Cause for low torque?
Old Jan 11, 2004 | 02:11 PM
Haris's Avatar
Anybody know why RX8 has little torque compared to most piston engines? Is there any possible solution like to make 250 HP and at least like 200 ft.lbs. for the RX8's rotary engine or is it just impossible without turbo? Would lighter rotors make any extra torque?
Old Jan 11, 2004 | 04:23 PM
renesis_turbo's Avatar
I believe the "Stroke" in a piston engine helps create the greater torque... a rotary by design doesn't have that kind of stroke in its eccentric movement. A more erratic eccentricity would probably help, but it would suffer in its ability to rev high. However, for what torque it does have, there is a rather wide torque band compared to a piston engine. Anyone else have some ideas?
Old Jan 11, 2004 | 05:17 PM
5Gen_Prelude's Avatar
The Geo Metro sized engine is one of the big reasons. While lower displacement engines can make up HP by spinning faster than typical higher displacement engines, torque seems to have a direct relationship with the size of the engine. If you compare an equivelant displaced inline 4 between Honda and GM for example, the torque ratings are very similar - what makes Honda's better is its ability to make more HP at higher RPM's.
Old Jan 12, 2004 | 10:47 AM
ChrisW's Avatar
The Renesis is effectively a 2.6 L so you wouldn't expect it to produce loads of torque. The cure for low torque is low gearing - this gives you more torque at the wheels (which is what really counts). The RX-8 has pretty low gearing, if you ignore 6th gear.
The price you pay for the low gearing is a higher revving engine. For a piston engine this is not always a great solution as it means much more noise and vibration (especially for a 4 cylinder). But it's fine for a rotary because they are so smooth anyway.
Old Jan 12, 2004 | 11:32 AM
paradigm's Avatar
Seen Your Member
Torque is really nothing more than force. Force is mass x accelleration. The pistons, rods, and crankshaft in a big v8 weigh a LOT more than our 2 rotors and e-shaft. When they get moving they can produce more force due to the sheer mass. Combine this with big displacement, the ability to move lots of air really fast and the ability to accellerate those heavy parts and you get lots of torque.
A good way to think of it is this. Let's say I had two viper engines. 500 cubic inch V10. I leave one internally stock. The other I replace all of the internals with parts that weigh half as much, but can rev twice as high. At 4000 RPM's, that stock viper engine, with the heavier internals, will be producing as much torque as our custom engine would produce at 8000 RPMs.
However when it comes down to it, torque is just a pretty number that sells products. It's really good for smoking tires and breaking driveline parts though. There was a really good writeup that I saw that explained all of this stuff in all of it gruesome mathematical glory. There's a lot of sites that explain the horsepower v.s torque relationship, how torque is really only important as a factor of horsepower. Just do a google search for something like "horsepower vs torque". It's kinda funny how many sites there are that treat torque as the end-all of racing. Coincidentally those sites are run by v8 guys. So before you bash me for saying that torque on it's own is nothing...go out there on the internet, find the info and do your own math, and make your own decisions about it.
Old Jan 12, 2004 | 12:39 PM
AlexCisneros's Avatar
Follow this link:
http://www.yawpower.com/tqvshp.html
It says it all
Old Jan 12, 2004 | 01:31 PM
wakeech's Avatar
mostly harmless
ok, wow. a few weird ideas out there.
for you guys thinking that it's a 2.6L, even when measuring torque at the crank, i'm sorry to report that you're incorrect my friend.
when you're measuring on a dyno how much force per turn you're making, then multiplying by the speed of the engine to get power, you're not counting two turns together, it's just the one. so, yes, the 1.3L displacement has a lot to do with it.
another idea which hit the mark is the eccentricity: the longer lever on presumably equal force generated by combustion would give more torque at the flywheel, but would be rpm inhibitive (that's why, along with a few other factors, why strokes in high horsepower machines are usually fairly small).
just so we don't have any more physics 11 mix-ups, it's not F = M * A in this case (the relationship derived from A = F/M), but force = pressure * area, initially, which is why displacement has such a huge todo about making power.
