct 13, 2009 | 08:03 PM
May have some DAs for sale depending on how soon you're looking for them
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
GM Enthusiast
Oct 19, 2015 07:31 PM
Paul_Y
Sep 21, 2015 02:23 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
MIGhunter
Sep 5, 2015 07:21 PM
