What is included in a factory rebuild?
Old Oct 5, 2009 | 10:27 AM
TX What is included in a factory rebuild?
I know its posted somewhere but I searched and could not find sleepy-z's post. I know it varies somewhat but does anyone know if the bearings are replaced every time?
Old Oct 5, 2009 | 11:27 AM
I found it on my first try, came up on my search as the first topic
you n00b ! SEARCH !!!!
Originally Posted by Sleepy-z
Rebuilt engine parts to be exact.....maybe 20% chance I built it btw....
New parts guaranteed...
Rotors and components on the rotor like springs/seals, water pump, oil pan, all rubber/metal seals/gaskets, bearings for stat. gears and rotors
50/50 shot of new parts.....
Some housing are new, pulley, flywheel can be used btw but 75% are new roughly, eccentric shaft is usually used but chance of a new one.
Used........
Some housings, pulleys, flywheels, stationary gears are used but with bearings pressed in by yours truely(apperantly I am the only one there that is capable of doing it without messing up), parts in the oil pan(sensor, baffle plate so on), oil pump/chain.
BTW small note, all oil pans are updated to the newer style(metal baffle plate added).
Old Oct 5, 2009 | 11:38 AM
Damn it, i knew he posted that info. I searched for like ten minutes through his posts and didn't find ****.
Thanks.
So all the bearings are new. But soem stuff is missing like teh water pump and stuff right?
Old Oct 5, 2009 | 11:57 AM
Thanks.
Water pump and Thermostats are always brand new. cuz its not worth it for a 100 dollar part fuxk a 3000 dollar engine up.
in the other words, a Reman will have roughly 80%+ brand new parts.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
cgrichie
Sep 19, 2015 07:03 PM
Turbonostic
Rotary Swaps
10
Sep 19, 2015 11:53 AM