there are two ways you can do it, it being make power. you can take a small force (say, the force generated by an all-motor 1.0L I4) and apply it repeatedly at a very high rate (rev it up to 13 000 rpm), thus equalling x amount of power. or you can take a large amount of force (like a 3.5L V6) and multiply that at a lower rate (say, 6 500 rpm), to make y amount of power. which is a better way?? well it depends on a host of other factors.
anyways, that was a little off track.
the reason the 13B-MSP has low torque is because of its small displacement, and that it only has a very small stroke (15, or 25mm or something... the difference between the centre of rotation and the centre of the e-shaft), although this lever is acted on for 270* of rotation instead of the normal 180*. blah blah blah, off track again.
anyways Haris, you could make a rotary engine which made only 250hp on 200ftlbs of torque, but it'd be... well, yeah. a 3 rotor tuned to make all low-end horsepower would do just the trick.
what you have to recognize though, is that not only is this terribly wasteful (that's a very low hp number for a 3 rotor), but it's not the torque that matters anyway, but only the horsepower (as illustrated in Paul's article that AlexCineros linked to) in the lower reaches of the rpm band.
and as for lighter rotors, no, they wouldn't help in making more torque, but if applied correctly would be an important part in making very high horsepower all-motor, with the revs.
Old Jan 12, 2004 | 02:14 PM
Haris's Avatar
So can rotary be used in trucks and have like 15,000 lbs. towing capacity, or is it just basically for sports cars?
Old Jan 12, 2004 | 02:28 PM
rotarygod's Avatar
I'm just going to cut and paste my response to the why 1.3 thread. Here is everything you ever wanted to know in an extremely long post.
First of all you may just want to print this as it is really freaking long!
I wrote this last summer for another forum so here it is reposted here.
The rotary engine is a 6 stroke internal combustion engine. I know, people will probably start screaming at me for this so lets get into a little explanation as to why and how typical mathematical formulas for piston engines don't work.
First of all, lets get the terms "stroke" and "cycle" defined (Some of you get your heads out of the gutter!) since everyone commonly gets these terms interchanged. They are not the same thing. Every internal combustion engine whether it is a 2 stroke, 4 stroke, diesel, gasolines, propane injected, etc. is a 4 cycle engine. Why? All of these engines take in air (intake), compress the air (compression), ignite the air whether by spark plug or glow plug (ignition), and expell it out the tailpipe (exhaust). There you go 4 cycles. Simple isn't it. The term "stroke" in this context refers to how many times the crankshaft or eccentric shaft makes a piston go up or down to complete the cycle.
The connecting rods and pistons are just an extension of the offset lobes of the crankshaft. This is also true in regards to a rotor and eccentric shaft. When the lobe rotates upward, the piston goes up. When the lobe rotates down, the piston goes down. Every time it moves one way is considered a stroke. In a 2 stroke engine, all 4 phases or cycles of the combustion process are completed in only 2 strokes of the piston, 1 up and 1 down. This is only 1 complete revolution of the crankshaft. In a 4 stroke engine, it takes 4 strokes of the piston, up, down, up, down to go through the complete combustion process. This is 2 complete revolutions of the crankshaft. It's all a very simple mathematical relationship.
Now lets go look at the workings of a rotary engine. If we look at a rotary engine eccentric shaft and compare it to a piston engine crankshaft, we see essentially the same piece. Both have lobes and because of this both engines will have a stroke length, even the rotating rotary. It doesn't matter if it is a piston going back and forth or a rotor going round and round. The crankshaft motion remains the same. On a rotary engine, the rotors are spinning at exactly 1/3 the speed of the eccentric shaft. From the time that the air entering one chamber goes through the combustion phases to the time it leaves the engine from the same chamber (rotor face), the eccentric shaft has gone around 3 complete times unlike a 4 strokes 2 times or a 2 strokes 1 time. If we do the math we see that the lobes of the eccentric shaft must have gone up and down 6 times (up, down, up, down, up, down). Since it does this process the exact same way every time for every rotor face, it is a 6 stroke engine. Thats right the rotary engine is a 6 stroke! Do not confuse these strokes with the 4 internal cycles that every engine has!
