Mazda's own turbocharged Renesis!! Saw it at NAIAS
Old Jan 11, 2004 | 11:08 AM
neit_jnf's Avatar
Got you all excited didn't I?
It's the hydrogen powerded renesis, it can use either gasoline or H2. It's a 4-port motor with an "electric motor assist" turbocharger. It looked like a regular turbocharger to me with a turbo exhaust manifold and all, at least we know Mazda has this!
Old Jan 11, 2004 | 11:09 AM
neit_jnf's Avatar
neit_jnf's Avatar
What is this I see? :D
Old Jan 11, 2004 | 11:11 AM
neit_jnf's Avatar
Electric?? It looks normal to me, turbo exhaust manifold, oil lines, etc.
Old Jan 11, 2004 | 11:12 AM
neit_jnf's Avatar
I was so excited to be at the show that I forgot to take pictures of the whole thing... Gas tank, H2 pressure tank, H2 injectors, very interesting!
Old Jan 11, 2004 | 11:16 AM
neit_jnf's Avatar
cat
Old Jan 11, 2004 | 11:17 AM
neit_jnf's Avatar
Car looks exactly the same as stock
Old Jan 11, 2004 | 11:18 AM
neit_jnf's Avatar
side, chromed wheels!
Old Jan 11, 2004 | 11:29 AM
RX-Nut's Avatar
8 the HARD way.
Whoa... things that make you go HMMM..
Old Jan 11, 2004 | 12:07 PM
SA22C's Avatar
Oversteer = Bliss
Too bad the H2 rotary only puts out ~100 hp. Still though, it's a neat design and a step in the right direction. If the rotary engine is going to survive, it will be in hydrogen form.
Old Jan 11, 2004 | 12:19 PM
racerdave's Avatar
F125er/Future RX-8er
SA22C... with the current fuel economy of the Renesis on gas, I'd have to agree with you.
But if they can make Hydrogen work, that would be sweet indeed!
Maybe they should add another rotor.
Old Jan 11, 2004 | 02:54 PM
Gyro's Avatar
Rotary Abuser
The turbocharger for the Hydrogen design is almost mandatory to make it work in the real world. The prototype lacks power with the new fuel type and needs positive pressure in the intake to bring HP up to "usable" levels.
Its much like the analogy with diesel engines.
Diesels tend to be high in torque but low in "get up and go". That all changes with a FI.
Take Fords "Power stroke" 7.3 liter diesel (made by International).
The large displacement along with natural characteristics of diesel fuel make that engine a power house for towing and durability. However its the Turbo that makes that engine have more midrange power for around town driving.
Old Jan 12, 2004 | 07:05 AM
neit_jnf's Avatar
bump :D
Old Jan 12, 2004 | 10:01 AM
greese's Avatar
WOW! That's awesome. White paint!
greese
Old Feb 7, 2004 | 03:02 PM
wakeech's Avatar
mostly harmless
...the turbo is a wee-bit wimpy for the application, dontcha think?? if 100hp is all they're making, add more boost... espeically with the lag-reducing electirc assist on there, why not bump up the compressor size, and especially the A/R for more efficiency at higher output?? i don't see why it should be so small...
Old Feb 7, 2004 | 03:17 PM
Gyro's Avatar
Rotary Abuser
I'm far from an expert on Hydrogen fueled internal combustion engines......but
I'm sure it isnt just that simple.
Our conventional thinking regarding adding power may not apply in all areas regarding Hyrdrogen fuel.
Adding more air under pressure with FI could have more limitations than gasoline or diesel engines.
maybe also the hydrogen likes high compression......greatly limiting the amount of boost that safely can be applied.
Old Feb 8, 2004 | 12:52 PM
deadrx7conv's Avatar
I read that it was dual fuel(user selected). Drive like hell on gas(250hp) and switch to hydrogen(100hp) when in the city or stuck in traffic to help prevent smog.
A Toyota synergy hybrid drive would do wonders to the Renesis regardless of what fuel is being used.
Old Feb 8, 2004 | 12:59 PM
Mr M's Avatar
Evolution of REvolution
I'm still trying to figure out the concept behind the electric-motor turbo charger. Does anyone know who the manufacturer is - Bosch? I would love a cross-section drawing of it. Maybe the hydrogen doesn't spin it up fast enough so they have the motor - which makes it a supercharger, not a turbocharger. Freaky!
Old Feb 8, 2004 | 02:28 PM
neit_jnf's Avatar
From 1000 to 3000 rpm the electric motor spools the turbocharger, from 3000 rpm up the exhaust gases have enough energy to drive it. The electric assist eliminates the turbo lag.
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
vapor2
Sep 21, 2015 01:36 AM
czr
Sep 13, 2015 11:37 AM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
