Retard noob question (premix)
Old Oct 5, 2009 | 10:43 PM
JFranco's Avatar
Yeah I know you can throw me with whatever you have got in your hands, but here is a noob question... WTF is premixing????? does it realy work? Sould I use the same kind of oil that is in the engine??? Thanks...
Old Oct 5, 2009 | 10:45 PM
RyansRx8's Avatar
Brettward is/has a G
ha loser what a retarded noob question lol jk I actually don't know either anybody want to help us out?
Old Oct 5, 2009 | 10:47 PM
JFranco's Avatar
Originally Posted by ryansrx8
ha loser what a retarded noob question lol jk i actually don't know either anybody want to help us out?
lol
Old Oct 5, 2009 | 10:50 PM
05rex8's Avatar
sold the 8... :(
Idemitsu Racing Rotary Fuel Lube (Premix) - Synthetic Blend
Inherently with many rotary engines, the entirety of the rotor and housing are not being sufficiently lubricated, resulting in premature wear or damage. In order to increase lubrication within the engine, Idemitsu developed Idemitsu Rotary Premix. At 1/2 oz per gallon of fuel, it is a cost effective way lubricate more of your engine and prevent premature catastrophic damage.
A special blend of base oils reduces deposits and subsequent exhaust port clogging. As a result, your rotary will maintain the power at which it was designed. Special detergent/dispersant additives keep your fuel injectors clean to reduce maintenance. Provides additional lubrication for apex and side seals to increase seal life and increase efficiency of engine. Special additives allow for better sealing of the chamber, creating greater efficiency and more power.
http://www.mazdatrix.com/q-supply.htm
you pour it in the gas tank
next time try the search function.
xun4gvn4everx's Avatar
True love is blue x2
It is putting oil into your gas tank like you would with a 2 cycle motor. Do not use the oil in your engine, there is specific stuff you buy that is called premix. Search premix and you will find endless threads on this. some say do, some say dont. Its a personal opinion.
Old Oct 5, 2009 | 10:52 PM
expo1's Avatar
He's as bad as Can
The second sticky post in the very same forum you posted is is devoted to this subject.
https://www.rx8club.com/series-i-tech-garage-22/gas-oil-premix-thread-99636/
The simple answer is if you have an 2004-2008 and plan on keeping the car a long time you should premix ( mix a certain type of oil with your fuel ). The details can be found it the above mentioned thread. I use 4oz of Idemitsu per 13 gallons of gas.
Old Oct 5, 2009 | 10:53 PM
JFranco's Avatar
Thanks guys...
Old Oct 5, 2009 | 10:54 PM
JFranco's Avatar
https://www.rx8club.com/showthread.php?t=99636
What makes the 2009 and later different??
Old Oct 5, 2009 | 10:56 PM
expo1's Avatar
He's as bad as Can
Mazda realized there wasn't enough oil being added to the center of the rotors and added a third nozzle. That doesn't help us 04-08 owners which is why many premix. 2009 RX-8 have a better system of adding oil to the engine than older RX-8's. They only way we can make up for the lack of the 3rd nozzle is premixing.
Old Oct 5, 2009 | 10:59 PM
JFranco's Avatar
Mine is 09 so I guess I should not wory that much huh?
Old Oct 5, 2009 | 11:08 PM
expo1's Avatar
He's as bad as Can
You have less of a reason to pre-mix than we do. But I would still do it, more positives than negatives.
Old Oct 8, 2009 | 12:46 AM
jessedrifter's Avatar
so cal
i think someone should just make a diy premixing for noooooubs
Old Oct 8, 2009 | 12:47 AM
I'll give ya a premix for n00bs
Old Oct 8, 2009 | 12:52 AM
UrbanOcho's Avatar
Stick Specialist
**** rory you took the premix right words right outta my mouth
damnit, i love n00b threads. they help my post count cuz i know nothing and can add nothing and still bank numbers FTW!!!
Old Oct 8, 2009 | 12:58 AM
Easy_E1's Avatar
I'm sure you know some things. The important things.
Old Oct 8, 2009 | 01:02 AM
so cal
i know important things
Old Oct 8, 2009 | 01:06 AM
mike[piston eater]'s Avatar
O' Let's do it.
+1
Old Oct 8, 2009 | 01:14 AM
Easy_E1's Avatar
Originally Posted by mike[piston eater]
+1
Fluffers! Sheeeesh.
Old Oct 8, 2009 | 01:19 AM
O' Let's do it.
i haz proof easy, next time your in so cal im gonna bring you some of my lady friends
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
Aug 21, 2022 01:29 PM
WranglerFan
May 31, 2022 07:51 AM
TJSiegrist
Sep 10, 2015 09:29 AM