Let's sum this up in a simple chart to visually explain how this works.
2 stroke engine (up,down) - 1 complete crankshaft revolution
4 stroke engine (up, down, up, down) - 2 complete crankshaft revolutions.
6 stroke (rotary) engine (up, down, up, down, up, down) - 3 complete crankshaft (eccentric shaft) revolutions.
See a pattern? All of these engines though are still 4 cycle engines! They are different stroke engines though so the amount of work they do per time is very different. A 2 stroke engine does twice the work per amount of time that a 4 stroke does. Don't believe me? Go race 2-80cc motorcycles, 1-2 stroke and 1-4 stroke and see who wins! This must mean that the rotary engine does the least amount of work per time than both other engine types. Yes it does. But, unlike a piston engine, it uses 3 sides of it's piston (rotor) at a time. In reality it makes no difference if we have 1 rotor with 3 usable faces or 6 rotors with 1 usable face each as in a piston engine.
Here's a little info on how to properly figure out displacement on a rotary engine. Everyone argues that it is really a 1.3 liter while others argue that it is really a 2.6 liter engine. They are both wrong! If we look at how a piston engines volume is calculated we arrive at a displacement based on total swept volume of every piston added together. It is not based on rpm. On a rotary, displacement is figured using one rotor face in one complete revolution then multiplyed by 2. This only leaves the total for 2 combustion chambers though and the rotary has 6! Since the volume of a 13b rotary is rated at 1.3 liters (only 2 combustion chambers) it really adds up to 3.9 liters!!! I can hear it now, "...but we only have 2 rotors!" So what. Like I said it makes no difference if there are 2 rotors with 6 faces or 6 rotors with one face each. the total is always 6 and the base numbers are only based on 2 chambers. The rotary merely does 3 times the work in a package 1/3 the size. It's just a 3.9 liter engine crammed into a 1.3 liter body. Just so none of you start a fight over this, I will explain this later so don't chastise me yet!!!
In case anyone is curious I did some math to determine what the 13B rotary would be sized at if it were a piston engine. The results are pretty neat. First of all the rotary would be a 3.9 liter, 6 cylinder engine. It would be a 6 stroke. Each cylinder would be 6.54" across (damn big piston!) but the stroke length would only be 1.18" in length peak to peak. Not much there. Interesting isn't it. Now just imagine a way to make all this work with only 2 intake runners!
In all fairness to the terms I have used, the word "stroke" can be interchanged with the word "cycle" since both technically have the same definition. The terms "periods", "quarters", or "phases" can also be used correctly. I merely wrote it the way I did to get a certain mental picture going.
I have already dealt with why the rotary engine is really a 6 stroke engine and why displacement is really 3.9 liters and not 1.3 liters. Now I need to explain why the rotary engine doesn't have the torque or horsepower of a good 3.9 liter engine or why it doesn't get the gas mileage of a 1.3 liter engine. The world has always wondered so here's why.
Remember that I stated that the true displacement of the rotary engine, if figured out according to the way piston engine volumes are calculated, is according to the total number of rotor faces and not the number of rotors, nor does it have anything to do with rpm. This added up to 3.9 liters for a 2 rotor 13B engine and not the published spec of 1.3 liters. They just crammed all 3.9 liters into a 1.3 liter body. If the engine is really a 3.9 liter engine then why doesn't it have the low end torque of a 3.9 liter engine? This has a very simple answer. Lack of leverage. OK, what the hell does that mean?
First of all we must figure out what a lever is. It is a device that multiplies mechanical advantage over an object to do the same amount of work with a smaller amout of effort. Another way to look at it is to do a greater amount of work with the same amount of effort. It's the same thing. Let's look at leverage differences as an example in a piston engine.
