help...ap question..quick and easy
Old Sep 24, 2009 | 09:51 PM
RX8sd's Avatar
I got the ap from mm a couple days ago and installed it on my 04 MT. I reflashed with the Stage one tune. My question is...is the stage 1 MMs tune? I'm asking because I heard that the stage one can cause engine knock and only provides 6ish pounds of torque as opposed to the 10 that I heard about with his tune. I'm not bitchin about it....I just wanna know if I did the right map or if I don't have the map I'm supposed to. I tried to get ahold of mm but I'm sure he's busy and quite frankly I can understand if he's got bigger fish to fry than answering a noobs question with the ap. I know and I've searched...theres just so much info out there that I don't have time to go through it all and I didn't understand half of what I was reading anyway....so can you help me out guys....please
Old Sep 24, 2009 | 10:01 PM
AJRx892's Avatar
http://www.youtube.com/watch?v=tFC1l6lS2bw
dunno if that will answer your question but it seems pretty staight forward to me....
of course i dont have an ap.....yet haha
Old Sep 24, 2009 | 10:04 PM
Mawnee's Avatar
I divide by zero
As far as I know MM does NOT preload the AP with his tunes. The stage 1 tune thats on it is a generic Cobb map.
Old Sep 24, 2009 | 10:37 PM
whatever map is on there is a Cobb map. (which means it's probably not very good)
READ the FIRST post in his thread. It will answer all your questions.
Old Sep 24, 2009 | 10:50 PM
JantzenRX-8's Avatar
Since we're on the topic of quick and easy AP questions can i temporarily thread jack and ask if when you receive a AP from MM if it can bump up the idle or is that part of the map that MM creates?
Old Sep 24, 2009 | 11:16 PM
PhantomRX-8's Avatar
Bad Ass
Yes, tell MM you want the idle turned up when you send him your datalogs. His tunes come locked so you cannot make any changes to them.
Stage 1 is an NA tune, do not put it on your car if you are turbo'd right now. Read his instructions on the first post carefully. It will guide you with what to do. You need to go to his website and download the base map that is appropriate for your car. It too is locked so you cannot make any changes to it. Also, that map is in NO WAY intended as a performance map. Do not go into boost while driving on it. Wait for the tunes that MM sends back to you before attempting any boosted driving.
Old Sep 25, 2009 | 12:04 AM
RX8sd's Avatar
no I'm not boosted....won't be for quite a while. I'm trying to set it up for nitrous down the road. I just thought it came with maps already on it. Shows how much I know....sorry guys...I'm learning. So I just follow his directions about how to data log my car..."which seemed easy enough"....send that to him....and it goes from there I take it....
Old Sep 25, 2009 | 12:37 AM
Bad Ass
Ok, then if youre not boosted then youre in good shape so far. I want to say he has base maps for NA cars also, although I dont think they are far off from stock. Assuming your car is a 6 speed, click on this and down load the 4.0v zip file.
http://www.mazdamaniac.com/dl/apcal/...ted/index.html
Once you save it, open the AP manager and find MMs tune through the software and load it to the library. Once you have it in the libray, hook the actual Cobb unit to your computer and transfer his tune to your Accessport. Go to your car and flash the MM_4.0v tune to your car. Once the flash is complete, start the car and take it for a spin, nice and easy driving, no WOT. Park car for a couple hours (till coolant is at least under 100 degrees) then take car for another ride, no WOT. Park car again and let sit till coolant is under 100 degrees. Then follow all the steps regaurding datalogging per his first post. He made it pretty idiot proof.
Old Sep 25, 2009 | 02:29 AM
RX8sd's Avatar
Lol....I don't know about idiot proof. I"m a pretty big idiot when it comes to the ap stuff. Other stuff I"m great at though....anyway I'll give it a shot this weekend and if you don't mind Phantom...I'll probably ask ya some questions along the way
Old Sep 25, 2009 | 03:24 AM
Juansito's Avatar
Redlined
Doesn't come with MM map preload.
You need to download it from his DB and put it on your AP.
You use this map to do the data-logging as well.
Old Sep 25, 2009 | 04:01 AM
Bad Ass
No problem man. Just let me know what you need and Ill help you as best as I can.
Old Sep 26, 2009 | 06:43 PM
shazy's Avatar
cool.
WranglerFan
Aug 21, 2022 01:29 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jb4ker96
Sep 27, 2015 10:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
