NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
Compression checker...
Old Oct 12, 2009 | 06:42 PM
kersh4w's Avatar
Hit & Run Magnet
does anyone have one? its possible my motor may be toast.
Old Oct 12, 2009 | 07:20 PM
DJ.NADA's Avatar
ROTARY UNITED (RU.) TM
You can buy one at autozone for $30. you can use the one for piston its the same ****. compression tester works the same if number reach 90 or over compression is good. under 90 it suck / under 60 really sucks bad. my motor when 2 weeks ago i went and brought a compression tester for piston engine. it works good......http://www.youtube.com/watch?v=9U8iNb21arw
Old Oct 13, 2009 | 10:48 AM
first-rotary04's Avatar
wankel? what's that?
hey kersh,
if you decide to use the piston engine one, let me know I have one that you can use.
Old Oct 13, 2009 | 10:54 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Just got me to thinking if Twisted is still selling this one and how it's working out.
Guess I need to go read through the thread now.
https://www.rx8club.com/showthread.p...ression+tester
Old Oct 13, 2009 | 11:41 PM
kersh4w's Avatar
Hit & Run Magnet
isnt that one $200?
jaime, did you buy a piston engine compression checker at autozone?
Old Oct 14, 2009 | 05:52 AM
Originally Posted by kersh4w
isnt that one $200?
nah, I bought mine a while ago from somewhere else.
BTW, Autozone doesn't sell snap on tools.
Old Oct 14, 2009 | 07:38 AM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
Works great - purchased one of the first and have been very happy with it. It does all three positions - not sure how to do that with a piston unit.
Old Oct 14, 2009 | 12:50 PM
NgoRX8's Avatar
You essentially watch the needle bounce in each chamber. Need to remove or hold open the valve that holds the pressure in. Problem is you don't get an RPM reading so you can't always correlate it to the condition of your engine.
Old Oct 14, 2009 | 11:43 PM
RX927's Avatar
Embrace The Sparkles
^^^ He speaks the truth. The piston compression tester doesn't account for RPM which makes a world of difference in numbers. Plus removing the Schroeder valve can make it messy/inaccurate.
Be 100% and get it done by mazda or buy a rotary specific one.
I have a Mazda rotary compression tester but you would have to come up to North Jersey to use it. No charge of course.
Old Oct 15, 2009 | 12:00 AM
hakuna matata!
^ you do?? wtfux!
i wants your services
Old Oct 28, 2009 | 05:42 PM
I just bought the Rotary Diagnostics multi-rotor tester. I wanted more than just a peak measurement tool. This one runs on a laptop and displays the full compression cycle curve, which tells you a lot more about what's going on inside the engine
http://rotarydiagnostics.com/
Old Oct 28, 2009 | 05:45 PM
hakuna matata!
/\ thoughts?
Old Oct 28, 2009 | 06:14 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Kersh, you can use mine. Just swing by and pick it up. Or we can check it here on the weekend.
Old Oct 28, 2009 | 06:45 PM
kanundra's Avatar
cone killer
Sorry to hear about your motor, I've been meaning to check mine. It feels strong but you never know.
gwailo
May 14, 2024 06:57 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