What happens to a piston engine when we make it a "stroker"? Ignoring a host of other variables, it gains torque. It also gains horsepower but they are both a fixed mathematical ratio between each other and you can't increase or decrease one without the other. Why did it gain torque? Greater mechanical advantage or leverage over the crankshaft. The reason being is that on a stroker crankshaft as opposed to the stock crankshaft, the lobe centerline is farther out from the rotational centerline of the crankshaft. This increases the leverage that the piston has over the crankshaft. Don't believe me? Try this. Get a short pole and hold it at the end straight out away from your body. Attach a 10 lb weight to it exactly 1 foot away from your hands. The weight is exerting exactly 10 ft. lbs. of torque on your hands. Now move that weight out away from you to 2 feet away from your hands. Now the same weight is exerting 20 ft. lbs. of torque on your hands. You have just in essence made a "stroker". Now let's get back to the engine.
Now we know that the greater the stroke length, the greater the engine torque. As I stated, the rotary engine only has an effective stroke length of 1.18". My weedeater has that! There is not very much mechanical advantage over the eccentric shaft. This still doesn't explain everything though.
Remember, I stated that if the 13B rotary were a piston engine it would have pistons 6.54" across. Now we just discovered another enemy of efficiency, flame front speed. When the spark plug ignites the mixture in the engine, it doesn't just ignite everything all at once. The spark ignites at the plug and then has to travel outward away from the plug at a certain rate of speed. While this only takes milliseconds, this amount of time gets more critical the higher the rpm gets due to the shorter amount of available time. The result is that as rpm's rise efficiency decreases. The larger the area of the piston, the farther the flame front has to travel and the greater the chance that all of the mixture does not get ignited when it should. Just can't go far enough fast enough. Todays rotaries have 2 sparkplugs per chamber to help combat this problem. Varying their ignition time in relation to each other even helps somewhat with power and emission. That's right they don't necessarily fire together even though they are in the same chamber. This can get complex so I will not deal with it at this time. Some race engines even have 3 plugs per chamber to improve efficiency and ignition wave front speed. On piston engines, Mercedes has capitalized on this and uses 2 plugs per cylinder in some of their higher end cars. Do they know something others don't?
There is also one more aspect that affects it. Remember that the rotary is a 6 stroke engine. A 2 stroke engine does twice the amount of work per amount of time that a 4 stroke engine does. A 4 stroke engine does 50% more work per amount of time that a 6 stroke does. The rotary engine does less work per eccentric shaft rotation than your typical 4 stroke counterpart. All of these characteristics combine to make an engine that has relatively little low end power and needs to be revved up to be truly powerful.
I make it sound like we should have less torque than a 1.3 liter engine due to the above reasons. This isn't true though. Remember that we still have a 3.9 liter engine even though it only uses 2 lobes on the eccentric shaft. We should not expect to develop the torque numbers of a 1.3 liter engine. It should settle in somewhere around 50% less than a 3.9 liter engine which would put it around equal to a 2.6 liter engine in power.
These traits of the rotary engine are also why the engine gets worse gas mileage than your typical 1.3 liter engine. Hell it gets worse gas mileage than your typical 2.6 liter engine. Another aspect that affects this is port timing and duration. If we had a piston engine of 2.6 liters in size that had the same intake and exhaust timing as the rotary then it would get comparable gas mileage to the rotary. The 12A/13B rotary though have much more exhaust duration than intake duration due to the peripheral exhaust port location. This contributes to several factors which decrease efficiency. Exhaust gas dilution is one of them. For each stroke there is a small amount of overlap. The exhaust ports and intake ports are open to the same chamber at the same time for a short amount of time as measured in degrees of eccentric shaft rotation. The higher the rpm's the less important this becomes since air velocity will generally keep the gasses where we want them to go. At lower rpm's though the intake and exhaust air velocity is not very high. This will cause some exhaust to go back through the combustion chamber again. When this happens volumetric efficiency decreases and there is less room for fresh air to fit inside the combustion space. Also this recirculated exhaust gas is very hot. A hotter air molecule is larger than a cold one which means a fewer number of molecules can fit in the same area per amount of pressure exerted on them. Another aspect of the rotary's peripheral exhaust port configuration that contributes to less low end power and greater fuel consumption is its incredibly long duration or time it is open for. Unfortunately when we make the port bigger we also change it's timing. We don't have the luxury of being able to mill out a head to accept a larger valve while still being able to use the same cam. The timing is really only optimized for high rpm use. We are leaving it open for too long which gets back to the whole overlap problem. Again, all of this is just a generalization and can be affected by how well the intake and exhaust flow and how well they can scavenge. The affects of scavenging, intake design, helmholtz effect, and proper exhaust design are all out of the scope of this article. So just assume it is an even world.
