Leak Testing?
Old Oct 11, 2009 | 08:59 AM
Rote8's Avatar
Leak Testing?
I have seen plumbers testing pipes.
An engine is an intake pipe connected to an exhaust pipe with interesting bits in between.
A forced induction system should not leak pressure.
Can we test an intake track the way plumbers do; with two plugs and air pressure?
My thought:
Remove throttle body and disconnect the midpipe connection to the exhaust manifold.
Insert the plumbers test plugs on both ends and inflate them, then pressure the "pipe" to about 5 PSI and listen for leaks.
I think any intake leaks would be obvious; but would the test break other things?
Any bad fuel injector grommet or a gasket leak would show.
Old Oct 11, 2009 | 10:42 AM
gregs's Avatar
Pull My Finger
i just did mine and used my air hose connected to the jet air fuel mix hose..i didnt plug the exhaust being i had a second person being able to listen it loses pressure so quickly
Old Oct 11, 2009 | 05:07 PM
Rote8's Avatar
Find any leaks?
mdl0209
May 23, 2019 05:46 PM
DG07
Sep 28, 2015 10:58 AM
