Help!!!!! Rx8 down..houston we have a problem.
Old Oct 13, 2009 | 04:16 AM
tautona's Avatar
I have an 03 rx8 with 60 000 on the odometer. Last week i was pushing it on the highway and when i changed down from 6 to 4, it stuttered and it died. I restarted it up and it was idling poorly, and the silencer felt like it had blown a gasket.
I checked the fluids..ok. I tried driving it in the morning the following day and it felt sluggish, no power, and was idling poorly. I couldn even ecelerate without it stalling and switching off. Help. What could be the problem? It has a full service history. It was due for service in 2 weeks.
Terence
Old Oct 13, 2009 | 04:42 AM
chrisis's Avatar
it sounds like a clog CAT, but first i would check plugs, wires and coils.
do you have any check engine light?
Is it a Manual or auto?
Old Oct 13, 2009 | 08:19 AM
tautona's Avatar
it is a manual 6 speed. and yes, the engine light is on.
Old Oct 13, 2009 | 08:23 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Go get the code read at Autozone or somewhere, report back to us what the code is. However, it does sound like maybe a clogged kitty, but can't tell yet.
Give us the rest of the info as well........................how long since you had any coil/spark plugs changes etc?
Old Oct 13, 2009 | 08:24 AM
chino0314's Avatar
he already gave that info
Old Oct 13, 2009 | 08:31 AM
Mazurfer's Avatar
Really? Wanna tell me what "Full service" history means?
You think this means they changed the coils and plug wires?
I'll bet that maybe the plugs are okay(but that depends on how old they are), but what about the rest?
The CEL would tell us a lot.
Old Oct 13, 2009 | 08:36 AM
chrisis's Avatar
you may want to find the check engine code quick, because if you have clogged CAT is very expensive and if you are lucky is a guy in here selling one very cheap.
check out this: https://www.rx8club.com/rx-8-parts-sale-wanted-44/fs-%2A2005-rx8-oem-catalytic-converter-%2A-184352/
with these miles i would change coil, plugs wires anyway.
let us know how it goes.
Old Oct 13, 2009 | 08:39 AM
chino0314's Avatar
hmmm somehow i read wrong thought you asked for mileage and year of the car
i failed
Huey52's Avatar
Registered Zoom Zoomer
O2 sensor(s) and/or Cat is my bet.
I didn't know there were any 2003 RX-8's.
Old Oct 13, 2009 | 08:42 AM
Mazurfer's Avatar
i failed
I did actually, but then I edited it because I was stupid enough to not read it the first time. Think I was editing it as you were posting your response to me! So.......I fail! My bad!
Old Oct 13, 2009 | 08:43 AM
Mazurfer's Avatar
^.........yep there are some 03 build dates.
Old Oct 14, 2009 | 06:32 AM
Huey52's Avatar
Well of course there were some built in '03, but that makes them the 2004 model year.
Old Oct 14, 2009 | 04:18 PM
Kaiser bun's Avatar
Yeah Sioux Sioux!!!
I thought that there acctually was an 03 in australia? dont quote me on that though.
Old Oct 15, 2009 | 10:25 AM
tautona's Avatar
i got the advice you guys gave me. i am looking at a problem of coils, plugs and plug wires. where would you recommend i get these. the prices i got here are crack prices.
part numbers; 1. coil set h; N3H118140B *1
2. coil ignition; N3H118100B *1
3. mplug spark; N3Y48110A * 2
4. spark plug; N3Z118110A *2
PLEASE HELP.
Old Oct 15, 2009 | 10:35 AM
cornholio135's Avatar
SARX
Where are you located????
plugs you can get from sparkplugs.com come in set of 4 2 trailng, 2 leading
colis,wires from finishlineperfromance.com
Old Oct 17, 2009 | 06:15 AM
tautona's Avatar
thanx again.
by the way, i am in Africa, Botswana. Its right next to South Africa.
my RX8 is a 04 model by the way.
what else should i change after the coil, plugs and wires?
Old Oct 17, 2009 | 07:37 AM
newguy's Avatar
zoom fuckin zoom
Originally Posted by tautona
thanx again.
get access to an OBD-2 scanner/code reader, if the check engine light is a "cylinder missfire" coils are probably the problem but Id change wires and plugs as well w/ your mileage and your cat should be ok, if however your read a rear oxygen sensor fault code your cat could be bad.
One thing not to do is keep running it with a miss, I did this 2 days ago, what you end up doing is dumping gasoline into the cat and it ignites in there heating the cat to unsafe levels, mine was glowing cherry red around the 02 sensor bung and flanges but thanfully it seems to be OK and I never had a fault code for the 02 sensor which is still working. I just deep fried that bitch for 20 minutes
Old Oct 17, 2009 | 08:15 AM
rodjonathan's Avatar
silent assasin
lol i thought you were in houston
Old Oct 17, 2009 | 05:41 PM
SARRAS's Avatar
Sydney, Australia
Nah that's only in America - In Australia if it was Built in 2003, then its a 2003 model - plain and simple no mucking around.
Old Oct 20, 2009 | 11:17 AM
ChesteRx8's Avatar
not to thread jack. my rx8 2004 yesterday, when i started the car it didnt start.. but then i tried it again and this time i pump the gas and it started!! this morning it went fine and back to normal. what could be the problem here? i recently changed my sparkplugs. but the check engine light is still on!
Old Oct 20, 2009 | 11:32 AM
alfy28's Avatar
lol me too. i was like, where in houston should i head to lol
Old Oct 20, 2009 | 06:13 PM
Mazurfer's Avatar
Well, the front plug wire is notorious for working loose at the plug, so check that. Then go get the code read somewhere and come back and tell us what the code is. We can make guesses all day long.
Old Oct 21, 2009 | 05:32 AM
tautona's Avatar
i got an email today telling me that it sounds like the problem is a broken apex seal. i have more faith in what you guys say, that anybody else. could the seal be broken? from everything I have said?
what usually happens if your car breaks the apex seal?
by the way, something else to note; the leading plugs were soaked in gas when i removed them in the morning.
Solidtrance
22
Sep 4, 2015 12:47 PM
Tailicus
Sep 2, 2015 12:38 PM
Stubbs
Jul 28, 2015 09:23 PM
Kangarhew
Jul 18, 2015 08:27 PM
Belalnabi
Jul 17, 2015 07:48 PM