Luckily there is a cure for this. It is called Renesis! It is the new 13B based rotary engine in the new Mazda RX-8. The exhaust ports are no longer in the periphery of the chamber but have rather been moved to the side housings. This allowed the designers to more appropriately optimize the port timing duration. The location also allows more port area leaving the engine. So now we have more area to flow air out of faster. This new location also completely got rid of the port overlap. There is actually 64 degrees of dwell. This amount of dwell was originally greater in the early test engine called the MSP-RE since it had the intake timing of the '84-'91 n/a RX-7's 6 port engine. However dwell is only useful if you just have enough to get the job done but not so much that you are getting losses from it. Because of this Mazda engineers learned that they could open the intake earlier than previously and still maintain all of the other good aspects of the new exhaust layout. A bigger intake port = more time for air to enter and a greater cfm rating through the port. Less turbulence through the port as well. Less overlap gives us less dilution of the intake air and a cooler intake charge. More available room for incoming air. Volumetric efficiency increases. Since efficiency goes up, our use of gas gets more efficient. In other words it takes less fuel to do the same amount of work. The result, better gas mileage. With todays gas prices this is a very welcome thing. The efficiency increase also means that emissions characteristics are also improved. Another bonus with todays laws concerning air quality.
So after reading this you are probably wondering why in the world anyone would want to use one of these engines. First, and most obvious is size. They crammed a 3.9 liter engine, or more appropriately a 2.6 usable liter engine into a 1.3 liter body. Second, it is just such a simple design. There are only 3 moving parts. Fewer moving parts have less frictional losses. Also fewer moving parts have less chance statistically of failure. The more it moves, the more chances you have for failure. Third, nothing moves back and forth. So what? A piston stopping and changing direction exerts alot of stress on everything from the crankshaft to the connecting rods, to the pistons, to the wristpins, etc. Lets not also forget the stresses on the valves for being slammed open and shut as well as the temperature extremes they see during the combustion cycle. A body in motion tends to stay in motion. It is a very unnatural act to change direction suddenly or at all for that matter. A rotary just spins away in the same direction. Yes the lobes of the eccentric shaft do see stress but remember that we don't have very much leverage over them. The rotors are also exerting some of their rotational stress on the stationary gears as well so some stress is never transmitted to the eccentric shaft from the rotors. The lack of stroke length and pure rotational motional do make it very naturally adapted to high rpm use. If we look at really high horsepower piston race engines, their stroke length has been shortened to reduce the stresses to all of the engine components at high rpms. The last and most important reason why the rotary engine is still a popular engine despite it's shortcomings is because it is different. There is always something to be said for individuality and uniqueness. If you own a piston engine it doesn't matter how big it is or if it is made by Chevrolet or Honda. It is still the same device.
Just to shoot down right now any arguments on displacement think about this.
The 13B rotary engine is a 1.3 liter. Yes.
The 13B rotary engine is a 2.6 liter. Yes.
The 13B rotary engine is a 3.9 liter. Yes.
Notice that all of these statements are TRUE!!! That's right there is a truth to all of those statements. Go read the whole thing again. To understand why this is so, lets define truth. Truth can be defined in a couple of ways: Anything that is not false (none of those statements is) or it can be defined as: One's individual interpretation of presented facts. This herein is the source of our debate. We can't change the facts no matter how hard we try. Arguing won't do it. What is debatable however, is each individual's interpretation of facts. If your interpretation doesn't match someone else's, you argue about it.
Here are the facts: The rotary engine as rated by Mazda is 1.3 liters because each individual rotor, following one face of one rotor through the complete cycle, has a swept displacement of 654cc or .65 liters. Multiply this times 2 rotors to achieve 1.3. Since this only accounts for 2 of the total of 6 rotor faces, we multiply our answer by 3 to get an actual displacement of 3.9 liters. However since the rotary engine is a 6 stroke engine and not a 4 stroke engine since it takes 3 complete eccentric shaft revolutions to fire all faces instead of the typical engine's 2, it only does 66% the work of a 4 stroke 3.9 liter engine. Calculating for this we divide 3.9 by 1.5 to get a total of 2.6 liters equivalent work to a 4 stroke piston engine. All of this from a 1.3 liter in physical size package.
No one can argue that this is not correct and any response saying otherwise will have been explained by what I just said. Any debate will only focus on one aspect and not the total facts.
Just to put a cap on this whole thing: If at any time you try to calculate proper sizing for a turbo, intake manifold runners, intake plenum size, exhaust size, etc, and you try to use the 1.3 liter number in your equations, you will be way, way, way off!!!!!!!!! There are only 2 ways to flow more air: increase displacement or increase rpm. A 1.6 liter Honda engine doesn't flow anywhere even remotely near what a 13B (1.3 liter) flows per the same rpm. Just some food for thought.
Rebut that! I need the entertainment! Hehe!!!
If you got this far, give yourself a cookie! My carpal tunnel syndrome is starting to get bad
Old Jan 12, 2004 | 04:58 PM
neit_jnf's Avatar
I truly believe all of this is wrong. The heavier components have more inertia and are more difficult to move, thus have more losses. I think that the custom engine with 50% lighter internals (Titanium?) would give higher torque at all rpm ranges (ignoring a lot of other variables and assuming the components are equally strong as the stock heavier ones). Any expert care to comment? Rotarygod?
Oh and I already read your previous post on the other thread, Rotarygod. Very insightful. I read it againg here, I have a headache! :p
Old Jan 12, 2004 | 05:14 PM
rotarygod's Avatar
Give me your address so I can send you a packet of aspirin!
I'll respond to the rest after I think it out well. I don't want to contradict myself but I do also find it to be wrong.
Old Jan 13, 2004 | 12:43 PM
GooOnYou's Avatar
Gig 'em
I'm not sure how this relates to the actual reason why we have low torque, but I have a theory. I do know that torque doesn't equal mass times acceleration nor pressure times acceleration.
Torque is equal to the moment of inertia times the angular acceleration. The moment of inertia is equal to mass times distance squared. In the case of a piston engine (a uniform rod), the moment of inertia is 1/4 times the mass of the rod times the distance from its center of mass to the edge squared. Therefore, the mass and the size of the pistons probably have a lot to do with torque. Also, the sheer number of pistons should add to the total torque on the crankshaft.
As for the rotary, a wankle is similar to a uniform ring which has a moment of inertia of MR^2 instead of 1/4*MR^2 like the rod (M being mass and R being distance). It would require quite a bit of calculus to determine the exact moment of inertia of a wankle, but if you follow this logic, then a wankle should have a higher moment of inertia than a piston and therefore more torque. However, it comes down to quantity over quality and most piston engines have more than two pistons.
I'm not sure if my logic is correct, but that is what my mechanical physics class at Texas A&M has taught me.
Old Jan 13, 2004 | 01:46 PM
neit_jnf's Avatar
You have to take into account that even while a lot of mass (pistons, rods) will help the engine work while going down, it will actually make the engine work harder when pushing them up and suddenly changing direction. Remember Newton? A mass (piston) will keep going in the same direction unless a force is applied to it; the more mass, the more force it needs to move and change direction. Piston movement is completely linear and crankshaft movement is completely rotational, the rod's movement is more difficult to analyze. While the crankshaft will want to keep spinning, the constant change in direction of the pistons keep it from doing it.
Old Jan 13, 2004 | 05:42 PM
r0tor's Avatar
I'm going to play captain obvious here...
the rotor/eccentric shaft movement effectively creates a 3:1 gearing... or the eccentric shaft spins 3x faster then the rotors. Using the laws of physics and conservation of power, if you increase the speed by 3x through gearing you just decreased the torque by 1/3.
Old Jan 13, 2004 | 07:45 PM
rotarygod's Avatar
You guys need to think a little more simply here about torque vs engine parts weight. Try this little experiment. Go out to your vice and clamp a 1 ft long rod in the vice. Now attach a 10 lb. weight to the end of the rod. You have 10 ft pounds of torque being exerted on the vice or you can do it with a 10 pound rod with a 1 lb. weight. This is only true if the rod weighed nothing. If the rod weighed 10 lbs then the longer rod would "effectively" add more weight since more of the weight is farther out from the centerline. Both setups would weigh the same but the one with the greater amount of weight farther out would appear to the vice as being heavier and in turn exerting more torque on the vice. Remember that torque has absolutely nothing to do with movement. Some of you guys think you know where I'm going with this don't you? However just as a heavier rotating assembly is easier to move downward in stroke it is also harder to move upwards as well. It's that whole gravity thing that everyone talked about in school. You need to remember that torque is affected by many things. Displacement is one very important aspect but its leverage on the crank is also very important. While the weight of the components will affect it some, halving the weight will not yield half the torque. This would only be true if we also halved the combustion. Weight will affect it some but you probably won't feel as if you've lost torque. In fact the result will be that it feels more powerful. Remember that all that extra weight also takes power to move. Remember again that torque has nothing to do with movement however movement is a funtcion of horsepower which is in a fixed relationship with torque. Less weight is easier for an engine to get moving and therefore there is more usable power. The amount of air in the combustion chamber and the compression ratio also affect how hard an engine is to turn. A higher compression ratio will yield a higher torque. Weight is a factor but you actually want less weight to get more power. Also remember that a different intake or exhaust will tune for more power/torque at a different rpm. There are too many variables to just base speculation off of just one thing. Engine designers want to get lighter and lighter assemblies. This builds horsepower and makes you much faster. It is also much less stress on engine internals. Maybe a small amount of low end torque is lost but then again it did take power away to get that extra weight moving so maybe not. It is not a set relationship that torque is halved if weight is halved. That is just plain wrong. It is kind of funny that if more weight were so important then why do lighter flywheels give more wheel horsepower on the dyno and make your car accelerate faster? Remember that since torque and horsepower are a fixed ratio that if the car is faster and shows more power, it can't have less torque. Even if it does, it will be very low in the rpm range and not worth worrying about. You would think that everyone would want a heavier flywheel for street use wouldn't you? Before anyone says that they do, while true it is only because it is easier to drive since the engine does not rev up or down as fast. This leads to smoother shifts with less rpm loss in between them but is not due to torque. Ever weighed an automatic cars' starter wheel which would be the equivalent? It is pretty damn light. That's my take on it. The lighter the better.
Old Jan 14, 2004 | 11:24 AM
Shard's Avatar
I can tell you are getting a lot of your information from the yawpower article but torque definately has a lot to do with movement. Without an angular acelleration, there can be no torque. That I am 100% positive about.
Inertia is the property of an object to resist change in motion. What your talking about with the 10lb weight on the end of a pole is inertia. An increase in inertia will increase torque. Inertia is completely independent of motion.
I do agree that if weight is halved than torque will not be halved because there are more factors than just weight at work here.
The lighter flywheel as you said will cause the engine to rev up faster which would increase angular acelleration and lead to more torque that way. As i said its not just weight at work here.
I believe that the pistons are the means of acellerating the connecting rods and the moment of inertia of the crankshaft combined with that acelleration provide you with your torque. Factors such as distance from the center of mass of the crankshaft to connecting rods, the mass of the crankshaft, and the acelleration of the connecting rods make up torque. This seems like it would make the most logical sense. I was wrong earlier when trying to find torque by taking into account the inertia of the pistons themselves.
This is the same person as GooOnYou fyi.
Old Jan 14, 2004 | 11:58 AM
neit_jnf's Avatar
The pistons are there to convert the pressure of combustion into a linear force that is transmitted thru the conn rod to the crankshaft and converted into rotation. The mass of the piston actually robs power, that's why manufacturers try to go as light as possible while retaining strenght.
Rotarygod, thanks for your reply. It's a more elaborate way to explain what I already said. :D
Old Jan 14, 2004 | 12:05 PM
edit: to remove the egg from my face. what was i thinking?
Old Jan 14, 2004 | 12:17 PM
Shard's Avatar
nope torque is just the meaurement of the force. it is not a measure of distance or time and neither of those figure into the measure of torque
Do you know what force is? Its a mass times acelleration. Acelleration is distance divided by time squared which incorporates both DISTANCE AND TIME. You contradict yourself.
As for neit, he just restated what i said.
Check this article out.
http://science.howstuffworks.com/fpte3.htm
Old Jan 14, 2004 | 12:32 PM
Shard's Avatar
Oh and the moment of inertia times angular acelleration is equal to the force times distance which both are ways of finding torque.
MR^2*(A/R) = MAR
MR^2 is inertia
A/R is angular acelleration
MA is force
R is distance
Cancel one of the Rs from the left side because you have R^2/R and you get MAR = MAR.
Lesson in physics is over.
Old Jan 14, 2004 | 12:57 PM
sorry there, i lost my mind. i edited my post to reflect that. T is a measure of rotaional force so of course it incorporates distance and time. i'll try to figure out what i meant to say and state it again later.
Old Jan 14, 2004 | 12:58 PM
GooOnYou's Avatar
Gig 'em
No problem. Physics is my territory so I love an in depth discussion about this kind of stuff :D
Old Jan 14, 2004 | 02:24 PM
neit_jnf's Avatar
If force and torque require movement, then I don't apply any force to the ground while standing still... (Yay! I don't weight anything!); a mechanic doesn't apply any force/torque while trying to remove a very tight bolt or nut... hmm, think about that. How about force distribution in buildings, bridges, beams, etc., nothing is moving.
A force and therefore torque (force times torque arm length) can be applied without any movement or distance been involved. When a force or torque causes something to move it is doing Work.
We all need to review our Physics classes
Recheck this article out.
http://science.howstuffworks.com/fpte3.htm :D
Old Jan 14, 2004 | 02:41 PM
right-
Main Entry: 2torque
Function: noun
Etymology: Latin torquEre to twist
Date: circa 1884
1 : a force that produces or tends to produce rotation or torsion
so it doesn't have to be moving, it is used as a measure of the force if it did cause movement or that would be required to make something move. you don't have to have movement to have force but you need to have the potential for a rotation to have torque. i believe that is what i was trying to say earlier. and if i am right this time than it is most definetly what i meant.
Old Jan 14, 2004 | 02:52 PM
GooOnYou's Avatar
Gig 'em
Anyway, back to the original question. Reasons why the renesis could create less torque:
1) if it has a crankshaft of smaller mass compared to that of a high torque piston engine.
2) if the distance between the center of mass of the crankshaft to the perpendicular component of centripetal force acting on the crankshaft (aka the connecting rods) is very small. Therefore, the longer the connecting rod distance from the center of the crankshaft, the more torque. The renesis, however, does not have connecting rods. The force is acting directly on the outside of the crankshaft so the distance from the center of mass of the crankshaft to the perpendicular component of force is very small which in turn creates less torque. This i believe is the main reason for the loss of torque in the renesis.
3) another reason could be that the engine fails to put out enough force tangent to the edge of the crankshaft for it to be able to create loads of torque but i don't think this is an issue.
If i think of other reasons I will post them later.
